Test/Review of Keeppower 14500 840mAh (Black) 2015
Official specifications:
  • Capacity min.: 800mAh
  • Capacity typ.: 840mAh
  • Nominal voltage: 3.70V
  • Charge voltage: 4.20+/-0.05V
  • Standard discharge cut-off voltage: 2.50V
  • Standard charge current: 500mA
  • Charge termination current: 20mA
  • Standard discharge current: 800mA
  • Max. continuous discharge current: 4A
Keeppowers high quality 14500 battery with protection.
The cells have good capacity and decent current capability, but performance is a bit lower than last year. I wonder why (Maybe the cells has been in storage for some time)?
Conclusion
It is good cells and one of the best 14500 on the market.
Notes and links
The batteries was supplied by Keeppower for review.
Comparison to other LiIon batteries
Thanks hkj. Another great. and more importantly, trustworthy review! :slight_smile:
Thank you very much for the review!
Thanks, HKJ!
Well, why do they advertise this as 840mAh battery, when in real life you couldnt get even 800mAh out of it?
Wheres the catch, much lower discharge voltage when testing in their factory?
Mostly to avoid confusion with their cheap 14500 battery that has 800mAh.
Thanks for the review HKJ
hum looks good….My ZL 14500 barely is able to hold the 500 lumens from my H52W. It keeps stepping down to about 280 lumens……Even after being full charged.
Time for some new batteries :slight_smile:
Thanks for the review HKJ!
Edit: From what vendor did you buy those cells?
As it says in the review: The batteries was supplied by Keeppower for review.
rofl. I read everything except that last line. :stupid:
