Why are you assuming they would think you are scamming them?
Just ask politely for what you ordered and try as best you can to provide evidence that they send the wrong light to you.
Just my pessimistic personality I guess.
Be nice. Until it’s time to not be nice - Patrick Swayze
In this case it’s a good idea to just keep being nice until it’s resolved but depending on your level of dissatisfaction don’t let it go past the the paypal time limit and let them be not nice instead.
I was not able to use paypal, because the link did not work for what ever reason, so I had to just use my debit card.
I would want them to correct the issues. But then again 5a tint isn’t the end of the world. Take it outside once you get your new tube and check it out. The warmer tints are pretty sweet looking on natural scenes. You may really like it! I lucked out and every light I’ve ordered had worked but I couldn’t swap parts between my bare light and my anodized lights. Tail cap to deep.
Guys I’m looking at TIR lens. Don;t know if it will fit and I need help!
http://www.kaidomain.com/product/details.S020644
http://www.kaidomain.com/product/details.S021698
Do i need this? http://www.kaidomain.com/product/details.S020961
And another thing, why cant I open the bezel of my anodized A6 but I can on the bare Alu one?
Stripped lenses like those spread the beam sideways perpendicular to the lines.
Yeap! I wanna use it on my bike! I have the 15 degree TIR on the way alr
It might have been jammed/cross threaded. Haven’t heard of them being glued.
Maybe try warming the head+pill without the battery tube then ice the pill and quickly twist.
I started compiling some of your guy's advice into post #2 but (I'm guessing) because I started this thread with a simple post editor I can't go back and use the advanced when I go to edit it. Luckily I was able to save it as a word doc but I really wanted the text color option or something besides bullet points to get it organized. I'll figure it out somehow.....
Just use the Advanced Text Editor.
By clicking the Input format, located directly below the text box.
You can add color.
Change font types.
Change font size.
And highlight text.
And for really complex editing, do it on a word document, then cut & paste it into the Advanced Text Editor.
Hah! Thanks! I had gone into my account and changed it for topics and comments but I didn't realize you could change it with input format! I probably clicked that when I first started but didn't really want the advanced editor and then totally forgot it was there. I'm pretty new to forums......:) Thanks again!
FWIW, you can also just add some HTML and/or CSS to your posts when you need extra formatting. It works, and that’s what the advanced editor does. It also makes quoting easier for the rest of us, since it won’t have gratuitous symbols and <span style=“foo”> tags and redundant attributes everywhere getting in the way of the text.
For example, if I quote 1dash1’s post above… it looks like this:
My anodized A6 is bezel is also stuck, how do you mean heat the head+pill then ice the pill when the A6 has a shelf? :~
Heat the part with female threads and cool the part with the male threads. People have also wrapped in tape and gently used pliers. Or also used penetrating oil leaving the light on it's head so it doesn't get in the driver.
Ok, i got it now.
So if I run it on turbo a bunch of times and use some ice or something to cool the bezel it might help to loosen the threads.
The head and pill should unscrew from the battery tube as a unit if they’re stuck together so yes, just run it on turbo until it’s pretty warm but you can still grab it to unscrew then immediately stick the pill end on an ice cube for 5-10 seconds. A wide rubber band doubled over a few times on each piece might help with grip.
YEEEESSSS
I got i open, and it was so easy when I used all the tricks together.
First i heated it by running it in turbo a few times without holding it to get it extra hot, and while it ran I took some ice cubes and crushed them to a slush. Then i quickly removed the searingly hot head and put it head down in the ice slush for ~10 seconds. and then i used a silicon oven liner for extra grip and finally I got it open easy
The threads where super gritty, but now i can at least make this anodized BLF A6 in to the triple it was always meant to be.
Thanks guys
