BLF Special Edition Lights - Master List
Hello BLFers and curious lurkers,
This post intends to serve as a comprehensive index of the BLF Special Edition lights this forums has produced as well as upcoming Special Edition projects that seem promising. It lists those rare lights that only exist due to the efforts of this community - lights that are designed or modified by BLF members and produced through their efforts, either by working with a manufacturer or even by their own hand in quantities > 1ish, not one-off custom lights. To that goal, it is incomplete! If you see errors or missing information, please let me know. This chart will only be made complete by the efforts of the community.
Light
Date
Status
Eastward YJ J609
10/2010
Out of Production
The “BLF light that never happened”…then it did. More info here and here
BLF AA-Y4E
10/2010
Out of Production
AA/14500 tube light with custom modes
BLF Tank007
9/2011
Out of Production
E07 with neutral emitter and 3 modes
BLF CQG S1
9/2011
Out of Production
Small ss penlight with tint selection & BLF logo
E1320 BLF UF-2100
6/2012
Out of Production
UF-2100 with custom 5-mode driver. Review and more info here.
BLF Mini
9/2012
Out of Production
Trustfire Mini-01 with 1kHz pwm, nw, mode order l-m-h 2–25–100%
Trustfire A8 BLF
11/2012
Out of Production
A8 with current bump, faster pwm
ThruNite Saber 1A BLF
3/2013
Out of Production
Cheaper? Not really sure if this light had any upgrades except the logo
BLF Mini v2
3/2013
Out of Production
Trustfire Mini-02 with 1kHz pwm, 2 tints, l-m-h 2–30–100%
BLF CQG S1/2/3 mk2
8/2013
Out of Production
SS penlights with choice of tint, clips and individualized engraving
Starry Light SA-22 BLF Ed
2/2014
Out of Production
NW emitter, better modes, faster PWM
Lumintop BLF SD10
10/2014
Out of Production
Current bump, better moonlight, several tint choices
BLF X6-SE
11/2014
Out of Production
EagleEye X6, XM-L2 on copper, increased current with custom modes
18sixfifty BLF 502B
3/2015
Probably still available. PM 18sixfifty for details.
UF 502B host with BLF label and various guts. I’ve linked the first thread of many.
Rey BLF Ti
6/2015
Out of Production
Custom Titanium 1x18350/18650 tube light host with trit slots.
Rey BLF X6 Ti
7/2015
Out of Production
Very limited production full titanium X6 host
BLF A6
8/2015
Available to the public now. (Goes in and out of stock often)
Manker A6, XP-L on copper, custom FET+1 driver with custom firmware
RoMiSen BLF UV Special
10/2015
Out of Production
365/400nm 2xUV in RoMiSen SS host
GBGB BLF-348
10/2015
Out of Production
1xAAA SS clicky penlight with Nichia 219b
M24 Sniper BLF-TE
11/2015
Out of Production
Maxtoch M24 with XP-L HI, current bump, better modes
ReyLight Copper AAA
11/2015
Out of Production
Lumintop Cu AAA tail clicky, Nichia 219b, custom 3-mode driver
LuckySun BLF D80-SE
12/2015
Out of Production
LuckySun D80 with current bump, better modes, XM-L2 on DTP copper
Kronos X6 & X5 Sets - Cu/SS or Al
1/2016
Sold out, but you may find the Astrolux version on Banggood.
Upgraded X6-SE in Cu/SS (or Al) + Brand New X5 in Cu (or Al)
Astrolux A01
3/2016
Custom colors, including copper with a blf logo and modified tail
ReyLight Titanium AAA
3/2016
Lumintop Ti AAA clicky, Nichia 219b, custom 3-mode driver, custom engraving
Old-Lumen Lights Triple 50
5/2016
Out of Production
Short run custom 3x XHP50 on FET in a 2D Maglite host.
ReyLight Pineapple & Ti Lan
10/2016
A solid brass or ti AA/14500 light with high-CRI 219c and moonlight.
VOB Ultimate EDC
7/2017
Out of Production
USA-made solid brass, 14500 triple edc light.
BLF Q8
9/2017
A BLF worthy SRK-style monster flooder
BLF GT
12/2017
Monster XHP35 HI thrower with 120mm reflector, 8x18650. 1+MCD throw!
BLF GT70
9/2018
The Giggle Monster. An XHP-70.2 version of the GT. 7500 lm, 1500 m throw.
Sofirn AAA Yuji
11/2018
Out of Production
A bombproof AAA twisty with Very-HCri Yuji 5mm LED.
