Jacob is out of stock everywhere now...
Enjoy in your last one :)
Are my readings in line with what others got? I’ve read about ± 130-150kcd. But 240kcd!?
Yes they should be ok. This is new XP-G2 and dd driver. Regular one should do about 200kcd, and some guys got even lower than that. Secret is with centering.
100% correct… reflector height & centering of the LED… was the most difficult part for sure.
I was very sad when Jacob disappear from market. I just can't believe that... Bestseller flashlight out of stock? Crazy...
I would like to know which factory manufactures Jacob. I would wrote them a mail.
Or, this... new Convoy L2
That is incredible! What is the measured current at tail?
Shrick,
I was not aware of that thread. I signed in for Jacob's return on the market.
Will measure tonight…
My biggest concern with the light is the extremely ringy beam pattern. I can possibly still live with the low quality and do some ‘upgrades’ around this, like the switch, AR lens, orings etc. Should they decide to make a comeback, I hope they do it with at least an upgraded aluminium reflector. As I realized above, there is LOTS of potential in this reflector, so the design seems good, but the quality of it is just bad.
Sorry but we don't share similar opinion.
I'll answer like this(as i did in other thread):
I would like to see it in old format. Why?
- That would lower production cost so we could have it at 10$ again,
- Plastic reflector can handle any magnum rifle recoil without any issues
About A60 ringy beam haters... Yes it really has ringy beam but only if you hunt white walls
Do you guys actually use flashlight or you are watching the beam on white wall? I don't care about ringy beam because if you field use this you'll not notice a single ring in beam just pure and unbeatable throw for size of flashlight.
Some even more premium SMO reflector throwers(solarforce, lumapower) has similar ringy beam as Jacob so I don't see any issue with that.
I just acquired a NOS A60 from a member here.
Yes it has rings. Anyone who can’t get past that, probably isn’t married.
A pun and several levels of thought there
I plan on putting a Nichia 219C in mine. What an awesome emitter!
I was sleeping during the ME promotion, luckily another member Had my back and procured some for me.
I believe there’s definitely still a need for a better quality light, in the same form factor as the A60. Why is there so little to choose from in this ‘A60’ size? The size/performance ratio of the A60 is exceptional… I mean, almost 1000m in a light this size - Crazy. The light is really compact. Most of its ‘competitors’ are bigger sized lights e.g. M2X-UT (Single Cell). Again, I’ve realized that the size/performance ratio of the A60 is special.
I would add the best price/size/performance ratio in category of reflector flashlights.
But best kcd performers are aspherical flashlights in size/performance. Even when you compare same kcd values of reflector vs aspheric, aspheric will always visually out throw reflector.
Very nice work!
Nice work! I felt he same way as you did when I first got mine and completely overhauled mine too. Did you get the focus right the first time or did you have to sand down your spacer at all?
**EDIT - nevermind…I missed the part where you said you sanded it down.
4.7 amps on a fresh Efest Purple.
What flashlight is this? I want one! (Sorry to thread jack, my flashlight excitement gets the best of me sometimes)
FWIW, my A60 w/ a de-domed XM-L2 produced 157Kcd. A lot more usable light than the stock pencil beam.
Missed out on getting more so would def like the A60 to be resurrected again…
