Solarforce L2s
Or as I like to think of it , L2small [ 18650 ]
Nice small size, is it readily available or it is a custom?
Its an extension of my L2mini ... Ever since I made the mini , I thought why not a small/short 18650 , so after almost 1 year on the back burner , the L2s was born ... [ L2small ]
Pictured , is the L2micro with a shortened CR123A extension .. [ Shortened 20 thou at the front as the threads are so deep they wont engage the body ]
Pictured with a regular L2 , you can see its quite shorter now ... So now I have the option of RCR123A x 1 or 18650 x 1 / Possibly now a L2sm [ small / micro ]
If I had the space to put one I'd be tempted too. Not that I'm any good with my hands.
How much work is it to make the micro? I take it you had to empty out the tail section?
You need to make the pill smaller , originally I used a stock L2 tailcap , but a few months ago I did a Romisen forward clicky mod , and it improved the internal space in the tailclicky ...
Here you can see how much smaller the pill needed to be , before the Romisen forward clicky mod / You will need to make the pill shorter , internal space is at a premium in the micro .
old4570 can you explain a little about the Romisen foward clickie mod please ?
http://www.shiningbeam.com/servlet/the-92/Forward-Tactical-Click-Switch/Detail
Just pull out the solarforce guts , and drop in the Romisen forward clicky unit . Might need a washer , but a rather easy mod .
Thank you. Does it matter which Romisen switch? Does the N3 handle more amperage?
I got 5 of the RC-G2 [ in the pictures they look the same ??? so cant say if one is better than the other . ]
