In case you didn't see them, I posted some comparison beamshots in "My Bike Light Thread" post #46 & $47. I modded a Nitefighter BT40S that came stock with NW XP-G2's (which I had compared tint with other lights and found to be 4C or very very close) over to Nichia 219C's. I then compared these Nichia's to my favorite XM-L2 5B1 tint.
(So I did get around to using them without letting them sit on my workbench for months!)
I was able to get in on RMM’s recent 219C special offer, with three 219Cs mounted on a Noctigon along with Carclo optics.
My order from RMM also included the MTN-17DD FET driver loaded with Toykeeper’s excellent firmware / UI, the Convoy S2 host, the S2 copper spacer/heatsink, and Samsung INR18650-30Q battery.
Last weekend, I assembled the above S2 with the triple nichia 219C noctigon, the S2 copper heatsink/spacer, and did a switch and spring bypass (with 18 gauge wire) on the S2’s clicky. The MTN 17DD driver already had a spring bypass done by Richard with copper braid.
I kept the stock 17DD driver wires provided by Richard to attach the driver to the nichia LEDs on the noctigon. I think these are 22 gauge wires, and I am contemplating replacing these wires with something heavier, given that the projected amount of current draw with this setup (over 10 amps?) is in excess of 22 gauge wire’s rated maximum current carrying capacity. I’d like to use 18 gauge wires to attach the driver to the LEDs, but these may be too thick to solder onto the driver’s + and - pads. Additionally, the thinner 22 gauge wire, however, may be acting as a resistive “safety valve” to limit current to the nichias, and it may be better to retain the smaller gauge wires provided they don’t eventually act like fuses when running on turbo.
So far, I have run this light configuration on turbo for no longer than 15~20 seconds or so - I’m not yet brave enough to run it on turbo much longer. . I’ve done this quite a few times over the last 3 days, and the 219Cs seem to be taking it just fine so far.
It’s output is truly stunning on turbo!
To my eyes, I don’t see any tint anomalies when running on turbo, just that pleasant nichia whiteness.
I don’t have a way of measuring the light output, but doing a ceiling bounce with the above S2 configuration running on turbo lights up an entire bedroom! I have a Trustfire X100 (9 LEDs) that appears, to my eyes, to have similar ceiling bounce performance. The x100 light is supposed to emit roughly 3000 OTF Lumens.
On turbo, the S2 copper spacer/heat sink and S2 flashlight body get warm pretty fast (in about 7 seconds or so), but the heat sink/spacer appears to be doing a good job at removing what must be significant amounts of heat density. This seems to help keep the nichias from burning up (at least for short turbo bursts for roughly 15 seconds).
The 30Q battery seems to be one hell of cell when coupled with the 17DD+FET driver!
I don’t think I have a way to measure the amount of current that must be flowing in the setup. My meter has a 10 amp maximum capacity. I hope to investigate means to measure the current in this setup a bit more this weekend. Don’t know that I’ll be successful, but will post any findings or observations.
I just tested this with a KeepPower 18350 in my S2+ with one of RMM’s triple 219C’s from the recent sale.
I used a clamp on ammeter and some 12ga stranded copper (5 inches long) from negative on battery to side of tube.
I got 11.2 A initially, from an 18350…
I held it for about 10 seconds until it got too hot, it was down to 10.7 A
Holy smokes these 219C’s are awesome for pulling amps… That is about 3.5A for each emitter and according to Djozz’s chart in the OP, about 3000 LED lumen.
As for the heat, ten seconds was all I could handle holding it in one hand. I will have to adjust the firmware. With the XP-G2 S4 2B triple prior, I had it start to step down at 15 seconds, taking about 35 more seconds to ramp down to 50%…. That will not do for these little heat generators.
