Any tweaks or changes you guys want made just let me know I’ll finish it off tonight
In the course of this hobby, no EDC that I thought was the perfect one has lasted more than 3 months in my pocket before it was replaced by a different (different=always better ) one. But it is a good thing to think about that of course :-)
can pyro/djozz link to the page where we are getting these pot measurements (or ordering from)?
also, what springs are everyone using? I think I could get my switches to work if my springs were a tiny bit bigger.
I just ordered these:
For the sizes, google 3303 potentiometer (most hits direct to Bourns pots), or 3x3 potentiometer.
For my EDC I used the stock switch that came with the Supfire S1, not the biggest one around but I think I can fit the 3x3.5x1.2mm pot in there.
another link (I go for 100K but perhaps 50K is enough):
Would you have the model # or a link to your switches?
I was hoping for something closer to 25kohm…. I’ve never had to use a higher value than 22.1kohm, plus I have the other resistor pad in series bring it down a touch more. I’m worried 0-100kohm in one tiny pot is going to be a nightmare to tune…
Still better than soldering/unsoldering resistors till you get it right though.
I think this is what I have. Honestly I think it’ll fit under my springs, I’m just worried it’ll be too easy to bridge solder to the inside switch pins. I’m not worried about the outside pins because the case is neutral. I’ll do a board in about 4 hours.
I was hoping for something closer to 25kohm… I’ve never had to use a higher value than 22.1kohm, plus I have the other resistor pad in series bring it down a touch more. I’m worried 0-100kohm in one tiny pot is going to be a nightmare to tune… Still better than soldering/unsoldering resistors till you get it right though.
My idea is to bridge the other resistor pad and have the full range to adjust (the bleeder resistor will determine the maximum brightness) , and the 100K is to be able to effectively switch the lighted tail off. I will see about the tunability. (I have not found logarithmic pots in this size yet, just lineair ones. Come to think of it, if logarithmic pots are used, the orientation of the pot does matter )
What is the orientation for logarithmic pots then? On mine with a linear pot, clockwise would make the led’s brighter.
don't know, have to look that up.....
Mousers seems to only have the option for lineair potmeters in this size
well that makes it simple enough.
It would literally only take about 45seconds to move the trace to the other pot pin anyways. I just know it will be easier for me to remember right=bright
It is a bit bigger (4.5x4.5x2.55mm), but this Bourns 3314 type will fit the solder pads as well I think, and it is a bit more robust:
I still have not got my BLF A6 to work properly.
If I adjust mode to moon then switch it off I get sometimes a mode were the LED did not light up, so the switch is pressed but no light shines…
I used a 680ohm bleeder.
I do like that slotted type better than the “phillips” type.
I don’t think anything bigger will fit
The diagonal measurement of 4.5mm square will be 1.414 times bigger or ~ 6.3 mm which would almost certainly touch the spring when compressed. Definitely need to know what the case metal is grounded to.
On the big one Djozz posted, It looks like it’s just a clip and not connected to anything else. On the smaller ones, I think the case is the same as the “slider” pin
