It's pretty much better than the Yinding all around. Better build quality, more mass for heat management, "off" out of the mode cycle, and a bit more output current (Yinding at 2.4A per LED IIRC). Apart from the BT70, Nitefighter is really producing great lights for really good prices. I'd easily pay $35 for just the lighthead.
Hmm . . . It seems I forgot to list my Yinding in this thread. I'll have to add that too soon.
A good light?
I was wondering to snap it up, but no reviews had been posted. I guess I should have looked at MTBR
I’m not a modder so I would just use it as is.
Snagged a few beamshots of my BT21 with LEDDNA 10º optics last night. Same location as my other beamshots. I used 2 batteries at about 75% charge in my modded Fenix case (so Turbo may be a hair dimmer than max). Distance to the two trees is approx. 185 feet, approx. 275 feet to the house off to the left of the tree:
Low:
Med:
High:
Turbo:
My wooded setting:
Low:
Med:
High:
Turbo:
For comparison, here are mouseovers with the BT40s on Turbo (mouse out=BT40s, mouse over=BT21 (note: photos takes on different dates):
Might as well throw in some mouseovers with my modded HD-016 (mouse out=HD-016, mouse over=BT21 (note: photos takes on different dates):
Modded my Nitefighter BT40S to the new Nichia 219C's. Here are some beamshots with mouseovers.
Mouse Out = Original Stock XP-G2's, Mouse Over = Nichia 219C's:
Wooded setting:
And wooded shots of the Nichia modded with the light mounted below the camera so as to get that darn bright button out of the photo! Low, Medium, High, then Turbo:
The yard shot doesn't show it too well, but in the wooded shot it appears that after the Nichia mod that the light lost just a tad bit of throw and gained a little more flood. The color rendering does in fact look better, even though it wasn't that bad with the original NW XP-G2's. (Look at that first large tree to the right.) I can say that those leaves and foliage look exactly like they do to my eyes in the daylight.
I initial impression was that you lost a little throw going to the 219C, but I think all the added flood and cooler tint threw me off. If you look at the dark area beyond the visible beam (first picture in Post 46), more items are visible in the 219C shot. Has something changed out in that area to make those objects better reflect light?
No, I don't believe anything has changed. I gave that first mouseover a good closeup look and they appear identical to me as far as what is visible in the distance.
OK, I pulled up your pictures on a better monitor and I see what you mean. The throw is a little less with the 219C. What was throwing me off was the big dark trailer that was in front of the big structure or fence on the right and the house/building that is more visible on the right. I think that building is showing up more because it is now in the bigger flood of the 219C. On the better screen, I can see some stuff in the dark that I could not see with the 219C. Although the throw is slightly less, the bigger flood seems better for biking so that you can see objects approaching the path better further out.
I got a question on how to feed the ‘Kaidomain’s Gemini Duo / Yinding Clone’ when it’s 4.2V only?
I was thinking about a 2 cells parallel setup, but got problems to find a nice off the shelf battery case, most discussed cases are always 2s2p and therefore deliver to much voltage.
Garry how did you power up this nice budget bike light?
The price at kaidomain is really tempting.
I would recommend strongly against the 4.2v version. You get too much voltage drop through the thin wires. (See the thread I did on that light asking for help doing the sense resistor mod. I think it's linked further up in this thread.) I don't even use this light anymore. Buy the NW Yinding at GearBest. Much better light with great thermal path. Or the Nitefighter BT21 is an even better light.
Thank you Garry !
I will follow your advice and look closer at the Yinding version at gearbest.
Since the nightride season in german mountain bike forum just started, I will probably get back to you (and everyone else in this part of the forum) with more stupid questions.
Though I’m still not unsatisfied with my Solarforce at the handlebar, I would like to get a bit ‘more’ or ‘better’, you know the old flashaholic virus……. sigh.
So I boosted my BT40S driver up to a calculated 4.0A (2A per emitter) and I think I might have this driver boosted for too much light (is there such a thing?).
Some details: I've replaced the SS34 diode with an SS54 (which is huge in comparison - didn't realize that). I also replaced the stock "2300" FET (datasheet found here) with an "AO3400" ("A09T" chip marking - datasheet here). I happened to have the AO3400's on-hand from my Courui mod. Lastly I added (2) R200's on top of the (2) stock R200's. I had already replaced the power cable with the DX 20 gauge one.
Driver with FET and diode replaced but prior to adding R200's:
Comparison of the SS54 to the SS34:
Fired up my driver-modded BT40S for a bench test. Started out at 3.3A from 2 fully charged protected cells in my modded Fenix 2 cell case. Left her burn-in and no smoke, no hot components either. After 2 minutes the lighthead was starting to get uncomfortable to hold in my hand. Wow it's A LOT of light!
This light will definitely need powered from my homemade 2S3P pack made from those Xiaomi power banks. (Need to finish that yet.)
Here are some beamshots using 4 fully charged unprotected cells in my old Pannova case. Current measured off the case was 3.48A peak dropping to about 3.2A (so Turbo would give more output yet if I can get a pack to provide the full 4A output. (Remember, these beamshots are with Nichia 219C LEDs.)
Boosted Driver:
Stock driver:
Boosted Driver:
Stock Driver:
Wooded Mouseover: Mouse Out = Stock Driver, Mouse Over = Boosted Driver both "Turbo" mode :
Yard Mouseover: Mouse Out = Stock Driver, Mouse Over = Boosted Driver both "Turbo" mode :
And here's how much more output low has now (it pulls about 1.0A on low for +/- 500mA per LED).
Boosted driver's "Low":
Stock Driver's "Low":
Mouseover on the "Low" mode, Out = Stock, Over = "Boosted Driver"
So what do you think? Should I lower output to bring Low-Med-High back down some? And any thoughts on why "Turbo" doesn't pull full calculated current? Even the stock driver was calculated at 2.0A but only pulled about 1.75A.
In this form it might work as a bike heater for winter use. The airflow coming past it will blow the heat back at you while you're riding :) . Perhaps I should work on a seat mounted light so I can have a "heated seat" :) .
