Right, no OTC cap. I'm using brownout detection for the power switch. I'm so close............
I think I have that driver with the 45V. I can try to flash it tonight and see what happens. Can you post or email me the exact FW you are trying to flash and the fuses?
I also have this one that is modded.
Ahhh - the firmware is my under test/debug/pre-cursor/not-quite-there version, if you know what I mean...
I'm looking around, and found someone else: vex_zg, who seems to have had similar experiences, here: https://budgetlightforum.com/t/-/31826.
So, he set 8 Mhz and turned off the /8 clock option... Hhmm - I'll try anything. He has very similar experiences though - the MCU seems bricked then comes back to life! Exactly what I saw. I'm also pm'ing RMM, TK, and Mike C and asking them to check in. I know Mike has done 85 work, and RMM and TK I think started.
Are you programming at 5v?
Slower avrdude programming speed? Like -B 4. Higher is slower, max is 64.
Yes.
ImA4Wheelr - what is that hugh part on that driver pic? Mine is the same driver, yes. Dunno, vex_zg pm'ed me, saying might be something on the driver PCB, but weird because it was basically all working. I've been using this same driver. I should really just try another one built up though, maybe different design too.
The default avrdude programming SCK speed is suppose to be suitable for target MCUs running at 4 MHz clock and above. What did clock did you have the attiny85 set to?
Try avrdude -p t85 -B 4 -c usbasp
I’ve heard most chinese firmware will automatically adjust SCK though.
Just did try "-B 4"- no difference. My fuses right now are:
-Ulfuse:w:0xe2:m -Uhfuse:w:0xde:m -Uefuse:w:0xff:m
I'm using 8 Mhz, tried with and without /8 clock option, and I have brownout enabled for 1.8v.
Just tried "-B 40" and no difference.
I'm gonna remove this 85V and install one I "air" programmed. Betta the new one will work on the board, maybe can't re-program it though, and the old one will probably air program... This is ugly if this is how it's gonna be...
Minutes later....
I pulled the old one off, traced MCU pins on the board all over the place - looks real good, nothing grnd'ed that shouldn't be. Yes - new one worked on the board, w/bugs of course. Old one can now be programmed in "air". New one on the board can't be reprogrammed - once I tried (of course) to program it, the program is trashed, once again. Back in the mess I started with.
Madness I Tell You!! Sheer Madness!
Do you have an unpopulated pcb? I’d try a tiny85 on an empty board then populate one component at a time! Hunt that evil thing down!
Which usbasp do you have? Blue one with a slow SCK jumper?
I think the chinese usbasp firmware might not respond to the avrdude -B command. I'd recommend trying the slow jumper.
I feel for you Tom E. I cant offer you any help except my support for what your doing.
Hhhmmm, I got two dongles - quite unusual I would think... I think they are the same config - I'll check, after another beer. I do not have a drinking problem - or a flashlight problem...
Updates:
- The JP3 jumper didn't work either - same result
- I mounted the 85V with the bent legs that I could air program onto a blank 17mm wight DD+1 (different driver) and same problem - verify fails on the first byte. So, it's a bare board with no components other than the MCU. Clip looks well secured - looks like all legs are making contact. I buzzed out the legs and all looked good.
So is it the driver board that is the problem? I don't know what " I buzzed out the legs and all looked good." means. I've been flashing chips on the 17mm board without issue, but I don't recall if I have flashed any on 22mm boards.
Tom E wrote:
. . . ImA4Wheelr - what is that hugh part on that driver pic? . . . .
That is a LDO Voltage Regulator. It's an LM2936. I'm using it instead of doing the Zener mod so that I can have a momentary switch and greater than 1S cells and not have to worry about parasitic drain if I accidentally forget to lock out.
EDIT: Fixed my the above quote. Pasted the wrong text.
Sorry, updated post #243 - I tried a different driver altogether - a 17mm as opposed to a 22mm, both wight designs, both FET+1 boards, both have the same verification problem: can't seem to write/program anything to the 85V when mounted.
- The 22mm is fully populated
- the 17mm is bare with only the 85V mounted
I edited my post above as I had quoted the wrong text.
Hmmm, Could you provide a clear pic of one of the offending boards/drivers? I wonder if there is a trace error. I know I have repeatedly flashed the 17DD+1 with no problems. I think I have flashed the 22mm too, but not sure. I tend to "air" flash first before building a board because it is easier. But I have reflashed several other drivers without issue. So it seems like it may be the batch of boards you got.
I will try to flash one of my 22mm drivers today and report back.
I buzzed out all traces on both boards, so the one 22mm board works 100% perfect - always has, with both a 13A that it had, and later a 45, then a 85 (it works with a known good version of firmware - what I'm testing now is new). The 17mm is a bare one I had around - never had a bad one and I've built maybe a dozen or so. I'll take pics of both and poste them.
I still don't know what "buzzed out" means. I'm assuming it means you checked for continuity from pin to end of each trace and lack of continuity to the other pins.
I looked at my programmer. Instead of saying "Lcsoft Studios" like in the picture Halo... posted in Post 241, mine says "LC Technologies".
I think that (checked continuity) is what he meant.
I haven’t been following this thread closely but is Tom E’s problem that he can program the 85 chips when they are not connected to anything, but when he solders the 85 chip onto a populated driver board, he cannot program the 85 chip anymore?
You are correct Ohaya, but he is not having the problem with every board. He has at least one that works fine. Right now it's a mystery as to what is causing the problem.
Ahh - no, I don't have any board where programming on it worked repeatedly... Even when I worked with the 25's and 45's, I sometimes could get it to work the first time on a board, then never again. Maybe buzzed out is an 80's term - yes: put your probes on the board, if the DMM buzzer sounds, it's got continuity . I also checked for ground shorts, cross shorts, etc. Everything looks good on the board, and certainly the one 22mm driver I've been working with all along, it works.
Been doing a bit more research and it almost acts like I soon as I program it, the "lock" bits are getting programmed, or the serial dnld is being disabled (fuse bit). Yet, when I take the MCU off the board, I can program it fine.
I only have one flashlight I deployed my new firmware in, and that's a EE X6R with a 45 in it.
Have you shared your X6R firmware somewhere? I’m looking for something with temp monitoring that would work on a 25v for my 7g3cs (dual switch).
I’m also looking for a very simple (3-4 modes) clicky firmware with temp monitoring for a different project.
No - I've done nothing w/temp monitoring, and my adv. e-switch/brownout development is stalled til I can figure how to get the dnld working reliably.
