If you’re using this for testing as you say then this may just be the one you want.
It does use 17mm driver, 16mm LED base, and better still you can remove the zoom and reinsert the pill only - bare LED straightaway accessible for whatever tests you need to do.
I received this flashlight today and it doesnt work with any of the 3 batteries I have. So I opened it up and its got a Cree xpe looks genuine. Of course nowhere near 2500 lumens by a long shot even if it was an xml. Lol. Where do they get these numbers? So I emailed the seller amd he can refund or send me another. I asked if he can send me a different light of equal value. The side button feels cheesy. Id rather have a standard driver so I picked an 18650 zoomie. I hope he can send me that different light.
matg, which light did you buy? The 14500 one? Mind you it listed as XMT - LOL.
If it really didn’t work with 14500 as listed then I’d recommend getting money back and then repurchase a different light. One of the ebay Do’s (at least mine, anyway). Both seller and buyer benefit from this - seller gets rating point, buyer gets renewed protection with the new purchase.
I’m not talking about your seller here, just FYI in my experience if the seller REALLY insist on sending a new one instead of refund then he/she does not intend to send anything.
Yes i bought the 14500 one woth the side switch. Doesnt turn on. I only had time to breifly check the wiring and everything looks good just no light.
I got a message back from the seller and he will send me the other light I wanted. Its an 18650 zoomie light with an xml at 20 million lumens. Cant go wrong with that Lol. I would be happy if it actually has an official cree led in it.
actually solid pill with shelf + two holes for pos+ and neg- leads on a 16mm star not 20 without flattening the shelf off the top. plenty of threading on it to make good contact with the body. glass lens. reverse clicky tailcap threaded most of the way to the back. came out of proper focus. used shims and brought it to near perfection. good little car light for $5.33 plus time tinkering with it.
The weirdest thing is it came from china in like 5 days. WTMF?
That one at 2.94 is in the mail for me after the other one didnt work. Turns out that light with the side switch had a bad emitter. I swapped it out for a q5 I had laying around and it is a decent light. For some reason it had a charging port with no included charger. I have my own charger thank you. Lol
