DC-Fix Diffusion Film Sale
446 posts / 0 new
Boaz
Boaz's picture
Last seen: 4 hours 54 min ago
  * Updated 9-01-21
2 - 3 " x 6" sheets of  "The Famous Dc-Fix" shipped to your door only $3.50
Add $1.50 for extra sheets
 +$1.50 - international shipping
 Dc-fix will take a really bad beam and turn it into soft buttery smooth delight with amazingly low light loss (3.2% ) I've found myself using more and more diffuser film to  soften  artifacts ,cancel out ugly rings and create a floody smooth  beam . If you've wanted to try it ...
   PM me with your address,...hit my paypal and I'll ship you some. Thanks !
- materials available are:
 #1- The original Dc-fix single sided adhesive . 3% loss...Selfbuilt on CPF measured it at only 3% loss..Great stuff  ****
 #2-   same thickness a little different pattern ..still more of a frosted ****
 #3- Single sided (pattern on just one side and smooth on the other) non adhesive a little thicker than dc fix , pattern is a fine frosted . This film has the least amount of diffusion and still produces a softly diffused beam which leaves some hotspot .( used to be called 2C )  Very popular !!!!  ****
 #4- Fairly rigid. double sided ,non-adhesive, about the thickness of a playing card, can be used to make removable lens cap type diffusers****
 #5- a non adhesive thin material that flattens out the beam so it can be positioned horizontally or vertically . my thoughts are use as a bike light to spread out the beam left and right and cutting off beam that needlessly blinds oncoming traffic.***
 #6-///Sold out //  non adhesive double sided pattern that is about twice as thick as Dc fix . flexible ****
 #7- Non adhesive double sided very fine frosting similar to #2 but more flexible .works great   4 stars****
 #8- Thickness is close to  #4 no adhesive ,two sided (pattern on both sides) a little bit better than original number 4 ....****
 #9-    "   "  Same but different  /two sided non adhesive    "            "                 "          ....   ****
 #10- Same but different  /two sided non adhesive    "            "                 "          ....   ****
 #11- Same but different  /two sided non adhesive    "            "                 "          ....   ****
 #12- Close to same thickness but again a different pattern and different diffusion
 #13-  "    "        "        "           close but not the same  Smile
 #14-  One sided - non adhesive / still about the thickness of a playing card ****
 New materials available are :
--> #7 - Non adhesive double sided very fine frosting similar to #2 but more flexible .works great   4 stars****   <-- NEW
                                                  Diffuser film is rated 1-5 stars according to how much I personally like it .:) *****
I respond to PMs' with what current film I have available ... the list will always change a bit.
  OK how about a few Pics   :
  Here is an xpl emitter with a yellow hot spot ,ugly green in the corona and bad tint shifting all thru the beam.
Before
 AFTER
with dc-fix added
Shot on an iPhone and very closely resembles what your eye sees
   Thanks ....
Edited by: Boaz on 09/02/2021 - 17:47
ReManG
PM incoming!
saypat
saypat's picture
Last seen: 1 day 22 hours ago
this film is some of the best – really cleans up a beam! I have it on many of my lights, easy to apply. Recommend it!
ChibiM
ChibiM's picture
Last seen: 1 day 7 hours ago
Yep, I recommend it also.. crappy beam? DC FIX!
great way to improve your cheapos.
1dash1
1dash1's picture
Last seen: 2 years 5 months ago
PM sent. Smile
Rule 1-1 as it applies to life, take it as it comes.
Leif
Leif's picture
Last seen: 6 days 12 hours ago
Fantastic stuff, I have it on throwy lights to broaden out the beam. Two layers gives all spill, no throw. I have heard it absorbs only a few per cent of the light.
This forum may contain nuts.
No animals were harmed in the creation of this post.
Be nice to people. It annoys them no end.
Ronin42
Ronin42's picture
Im in for three
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
pilotdog68
pilotdog68's picture
I will take 2. PM incoming
Gunga
Gunga's picture
Last seen: 46 min 46 sec ago
I love this stuff. Very useful film! I use it on a bunch of mine lights!
ReManG
And now I see my message that you have already shipped mine…. WOW, thanks!
jacktheclipper
jacktheclipper's picture
Last seen: 5 hours 43 min ago
Great stuff .
