Poll: would you consider getting a Noctigon Meteor M43 with a simple UI?
Well i see no use of that torch too but hey, thats the power of democrasy and free expresion- especialy if ones ctiticizm is motivated
Group buy for $99? I’m in.
It would need to be single click to turn the light on and off.
Hold switch while light is on, and ramps levels.
Hold switch while light is off, turns on moonlight mode.
Single click turns on light in last used mode including turbo.
Give me this ui, I promise to purchase at least two more units.
Thats almost the UI I like as well. But I would prefer to have just 3 modes instead of the ramping.
Yea that’s what I actually meant…. Ramping 3 or 4 mode.
I’d like to see a Bluetooth version + Simple App = Customize your own Meteor UI (I think someone suggested this in the thread a while back).
That would be fantastic.
This….
I love the UI for this light. Would not want it for a smaller tail switch like but I think is brilliant for a forward switch turbo centric light like this.
Add double click from off to high (turbo) and you have the praised "Olight UI".
I like that UI very much and would definitely buy a M43 with it. (Note: I don't have the M43 - Simply because of the confusing UI!)
Oh, I think I misread blue8llz UI. I am a person that likes to Click to change modes, rather than holding the switch.
I actually like having a Clicky at the back for complete power off, and side switch for switching between modes. (but that wont work with the meteor)
Double click to Turbo, Long press to Low. normal click to cycle through modes.
But if its only a side switch:
from off: click= last memorized mode
from off: double click = Max
from off: long press = Moon
when on: click= cycle through modes
when on: double click = Max
when on: long press = mmmmmm off maybe.
Long press to turn off.. is a turn off for me. Absolute deal breaker.
I’d love to put my code on this light. I looked into what it would take though, and there’s an awful lot of twisty assembly code with comments only in Russian. And its author warns against anyone modding it because it apparently “fails open”, meaning code bugs could cause explosions. :frowning:
But if I could, I’d like to run an improved version of my ramping UI on it.
While off:
  • Single short press turns light on in last-used mode.
  • Double click goes to turbo.
  • Long press turns light on in lowest mode. Keep holding for a few seconds to enter or leave lock-out mode.
While on:
  • Single short press turns light off.
  • Double click goes to (or from) turbo.
  • Press-and-hold ramps smoothly and pretty quickly until button is released. Release and press again within a second or so to reverse and ramp the other way.
… and probably some extras, like for triple click.
Will this be a reality or we just dreamin…?
Still dreaming.
This would be the perfect UI and should be in every electronic-switched light I use. :wink:
Considering the price of this fl. I would say that sale is going quite slow or, nobody is asking about the fl. itself…
Maybe time to produce a brother/sister of this meteor....
It’s a nice light but the problem is that manufacturing small quantities of high quality product will always be expensive, that custom made noctigon MCPCB is not cheap for sure, more stock parts you use cheaper it gets…
Well originally it was going to just be a single run of 300 flashlights. But word recently came out from RMM that Hank has a second run in process that should be out in a couple weeks. This new run also contains the new tan body.