Yes, it will never be a pocket-rocket but it is possible. You will have to remove some resitances in your flashlight, mainly bypassing the spring(s), then the 219C should run at up to 1.5A direct drive on a LiFePo. I like LiFePo's because the chemistry is relatively safe. :-)
I looked at HKJ's test of a 14500 LiFePo cell and compared the currents/voltages with the 219C current/voltage and that comes down to a bit over 1.5A, ignoring any resistances in the system. A 18650 size LiFePo cell should do a bit better.
Well this is interesting, I had not considered that LiFePO4 cells would be good for DD until reading this. Would be interesting in the Noctigon Meteor M43 that Richard had with the 219C… Plenty of light, pretty cool for the amount of light being put out and safer chemistry…
An old Illumina Ti LED/MCPCB upgrade mod to a 219C 4000K (Cutter):
Stock light did 241 lumens @30secs, 219C/10mm SinkPAD does 296 @30 secs in a much better tint and better beam pattern as well. Both tests were done on a EFEST 10440.
Yea, was think'n bout replacing the driver for sure. Actually I got another one I want to mod as well - might do with the 5000K from Richard. Since it's a contact board/driver design, should be perfect for our 2 sided FET based 10mm driver... Hhhmmm... I know I got a couple.
Also need to do something better with that alignment piece, and the contact board is not sitting down flat, so it's a little more flaky switching modes that it used to be. I left the tiny stock LED wires - might be ok with the low Vf of the 219C, but definitely could get more power and heat for sure out of a FET with heavier wires. Didn't have much time of course.
I am working on a Olight I3S & that Illumina Ti led holder & the pill looks identical, i wonder if Olight is the OEM for the Illumina Ti.
The biggest difference seem to be Olight used lots of threadlock + glued the driver well in place unfortunately, i have gotten the threadlock lose but haven’t attacked the glued in driver yet i want to test an XP-L on it before i have to probably destroy it to get it out
Good point about contact board & the 2 sided 10mm fet driver, the pill is very deep for something so small, i will have to see if the I3S also has that setup also, the pill should be deep enough for it anyway.
If you are going to test an 10mm fet driver in the Ti wouldn’t the alu pill very quick get overheated due to the bad heatsinking of Ti?
I guess you could use an very short turbo timer to save it destroying it self though.
I hope you try it, it is always interesting to see more hotrodded 10440 lights pushed to the edge
Did test the 219c 5k. The tint isn't very nice (not if you are used to the A or B series) Too flat (dull) and has some greenish/blue hue (that is the reason why it slightly outperform the 219b in term of lumens... "less red" emitted)
I’m not sure where to ask this… Has anyone done testing on the 219B V1? The tint is very nice in my BLF-348, and I remember having a talk about it’s Vf being the same as as the 219c, but I’m wondering about lumens and how much current they can take…
Finally got around to installing some 219Cs last night.
I installed two in small 1x14500 zoomies, and 3 more inside my Jetbeam TCR-01 triple. Previously all 3 lights had been running with Nichia 219B.
My impression: Not bad at all! All 3 lights are producing considerably more lumens than before. The new emitters aren’t high-CRI like the 219Bs I previously had installed, but they more than make up for it with the increased output. My TCR-01 triple with triple 219C and stock driver (not sure the about… my guess is maybe 2 amps), is producing a beam that is fairly close in brightness to a similar light with triple 219B and FET driver (both on IMR 18350).
I also like the low forward voltage on these emitters. Hopefully they will keep their max output in these lights longer than on the previous emitters or XPL HI. I’ve previously tried XPL HI in small 1x14500 zoomies at 3 amps. Output looks great initially, but they start to step down pretty fast as the battery depletes.
No, there is no test, many still confuse them with 219B (discontinued) and they will forever I assume since Nichia's specifications are still vastly not comprehended by most people. Yes undoubtedly you can check the datasheets and see the Vf is the same, but you know they will come in different Vfs bins anyway (3 bins: L1 L2 M1 , lower to higher voltage), so far the 219C is not disclosed as to what Vf is, by none of the sellers, so I would like to see a L2 vs L2 comaparison not something like M1 vs L1.