All of my lights except throwers have a layer of this .
Great for close-up work and headlamps .
What I do
edeekeos
edeekeos's picture
Last seen: 4 months 4 weeks ago
Thanks for doing this!!!! PM Sent!
MauiSon
Last seen: 3 days 21 hours ago
I would like to see an example of the product being offered. As I understand it, there are different types/levels of diffusion available. Thanks, Ed
[Is this the ‘sand’ or ‘moire’? Product #?]
Halo...
Halo...'s picture
Last seen: 5 years 3 weeks ago
People just refer to it as “dc-fix” because it seems “sand” is the only one that works well for flashlights. If I’m not mistaken, the others don’t really come close.
Boaz
Boaz's picture
  Selfbuilt did a test on it on CPF  and came up with the  3% loss number .
 It's definitely as good or better than any other diffusion material I've ever used  . I use it on the S2+ Convoy lights that I originally didn't like as much as the S2 Convoy because they were to floody  . This just makes them a beautiful smooth beam which I like much better .
   It also kills all those super ugly rings from really ringy lights like the Tank007 566 lights . It took me a long time to start using diffuser film because i somehow thought it was cheating or going to kill a bunch of lumens .I agree with "Jacktheclipper"   it's a nice addition to lots of lights .
 Certainly one of the cheapest things you can do to dramatically change or fix your flashlights beam pattern .
 S -series Convoy tube lights in a nice tint with dx-fix on the lens makes a great 'round the house light
Leif
Leif's picture
Ah yes, this should be called Mag-Fix. It makes my old MagLite have a nice smooth beam. Big Smile
ReManG
So do you have any beamshots of the film in “action” so to speak?
I am looking forward to getting mine for my Xtar H2 headlamp
Gunga
Gunga's picture
It’s good for the xtar but I ended up Using a super heavy film (not DC fix) to get the flood I wanted.
cabfrank
Last seen: 1 month 6 days ago
Pm sent. Thanks.
siata94
siata94's picture
Last seen: 2 days 5 hours ago
awesome, thanks Boaz. I have DCFix on a couple of lights and it def does the trick.
Tom E
Tom E's picture
Last seen: 3 hours 55 min ago
Again, thanks! Ordered... Look'n forward to trying it out.
Cula
Cula's picture
Last seen: 5 months 2 days ago
Pm sent. Thanks.
cabfrank
Thanks Jeff!
ReManG
Did you change the emitter as well, or just try the film? Is the DC fix good, but just not good enough for this?
I pls on reflowing a Nichia 219C on mine…
Gunga
Gunga's picture
I swapped to Nichia 219. The film is good for many applications. I just wanted a very floody beam and it wasn’t enough for the xtar.
Splott-Light
Splott-Light's picture
Boaz,
Thanks for bulk-buying this for us, and then sending little strips of it all over the world.
What a hobby!
PP sent.
Cheers,
Splott-Light Smile
Ouchyfoot to a New Member: Welcome CJ. Now you have to learn about buying an inexpensive flashlight and modifying it until it either blows up, or starts small fires on the moon…………
Hugh Johnson:
I, too, once lived a tragic and empty life. Then I found [portable] light.
You forgot to mention clothes. I sold most of my clothes to fund my light collection. This is actually fine, since I only go out after dark, and most people can’t see me.
Finally, I got my priorities straight.
jacktheclipper
If like me you're a beam profile snob
This diffusion film does a great job
Of creating a light
That is evenly bright
Why be part of the glaring spot mob ?
What I do
ReManG
I am going to try it, worse come to worse, there are two sides to the lens that I can DC-Fix… Lol
keithd
keithd's picture
Last seen: 6 months 3 weeks ago
Splott-Light wrote:
Boaz, Thanks for bulk-buying this for us, and then sending little strips of it all over the world. What a hobby! PP sent. Cheers, Splott-Light Smile
Agreed, thanks Boaz!!
“What a hobby!”
-Yakov Smirnov
Big Smile
ohaya
Last seen: 3 years 4 months ago
PM’ing you – would like 4 sheets (or whatever they are)..
Jim
1dash1
1dash1's picture
Boaz:
Received mine in the mail today. Thanks!
Now, which flashlights should I try first? Glasses
