I am starting to believe that they were meant to come out for the Black Friday event and this store jumped the gun. My favorite shopping day of the year!
Now back to drill bits, I am on a roll this morning.
Lately I have had very bad luck ordering stuff from FastTech. First order of an item is OK but then when I re-order there is a second generation out that has been made cheaper to the point of not being usable. I certainly have never ordered drill bits online, but here is proof as why it would not be a good idea.
Here is a capture of an offering of bits at FastTech, and then a blowup of their picture.
Enough said
Compare that to an EXTREME closeup of the Ryobi bits (considered by many to be cheap and of lesser quality than “name brands”}
This is something I have never come across before, but it makes sense. While I was doing some tailcap readings (2.75A with 2 18650’s in parallel, ala the DST thread) I noticed I could not switch modes. There should have been High, Low and a Blinky. All I could get was “High”. What I suspected was true. The driver is in the tailcap!
There are no identifying numbers on the small chip on the bottom.
No high amps thru the tailcap switch and the clicky had a nicer feel.
I’ve often found that things at Home Depot or Wlamart are cheaper than ebay. Walmart has the best price for garbage disposals. Home Depot has the best prices for most electrical stuff (though Walmart has the best price for blank and rectangular cover plates).
But all those on ebay are a lot more expensive. :~
It has been confirmed. The 850 Lumen Defiant 3C is a Black Friday promotion light that was brought early by that 1 store. Look for that light in an upcoming Black Friday ad.
I showed a picture of the display to Customer Service at my home town HD and they could not find it in their system. Then I showed them my receipt and they found it in another place on their computer. Upcoming BF stock.
They had them in the store, just not yet in their system, and certainly not on display.
My final thoughts on this is light is that it is not bad for what it is. A decently bright light that runs on commonly available batteries that is relatively cheap. The tailcap driver is probably not easy to mod and so far I have not been able to get the head off. The sloping of the head towards the bezel makes it difficult for a strap wrench to grip. Good for gifting non flashaholics during the holidays.
If I get time tomorrow I’ll walk up the hill from work and check the HD there. I haven’t had much luck with this store but who knows? If I do buy something I know who I’m gonna blame!
Got the ryobi kit returned and found the HDX kit. They don’t put them with all the other kits, instead they put them in front where they have all the other random stuff that you get for cheap or use as gifts…
Seems to be a nice kit for only $4.88. It has multiple of each bit so that you can break them several times before you run out. Also the kit has a rubbery back so when you place it on a smooth surface, it doesn’t slide all over the place.
I tested some of the bits and they work really well. They drill much better than the old ryobi bits, of course because they’re new. I broke 3 smaller bits when trying them out :_( The small bits are so fragile! But the larger bits are fine.
I used some of the bits to replace the bits in the old kit.
It was nice to repair the old kit but I felt bad taking bits from the new kit. The case of the new kit is so nice. :~
I wish HD would just sell assorted bits without a case that you can use to refill old cases. The bits always break but the nice cases don’t.
The flyer that contains info on the Triple 3C light came out. Sale is Novenber 19 to December 2
I finally noticed the $4.88 35 piece HDX drill bit set. They are among the Holiday gift displays, in the same general area as the Holiday flashlights. 35 bits for $4.88 IS a good deal. They are selling fast, looks like half of the stock is gone already.
I also saw that clamp worklight that I bought and returned. Even though they just came out, they are already on clearance. $14.04, ends with a “4” means it will be reduced to $7.02 very shortly.
Look what’s back! When I first came across this display I had this urge to buy one.
Then I remembered that I already had 3 :Sp
This deal looks compelling, but solar pathway lights just don’t work as well as one would like.
At $4.53 for a 6 pack, it works out to 75 cents a piece. That’s cheap!
A couple of days ago I helped out a friend as a consultant with an upcoming restoration job he had in another town. After we surveyed the site we went over to a nearby HD. He wanted to see the d-cho mojo in action! As we headed into the store we parted ways though. He wanted to check out the chainsaws. I headed into lighting and quickly came across a Plugmold tamper proof outlet strip. Original price was $81 and it was marked down to $21.03. The date was old enough to be a penny so I grabbed 1 (there were 2) and headed up to self checkout. Sure enough, a penny. So I bought it and headed outside to off load it into the car. I went back in and grabbed the other one and found him looking for me in one of the isles. He told me we had to go, his office scheduled another appointment for him. I explained what I had already done and gave him the second one so he could have the pleasure of checking it out himself. When we got to the checkout he scanned it and verified that it rang up at a penny, but he got flustered and set it back down on the WRONG side of the checkout. I told him he had to move it over to the bagging side and when he did it scanned AGAIN. To that, he got even more flustered and I explained to him it didn’t matter, it’s ONLY a penny, SO WHAT. Of course by then the self checkout helper noticed the problems and came over. Good thing he had already paid and had the receipt because he took issue with it. He called electrical about it but they never came so he finally just let us leave. My friend was impressed and once again I felt the thrill of victory.
We already cooked two turkeys and a meat pie or whatever it’s called in it. heh :party:
I found a problem with the cooker. It rusts. The metal ceiling of the heating area rusts.
When you leave it off and closed for a while, the moisture would condensate on the top and the heating area would be all wet. Then when you turn it back on, it dries out the water very quickly causing it to rapidly rust.
