The season of candlelights and lanterns is coming, I felt the need of a flashlight which has a artificial candle flickering.
A short google search shows a lot of guys already did this so less work for me
I stole the project from github and tried it, worked like I wanted it to be so I changed it to use the standard nanjg outputpin and flashed it on a nanjg ak47.
Here is the code I used: Dropbox - candleflicker.rar - Simplify your life
I just flashed it on a standard nanjg with standard fuses FD and 75. It runs on 9Mz which is probably to fast for the small voltage but it seems to work well I will try it out when I find more time. I also have the compiled hex in the project folder so you simply can flash it like every other firmware. This has no modes or battery protection or anything else it is just a in my eyes good working flickering code. For indoor use it is a bit nervous to look at the āflameā but in a lantern/box it works like a candle in the wind
I just put it in a ultrafire S6 which I got long ago but never used because time has changed in budgethostqualityā¦
I used a XML2 S6 so it has nice CRI
current consumption maxes out at a bit more than 1A and it gives around 100-200lm which makes it a nice and bright candle with hopefully long runtime.
I just wanted to share this before I shutdown my computer and close all tabs, maybe someone finds it helpfulā¦
Looks interesting. Iād like to include it in my collection (and it also reminds me I should add my lightning storm firmware).
Why is the clock doubled? Doesnāt seem like thereās anything which requires the extra computing power. Itās not a problem; just requires a different avrdude command line than most other firmwares.
Obviously youāre using AVR so it makes it more doable by the masses here, plus you donāt need any custom hardware but did you see my LED candle?
It can run an individual LED if you dont have spare $15 XML-Cās to waste.
Iām also using this code in a house light Iām building my wife for her bday. The lower globe will allow any color on solid or a continuous spectrum fade, the top will be either fire / candle mode (red/green flicker) or white.
I used my candle light today for my pumpkin lantern, works like intended. I always smile when I see some lanterns powered with the normal ledcandles or even real candles.
My pumpkin glows entirely, the structures of the skin gives it a cool look.
