Great!
Dang, missed this. Another great job PD! I gotta order some of each.
I got it built and only had a couple of solder bridges to fix, that went well.
Sorry about the quality of this pic...
I used a 560 ohm bleeder and it works with a lighted tailcap. R1 is 22k, that was all I had on hand and R2 is a 4.7k. The caps are the recommended ones for other FET based drivers.
But, now I have other problems. I flashed it with BLF-A6 firmware. I had to raise ML a little, but it is working fine now. I do not seem to have the highest mode, all of the others seem to be there. I also cannot go backwards in the modes. Any ideas? I was able to get into config mode and set it to 7 modes and that works, but no highest output level. I have flashed it with TK's battcheck and it will not run. So, I looked at the code and it looked to me like I needed to swap #define STAR2_PIN PB0 and #define PWM_PIN PB1 for output to the fet pwm channel. This requires me to recompile the code, and it spits out the following errors:
E:\AVRdude\BLF-A6\GccApplication1\GccApplication1\battcheck.c(48,10): error: expected '=', ',', ';', 'asm' or '__attribute__' before 'need'
Hey, you need to define ATTINY.
In file included from c:\program files (x86)\atmel\studio\7.0\toolchain\avr8\avr8-gnu-toolchain\lib\gcc\avr\4.9.2\include\stdint.h:9:0,
from c:\program files (x86)\atmel\studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\inttypes.h:37,
from c:\program files (x86)\atmel\studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\util\delay_basic.h:37,
from .././battcheck.c:66:
c:\program files (x86)\atmel\studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\stdint.h(159,9): error: unknown type name 'int8_t'
typedef int8_t int_least8_t;
c:\program files (x86)\atmel\studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\stdint.h(213,9): error: unknown type name 'int8_t'
typedef int8_t int_fast8_t;
.././battcheck.c: In function '_delay_ms':
E:\AVRdude\BLF-A6\GccApplication1\GccApplication1\battcheck.c(71,23): error: 'DELAY_TWEAK' undeclared (first use in this function)
_delay_loop_2(DELAY_TWEAK);
E:\AVRdude\BLF-A6\GccApplication1\GccApplication1\battcheck.c(71,23): info: each undeclared identifier is reported only once for each function it appears in
make: *** [battcheck.o] Error 1
Done executing task "RunCompilerTask" -- FAILED.
Done building target "CoreBuild" in project "battcheckM.cproj" -- FAILED.
Done building project "battcheckM.cproj" -- FAILED.
Build FAILED.
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
So, until I can get this compiled I am stuck on the voltage testing. I did test battcheck.hex, that I downloaded, on a 105c and it worked. The numbers were fairly high, but I have no point of reference.
Frankly that all sounds firmware related, so you would probably get more help in the firmware repository thread. FW is not really in my wheelhouse. I will say that I’ve also had some issues with the newest versions of TK’s stuff that were made to be interchangeable for the attiny 13a and 25.
Is it just an illusion or is most of the ground ring missing on top?
You need to define "ATTINY 13 "I believe. It's look'n for that or ATTTINY 25. TK set that up in the header file, I think it's in tk-attiny.h
Put:
#define ATTINY 13
somewhere before the header files are included. I'm using her new ltaets header files in my latest 45/85 e-switch code.
I flashed the following BLF-A6 modes…
// PWM levels for the big circuit (FET or Nx7135)
#define MODESNx1 0,0,0,0,56,137,255
// PWM levels for the small circuit (1x7135)
#define MODES1x1 8,20,110,255,0,0,0
And I have 4 low modes and 0 high modes!
I am going to try to add solder to the FET pins in case they are not good.
I did find the solder joint problem, the PWM pin for the FET was not well soldered. Now I get both the 7135 channel and the FET channel.
Pdog, I may have to move to the firmware thread… Just was not sure about the lack of reverse thing. I thought the ground ring was quite thin as well, but it does work when mounted in a light! Right now the off time mode save is advancing 1 mode with each test and I can’t back up. Really frustrating!
I did get battcheck running, got some really odd numbers but did plug them in. Mine were higher than any other sets of files, I was using a power supply. With the unit on battery, it start stepping down almost immediately. Did not you have a problem where the numbers were off when using a power supply as well?
Tom E:
It is defined in the main BLF.c file as the tiny13.
Well your reversing and mode switching sound like the OTC isn’t draining. I’d try it without the lighted tailcap first. If it still behaves the same, try swapping out the OTC for a new one (and be careful how long the heat is on the cap)
My eyes are just shot for today! Not sure I could pull it off right now if I felt like it. I have tried it with both types of tail caps, no change. Will the hot air solder let go with hot air again and still leave usable pads?
BTW, the hole through the middle is just genius!
Matt
Forget my earlier post, I see the problem. You have the parts sideways. I should have marked that on the PCB. The way you have it, the BR effectively doesn’t exist, and the cap is connected to batt+ instead of batt-. And yes, you can heat it back up with the hot air and move stuff around. Did you have any problem with clearance around the small ground ring?
What FET is this this? I would like read about it. I didn’t see a parts list.
It’s basically the same parts list as any of the other fet drivers on BLF
MCU: Attiny 13a/25 or 45/85 for 20/22mm
R1: 19.1k or 22k
R2: 4.7k
C1: 10uf
OTC: 1uf
FET: LFPAK56 footprint
Thanks for the quick reply. With that I was able to find some and datasheets.
With a standard tailcap all works as expected. I do need to adjust the medium press to be shorter but it works and memory works. With a lighted tail cap memory is always previous mode! I have about 2.3k of resistors on the tailcap board, 2 5.6k resistors and a 560 on the driver. It appears that the OTC is not discharging. I assume that I may need to raise the value of the bleed resistor?
I am so close!
Matt
I’ve never tried to dial in the medium press with a lighted tailcap. It actually sounds like it’s discharging the OTC faster than expected. Try running TK’s offtime cap FW to get the values. Here
With the light tailcap the only thing not working reasonably well is that fact that mode memory always decreases 1 mode. I can go forward and backwards but just not remember the correct final mode! I do not understand the process for last mode memory. If what I understand is correct, the OTC must totally discharge to store the last mode. It seems to my simple mind that it never discharges while off and therefore considers the off time as a medium press. So, I think I have to get it to discharge more. But, I am not sure if a larger or smaller bleeder will cause that to happen or larger or smaller resistor in the tail cap. Memory works on a standard tail cap.
I see that guys have it working on the A6, maybe someone will chime in with their resistor values.
Gotta hit the rack, will work more on this one. I really like the idea.
Matt
BTW, the center hole is great. It is always hard for me to get the conductor soldered in on the center of the pad.
i see what you’re saying now. Maybe try posting it in the lighted tailcap thread so the others see it.
Is there anything you would have added to this project if you had more space?
Hmm… I was able to fit just about everything on the 20mm. Once development gets a little further on FW for the new mcu’s I’ll probably do some with 3 pwm channels.
I was thinking about board stacking for more space. I have not seen it done before, I’m not sure why.
