Morally, you are right, but I would have dive into the excel- sheet again for that, it takes time, effort, and it is boring . This is a hobby, with in my case limited time, and I like it to be as much fun as I get away with.
Apart from that, the most interesting aspects of the graphs for me are the current/output behaviour and the output relative to other leds of the same wavelength , The absolute lumenvalues are of less interest, I think.
Maybe this will be interesting to someone.
I was preparing some red XP-E2 leds, dedoming them and I managed to rip of one bond wire from emitter, I tested it later and it still worked with one wire only but it was pulling only 1,9A out of ~2,4A that driver can deliver. Tested same driver on undamaged emitter and I got 2,4A as expected and anticipated. So, not all is lost if you screw up one bond wire on a emitter
It’s not really surprising that the green emitter falls off so much at higher drive currents. The thermal resistance for green is 15°C/W. Other colored emitters have a thermal resistance of 5-9°C. The unusual results is the plot for the red emitter…even though, red will typically have lower initial efficiency, with a thermal resistance of only 5°C/W, it should have pushed very well.
So much of the issue with determining the output of colored emitters (and varying tints of white emitters) is the spectral sensitivity of the light meter. Since green is near the center of the photopic luminous efficiency curve, it can be measured without much adjustment. Red and blue have to be factored heavily to determine come close to actual luminous flux using a CIE filtered meter.
I think here are some users, who can help me :)
A friend asked me a longer time ago to build him a green LED flashlight for hunting.
I combined a green Cree XP-E LED, alu base, dedomed it, use 3x 7135 AMC driver and a Convoy C8. Now he asked if I could modd it a little bit more. After this, I soldered another 7135 AMC on the driver and use a 4x 7135 driver with a UF T20. Both worked well.
He uses it for 20-25 minutes nonstop. Has anyone tested the older green XP-E with 1,75A or 2,1A for round about 25 minutes in one of these flashlights?
Has anyone gotten a photo red Xp-e2 yet? I have some, but no way to test other than a DMM really. If the data sheet shows them at 2.42vf and the regular red 2.65 @ 1000mah, what's your best guess on the vf and safe over-current for the photo red (on dtp copper)? Think it'll take 2.2ah like the old xp-e2 red did, but now with lower vf according to the datat sheet? Speculation welcome, or advice on how to test/get some data with minimal equipment and skill. Thanks!
Yes i have already one brinyte b158 with xp-e2 deep red made its very very good i drive it at 2.6 Amp no problems ,not become hot. now thats REAL red .
Also have a little trower made with dedome led.
If I can get them for a reasonable price, yes I will test them (although I have no comparison previous 660nm leds to check the output against).
Cutter always had high shipping rates, not sure about now. They are also listed at Mouser (not in stock yet either), perhaps that could be an option, together with other leds to make shipping reasonable.
Cutter has been traditionally high in shipping, for years, and don't see any recent change in that policy. They get no retailer savings from anyone, so have to pay full price and they are more set up for wholesale than retail.
Their high shipping costs are remarkably reasonable when you crank on the qty you order, as a reseller would order.
bro your right if you buy some qty we come in well on shipping, we arent kaioman or whoever that can send one led to the planet free shipping were just not that guy,
Cheers
Mark
O my god XPG3 red660 awesome i hope i can buy soon low shipping cost.
What is the approximate cost of shipping to Belgium / the Netherlands?
does anyone know that? 2/3 leds from cutter.
Just to confirm what Penumbra reported, I have a photo red xp-e2 on copper in a C8+ at 2.2A and its doing fine so far, even after letting it run on high for about 4 mins nonstop. I have no tools to measure, but it doesn’t seem to be damaged and puts out a lot of great, red light. Seems to handle the higher current.
Can’t wait for the photo red xp-g3.
Or fasttech ?
no i wait after your tests with the xpg3 660
ps: i have buy a spotlight on ebay for 16€ and wow wow what a light weight ,good handle and trow like a dream. i have the led dedome.
I have buy already 2 more of this on the way to me.
i gonne make one with xpe2 red 660 or maybe better xpg3 660 very usefull for nightspotting animals.
