The low weight is achieved by super skeletonized liners, as seen in this clip
skeleton work is shown from 16:51 in the clip
My only issue is that I don’t have a fitting hex-key to disassemble the knife
It is between my 2.5 and 3.0 mm keys, and I don’t want to tilt the screwdriver and mess things up
Great looking knife, found it at Knife Center, G10 is $41 CF is $46. If it’s true Sandvik steel it’s a terrific deal. The H6 model looks impressive as well.
I don’t like so much the “real” Endura, but I like this Ganzo! So strange…! :bigsmile:
I would like a Tenacious too!
But for me Ganzo will never do it, they do replica only for expensive models.
A Ganzo/tenacious will be a deal only for people like me in EU…(in Italy you can buy a Spyderco Tenacious for 60/70$!! very expensive for a budget knife )
Looks like those are the cheaper version with liner lock that are all over ali right now, the higher quality C81 (Paramilitary 2) with compression lock are very hard to find on ali anymore. I even read feedback from buyers that got the bait & switch, seller showed photos of the compression lock but sent out this cheap liner lock version instead.
The good version has the jumping on the thumb ramps, cheaper liner lock version has no jimping, smooth thumb ramp.
A few months back you could find the good ones but for some reason they’ve disappeared and now its flooded with that cheaper liner lock version. I did see one with the jimping but they don’t show the spot where top lock is located in any of the photos, looks like they’re hiding that area of the handle, so its a crap shoot as to what you’d get.
I bought several of the good ones a few months ago before they all disappeared. I paid around $18.00 each and they’re really excellent quality.
Here’s one of the ones I got, an all black one with scalloped G10 scales (listing still up but shows “no longer available”):
I did find some of the good ones on flea bay recently and ordered one, so we’ll see when it arrives.
EDIT: I found a few of the good ones on Ali, (they’re hiding the Compression lock in the photos) But I verify they have it from Buyers posted photos in the feedback. Also ordered.
+1, The Bondhus are excellent, most of the allen/torx sets in the stores nowdays are really crap, poor fit, soft metal, there’s some real junk out there. The Bondhus are high quality, Made in USA. I use them for work. I’m getting this set of shorty size for my knives with torx (star):
You can buy the combined metric and standard Eklind ball hex wrench sets from Enco for about $10-15 for both. Eklind Allen wrenches have been very good for me, rarely rounding off unless they’ve been used a LOT.
For torx wrenches I highly recommend the Wiha precision torx drivers. I bought my set from Amazon.
The three sets should be enough to take apart just about any knife.
Edited to add that I have used Bondhaus hex keys, they’re very comparable to the Eklind, but not enough better to justify the higher price.
I ended up buying
table(table#posts).
|Bondhus 31732 Set of 8 Star L-wrenches
Short Length
sizes T6-T25 |Bondhus 20199 Balldriver L-Wrench Double Pack
10999 (1.5-10mm)
10937 (0.050-3/8-Inch) |
Thanks for the info beam0. I wonder if Spyderco put some pressure on, and that’s why the compression lock models are hard to find. Unlikely, but just a thought.
Thanks KKW, I checked them out, the Eklind hex wrenches look good too, but the Whia torx set at nearly $70 on amazon is way over my budget, the Bondhaus torx set I linked is only about $11.
I thought that too. Because they are a true “counterfeit” I compared it to a real one and its pretty much spot on. Either that or the cheaper version sells a lot better.
I like Spyderco’s top lock/compression lock, but I’m undecided if its better than a liner lock. It seems like the compression lock on these was designed for lefty’s. To unlock I have to bring my thumb up over the top, for right hander’s like me I think it would be better with the cutout on the left side of the knife?
My new preferred opening method on these; the “Spyder Drop” 8) :
I like the the Axis lock on the SpyderGanz, I wish they would have did the Para2 clones with the nice thumb ramp & choil jimping .
I also like the “Arc Lock” on some of the the SOG knives, its real smooth and the stud is only on one side.
