Well, the rules are that you cannot pack powerbanks into your checked-in luggage. But you can have them in carry-on. We now have to separate them from our carry-on at security inspection points so they can be manually verified as OK.
I guess their use is banned because of the risk of over heating and perhaps catching fire, or just the chance of emitting some nasty fumes. It is OK for a Boeing 787 to use Li batteries in flight, but not for passengers
The “fast charge” cables should be just normal cables (section-wise) with D+ and D- pins shorted. I got a bunch of them and they were weak as hell, the section of the cable was about 0.1mm and they fell apart in no time.
It’s one of my favorite lights. Seems very well built and very easy to mod. I put 3A Qlite drivers, better LEDs on Noctigons, and coated lenses in mine.
Thinking of ordering the second one. Is there anything that stands out as shoddy on the PCB?
Maybe I’ve missed a fully enclosed 1x18650 power bank that’s already been reviewed as good?
(I would get the Miller ML-102 but it doesn’t fully enclose the battery)
Wondering, if it tweaks your curiousity, whether this use of USB power makes any sense.
8 watts seems a lot. I wondered if there’s any power source compatible with this much load.
Draws at least 1.6A, so must use a 2A USB source. The cable/connector may not coded properly to tell the USB source to drive that current level, but reviews seem to imply that it work. A lot of USB sources will only drive 500 mA or 1A unless the device cable is properly coded. Lots of computer USB ports are limited to 500 mA or 1A regardless of the cable coding.
8W is not much. You won’t be soldering heavy wires/big parts with it. Probably OK for smaller components.