The metal cage looks like it will not rust but the ceiling and propellor would. The propellor has not rusted much at all, just some coloration, but the ceiling has quite large rust areas. Also the screws rusted.
I wonder if after a lot of use the ceiling would rust through and it would break. Or maybe the top layer of rust will protect it. Only time will tell.
That depends on who and/or where. Where we are it is very dark at night (rural area, no bright lights anywhere in sight except for the damn cars) and solar lights work very well. We got solar lights from Dollar Tree. They are low quality but they work well and look nice.
But in your area with a thousand LED bulbs you got for cheap of course they won’t do didli squat.
btw, I just discovered Harbor Freight and that they sell cheap tools… yes I’ve heard of Harbor Freight but never browsed or entered their site or store. Just now I did after being recommended some hole saws for cheap. I needed a hole saw to drill a hole in our distribution panel for a sub panel. At home depot a 2” hole saw is nearly $15!! For a little more I found I can get a whole kit of hole saws at Harbor Freight. So now i’ve been interested in Harbor Freight tools and we’ll see what they have in store and hopefully they sell that kit in stores.
Also i’ve heard that Harbor Freight will give you a free multimeter whenever you buy anything. Or something like that. Someone sent Dave Jones the “World’s Cheapest Multimeter” which he said he got for free from Harbor Freight when buying a $3 torch. Here’s the video: https://youtu.be/d75uoCu69WY?t=33m49s
Edit: actually searching on google it looks like that was just a coupon for a limited time… google images gave a lot of results of harbor freight coupons for free things so it looks like harbor freight often gives free stuff every once in a while.
Harbor Freight actually has some good stuff among the junk, you just have to know which is which. My last trip to HD had space cleared for the upcoming sale displays so I’ll check back there ASAP to get those HDX bits. I go through lots of them in my work where hidden nails are a given, rendering enough damage to make resharpening unfeasible.
If you watch it, he admits that as far as accuracy is concerned it is “spot on” He seemed surprised by that. Of course he laughed during the whole review as it is obvious that it is very cheaply made, and he wouldn’t recommend it for high voltages. In other words, it is perfect as a “starter” meter IF all you are measuring is low voltages.
BTW, why is no one surprised that the cheap Harbor Freight Calipers measure so well and why is it no one is surprised when the $1 Dollar Tree calculator calculates the square root of 2, accurately, out to 8 digits? They too are “spot on”
I went ahead and picked up one of the Defiant 850 lumen flashlights for $9.88 and a 2-pack of the 2xAAA Penlights for $4.88. When I first discovered this forum and started buying more and more lights, one of my first purchases was a 3D ArmorMax and shortly after, a DST. Since, then, I have purchased every single mid-sized or large Defiant flashlight that has been released. It’s kind of just become a tradition and as a result, there are Defiant flashlights under most of the sinks in my house and in most of the closets and cupboards- they come in pretty handy! My impression of the triple emitter 850 lumen holiday special- typical Defiant… It’s bright enough to impress non-flashaholics and actually throws fairly well for such a cheap light. Size is much easier to handle than the bigger ArmorMax, DST and last years LARGE Triple emitter lights from the holiday season… Is it really 850 lumens? I have no idea LoL - I don’t have any way to measure it.
The AAA pen lights are VERY cool in tint- almost purple. Definitely brighter than some other pen lights that I’ve seen that run on the little tiny button batteries. For the price, I would have no problem buying a couple packs to take camping or something just to have a small cheap light that puts out adequate illumination without worrying about losing them.
In conclusion: for $9.88, the 850 Lumen is more than enough light for non-enthusiasts and cheap enough to use it hard without worries. The pen lights are also priced right for what they are and if they last a month of hard use, then I’d be happy with my $5 investment. (There is a large Husky light that I have my eye on simply because of its looks- its almost obscenely BIG and it just kind of amuses me, haha… maybe I’ll post some thoughts on it if I grab one)
Happy Thanksgiving!!
Does anyone know if those $4.88 drill bit kits will be gone anytime soon? I’d like to get another one later when I run low on bits but not now. But if they are going to be gone then I would want to get another one now.
Also yesterday on Black Friday I saw a good deal for a drill/driver kit. It was a RIDGID kit and it had a LOT of driver bits but not many drill bits, and it was $9.88 I think.
Problem with that kit is that there are too many drive bits that you don’t need much but not many drill bits that you always need lots of.
I can’t seem to find it on home depot website so it was probably a black friday only thing?
Was at HD today and was looking at the Black Friday stuff while walking by, and then I found this:
A RIDGID 16 gallon wet vac! Price… $39!
A while ago I was searching for 16 gallon wet vacs and the cheapest I could find was $100 for the Sears Craftsman wet vac. The cheapest for a 16 gal wet vac at Home Depot I saw was around $160 for a RIDGID vac. All of a sudden I see this and it is $40! Huge difference!
It is lightweight and feels cheap and basic but not poorly made.
If anyone is interested, some HD’s have a fair number of the older 5C Defiants for 10 bucks. I just picked up 3 at a local HD and some stores list over 30 in stock It’s pretty much a fence post with an led at the end but I really like these. Much more powerful then the BF 3c.
The 5C's and brethren seemed to be the end of high quality large Defiants.
poiihy,
Thanks for the Shop Vac alert. I picked one up. Seems like a great deal. My small anemic shop vac has been on it's last leg for years now. You the man!
