At nearly 9” and only 95g I think it will fit my needs well for a large, thin and lightweight knife for SD carry when wearing shorts and lightweight pants.
It’s actually about the same weight as my Large SOG Trident, which is EXTREMELY light, but I think this Endura4 is a lot thinner. If I really like it a lot I’ll eventually get the real one (probably the less expensive VG10 version)
Guys, I was thinking if we should create a thread of reputable AE stores selling sought after blades. This info is then constantly updated in OP. I think it’ll be easier for us all to refer to that list!
I have that exact model - I find it absolutely superb. My only very minor gripe is that the upper edge of the compression lock is a wee bit sharp so could do with the 90 degree angle softening a little with a file. I haven’t got round to doing it yet. I think mine worked out at about £17 but it is still incredible VFM.
Wow, I didn’t checked the shipping cost…only 30$, what a bargain… :Sp
Thank you FT, but not this time…I hate ordering from GB as well but if it’s the only choice well…will try
It’s a pleasant folder for the money. The chekering of the G10 is quite agressive so you don’t have to worry about having a firm grip on it. I chose the part serrated version :
I haven’t had many (any?) budget knives without blade play. It’s been a while though. Maybe they have gotten better. You guys are going to make me find out.
Thank you very much for explanations about compressor lock.
So, another question: if you have/can comparated them, which lock is better from a Spyderco clone (with compressor lock) and a “original” SpyderGanzo with linear lock?
In my opinion, the axis lock wins over the compression lock. In my use they are equal in safety, and both are fun to play with (flip-in-flip-out-…)
The ambidextrous axis lock makes the SpyderGanzo a winner
I can easily deploy the blade with left or right hand when needed
I also like the symmetry of it as there is no front/back side
Still waiting for the G731 Tri-Ad Lock (as if that will ever happen)
That lock is solid
My order of preference of the three is
1)compression
2)axis
3)liner.
It’s really just a matter of preference though. A good liner lock is plenty strong enough, but axis and compression are stronger. You have to do some really heavy work to compromise a well built example of any of them. It’s more about what you like opening and closing.
The safest lock system in the world is the tri-ad-lock but it is not enough to copy it, the materials used are very important too.
About lock systems… really it is almost more important the quality with the lock system is done than the type of system. But each system have some individual characteristics. I like the axis and the framelock but i have seen ALL types of lock system fail but not the triadlock on tests.