Sofirn C01S
3/2019
Out of Production
A small AAA twisty with SST20, L-H driver and clear ano.
BLF/TLF FW3A
4/2019
Available now.
A small, elegant, edc-style triple light with tail e-switch.
WildTrail (LuckySun) BLF-D80 v2
8/2019
Available now.
New D80 with several improvements, FET-based driver, emitter choices and a no-ano option.
BLF LT1
10/2019
Available now.
SRK-based lantern with long runtime, variable tint mixing, great cri, reduced glare, etc.
BLF UC4 Charger
WIP
In the development phase. Taking input.
A top end, fully programmable charger with all the bells ’n whistles.
BLF Edition SP10S
WIP
Upgraded Sofirn SP10S with Anduril and ano options.
BLF/WildTrail Tactical
WIP
18650/21700 dual-switch “tactical” flashlight with sophisticated firmware.
BLF LT1m
WIP
A micro version of the LT1 lantern.
Always check each light’s thread for the latest status or info!
A few explanations:
  • The name of the light links to the build thread or other discussion thread about the light. Full details about the build can be found there, including ordering information.
  • The date field lists the actual release date of the light. This is the time when the light actually became available to purchase. In most cases there were many months of work leading up to that time. All those details can be found in the build threads, if you’re curious. There are two “special” dates used:
    • SOON: These are projects that have a finished design, have met their minimum purchase commitments, and have moved into production. Barring some unforeseen complication, these lights are going to be made. Your chance to get your hands on one of these lights may be rapidly slipping away.
    • WIP: These are projects that are still in the design phase and/or are still trying to fill their minimum purchase commitments, but they’re active projects that look promising. Drop by these threads and see if you can help out. They need you!
Again, please let me know if see something that needs correcting or adding. Thanks in advance!
Updated through comment #142
Hey emarkd :bigsmile:
Good idea putting this list together, Will be a useful tool i imagine. Just one thing, the Romisen link you’ve got up goes to the A6 thread. Here’s the correct url for the Romisen. (gb=closed) Only 50 lights were delivered and sent out, *BLF special* Romisen 365/400nm 2xUV SSflashlight, gb with Tinywind
Cheers,
-KK :face_with_monocle:
I’ve got a couple from years ago. Mr.lite made us a BLF edition found here:
and tank007 made an e07 BLF special edition found here:
As far as I know, these were the ‘original’ special editions. As you can see from the years of the threads, they are classics, but they hold a spot in my heart. Times were simpler back then it seems.
Reference: GB Interest ///OFFICIALLY CLOSED 11/8 @ 9pm CST/Maxtoch M24 Sniper with XP-L HI /// 250K lux @ 4.3 Amps!!!
GB Maxtoch M24 Sniper. Still undecided on whether this will be “Special Edition” or “Thrower Edition”.
BLF Trustfire A8
BLF Thrunite Saber 1A
Hey Kane, thanks for the catch! Copy/paste fail.
Awesome, thanks! Great BLF history from way before my time.
Yeah, I can’t believe I forgot that one last night. Thanks!
Nice, thanks!
I’ve got my original updated with all these new lights. Thanks everyone for helping me with this. Even if it doesn’t go anywhere else, its helping me learn some of the history around here, and I really appreciate it.
Excellent thread, thanks for this!
Rey BLF-Ti
Rey X6 Ti
BLF lumintop SD10
Lumintop BLF SD10
I think that there was the original/earlier SD10 and now Rey is working on the “new” SD10 GB:
I missed the 1st one but am waiting for the new one…
Great thread! Watching with interest.
Great shopping list you have there :smiley:
Impressive list of lights! :exmark:
Thanks everyone, I appreciate the help and the support. I’ll get my original post edited with the extra lights this afternoon.
Yeah, I’d love to have a full set. I’m sure there are old-timers around here who do. I’ve only got one BLF light at the moment, the original X6-SE, but I’m on the list for all of the ongoing group buys and I’m in an ongoing negotiation with someone for another BLF light. So yeah, if anyone has any of these older BLF lights and wants to part with them, I may be interested. :slight_smile:
Was there a Starry Light or somesuch?
ah yes, good memory!
There as also the trustfire mini 1, mini 2, and possibly mini 3. Here were put together by Rey before and after the TF A8
There was also a CNQG 2*AAA stainless steel penlight and single AAA stainless penlights.
I have some mini 01’s and forgot about them.
Custom info on the BLF Trustfire mini-01: 1000Hz pwm, mode order l-m-h 2%-25%-100%
