In-depth vid review: Manker Quinlan T01 Compact Thrower (XP-L HI | 1 x AA / 14500)
Thanks!
TurboBB,
If you programmed the modes you wanted in pro mode, if you switch back to gerneral mode; will the programmed mode carry over to the general mode?
@dG2K2 - Yes and vice versa.
G'Day turboBB,
Greatly enjoyed review with a lot of Valuable info.
Thank you Very Much,
George
Edit:
Pity about the battery length limitation
OMG is this review a lot of data!
@keengeorge - You're welcome! I've suggested to Manker to make tube ~1-2mm longer to account for longer batteries.
@Ronin42 - but we like that don't we? I'm a data geek at heart... ^_^
I’ve seen it for $70 or so on amazon and ebay…… it’s right up there with the zebralight, so I’ll stick with a zebra until I can get this for $35 or so.
Any price comments?
I can’t believe I ate the whole thing. I mean I can’t believe I watched the whole thing! A 47 min light review. Must have been something in there that kept my interest. Well done! Great light. Not sure why I haven’t purchased one yet. This video alone is a strong selling point. Yes, it’s nice looking, great UI/programmable, king of the AA lights, etc…… but ultimately just another light that does what my other 60+ already do - shine light. I suppose if I got rid of my computer/internet I wouldn’t buy any more lights :bigsmile:
this one is beckoning strongly.
thanks for an amazing review turboBB. That’s one NICE test room you have there!
@wishiwereaskibum - in case you didn't see M4D M4X's thread, apparently he's able to get these at a pretty decent price (I'm not related to him nor do I make any referrals off this, just passing along as PSA).
@saypat - Thx! It's really important that I'm able to reproduce the results consistently so I'm very happy I have this space in the attic for that. I'll be putting anno's in my vid's from now for easier navigation between the sections.
From the figure but I didn’t see 500 lm for one hour with one Emerlop AA. The figure shows it lasted less than 30 minutes from 500 lm to 200 lm. (The dark purple curve). This is more reasonable by simple math.
Considering the flashlight loss and according to XP-L Hi spec., it probably take 1.5A at 3v. Assume the average voltage of the Enerlop is 1.25v, the time it can last is equal to (1.25*2.5/1.5/3) x efficiency = 0.694 x efficiency (hours). Lasting 0.5 hours corresponds to efficiency of 72%. I think it is pretty good for such 1.2 to 3.x v converter.
Did I missed anything?
@twinclouds - the mfg quote of 1hr is for the non- Constant Current run (the dark purple curve with a step down). I my reply to MK, I missed the "no step down" part of his comment and only focused on the sustained part.
I see. That makes sense to me now. Thanks for your clarification.
Another question I want to ask is: From your experience, how accurate are the Cree’s specs? As discussed previously, it appears to me that XP-L V5 is not as bright as XM-L2 U3, but it was list slightly higher than the latter in the spec. The bin number V5 and U3 are misleading also.
Sorry I've not specifically tested any lights with the two emitters you mentioned (nor am I in the habit of testing bare emitters) but based on the lights I've tested, I'd say they're reasonably accurate (of course take this with grain of salt since I don't have a professional IS but I'm reasonably confident with consistency of my PVC LMD). I think we need to keep in mind that Cree's specs are under optimal conditions (think stable power supply with sufficient heat sinking) and under those scenarios and based on what I've see of the tests some folks have conducted here, I've no reason to doubt the accuracy of their bare emitter claims.
Hello great review, I have a question about the programmable mode.
When your on the programmable side does it remember (memory) the blinky section ?
Can I be in programmed Medium and double click to the Turbo (without step down). And the double click back to Level 2 ???
Chad
Thx Chad and no, it will not memorize any of the blinkies or the CC Turbo mode.
Still sounds like a great little AA light. I was hoping I could jump back and forth without having to cycle other modes.
BG has black and white, both in US warehouse. I cant decide on color……
I think they both look great but as per my feedback to them, it'd be neat if they came out with contrasting color variations like Olight's S1 line. Given most of my lights are Black, I do like this particular raw color.
Would be great if Manker made a AA extension tube for 2 AA’s
Have you tested the current drawn from NiMh AA to produce 500 lm? If the LED takes current of 1.5A at 3v, which is necessary to produce 500lm according to the spec, the current drawn from the AA should be 1.5A*3V/1.25V/efficiency. Assuming efficiency is equal to 0.7, the current will be >5A. Their boost driver must be very powerful and efficient. I am wondering if it is possible to get such a driver anywhere on the market.
@twinclouds - Using the standard leads of my Fluke 289, current was ~2A with Eneloop XX; of course, there can be a bit of resistance like this. It'd likely be higher with thicker wires.
