I finally modded my A6 with a triple and bypasses inside both springs. Output (and heat) is really stunning for such a small light.
I get a verry audible whine as well. The higher the current the louder it gets. Retouched all solder points on the board, and it’s also there without the springs and tailcap! Would drowning the whole board in epoxy help to get rid of the sound?
I understand that this is caused by rapidly switching between no current and 10+ Amps.
Basically had problems with bad soldering on 7135 chip. Could not get the head open, maybe mine was glued, I don't know. Contacted banggood general customer service email on 23 September. Got reply on 24th, offered to send me driver only. Declined as I suck at soldering and I can't get the head open, insisted on full head instead. Agreed and head was sent out on 27th September. Today it cleared customs and on the way to me, should receive it sometime next week.
Pretty prompt response I would say... on another note, how do I open up the head?, pliers and elbow grease?, I'm assuming it unscrews at the groove right above the logo.
Both wires have dry dry solder joints.
This may not be the cause of your current problem, but it will not be reliable as is.
If you have problems with the low modes, the 7135 chip probably needs to be re-flowed.
(Try to see if the there is solder below the tab on the back of the chip.)
Flashlight won’t turn on at first press of switch, nor second most of the times. When it does, non-click presses scroll through a weird set of modes, with no moonlight but two identical low modes, a mid, and two identical high modes (this is as far as I recall) and the light will eventuality turn off itself.
How to reflow the 7135 chip? Completely de-solder and remove it? I have very basic soldering skills, this is the most advanced stuff I have ever done, but I don’t get any reply from “support”
Add some liquid flux at each pin and the tab. Then add a little bit of solder to each pin with a hot (750 F) soldering iron.
The flux will make the solder flow where it needs to go.
Do not spend more than 2-3 seconds per pin with the soldering iron. Do not heat it up so much that comes totally free, allow at least one pin to cool down so the chip stays in place.
OK, so, the switch is FRIED.
Maybe I killed it definitively, maybe it was defective beforehand. Any suggestions? Can I cannibalize another light’s switch?
I got mine open by putting a drop of penetrating gun oil (“nano-lube”) and a drop of electronics cleaner/lube (Radio Shack spray can, just a tiny bit) into the groove, drawing it around the whole groove with a toothpick, then leaving the head standing on the bezel overnight. Just a drop. Anything that penetrates into the head will vaporize all over the inside of the reflector and emitter. Don’t overdo it.
At least for mine, I think there was just crap in the threads jamming them — because lots of muscle twisting the thing in a padded vise with padded pliers didn’t budget it at all. Solvent did loosen it up — after leaving it overnight. Then I cleaned it very carefully before putting it back together.
I sourced a switch of the same shape, but orange in color, from a Xeno E03. I hope it will endure the amps, but the E03 supported 14500 cells so I hope it will do the job.
Uh oh... I'm sure they must have improved on that at some point, but that orange switch was the weakest link of the Xeno03 back when they first came out three years ago .
I got my new tubes today but they didn’t fix the issue. Anybody else have this happen? I thought this was the fix if your light seems to be ok otherwise.
It will fit, but the thin trace from the middle of the board to the switch lead will have a hard time with the 4+ amps that this light is drawing, the corresponding trace on the BLF-A6 tail board is way wider. I would go for soldering a new 1288 Omten to the existing board.
Penetrating oil, rubber, cardboard and pliers did it. Needed rubber again for the driver retaining ring. No sign of problems. Just wired the springs and added heat sink compound around the driver.
