Rechargeable Nitecore NL14500A not charging.
8 posts / 0 new
18650
18650's picture
Last seen: 2 years 3 months ago
Asking because I’m not familiar with these batteries.
I’m using my new Nitecore D2 and a new Nitecore NL14500A (3.7v) rechargeable battery, the screen show “Chg. Finish” but only show 1.60v ? I tried the battery in my EA11 and it doesn’t work or turn on the light. I tried a different brand of 14500 battery and the EA11 works perfect. I’m wondering if something is wrong with the Nitecore battery or the charger? Why it show less voltage if it’s full charged? Any help will be appreciated. Thanks!
Henk4U2
Henk4U2's picture
Last seen: 2 hours 26 min ago
Did you use the “mode” button. I have no D2 myself, but the review of HJK states that “The charger will assume NiMH below 1.8 volt and LiIon above 1.8 volt.”.
My impression is: if the charger “thinks” it’s a NiMH, it will never charge on to LiIon levels. Unless you can override that “thought” via a button.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
M4D M4X
M4D M4X's picture
Last seen: 1 year 3 months ago
can you meassure which voltage the cell actually has?
if its below 2.5V there is something fishy…
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
18650
18650's picture
I placed it back in the charger and shows battery is full charged but when I measured the voltage it read 0.47v while my other two non-Nitecore 14500 batteries read higher than 3.7v after been recharged in the same charger.
Ronin42
Ronin42's picture
Last seen: 3 years 3 weeks ago
Henk4U2 wrote:
Did you use the “mode” button. I have no D2 myself, but the review of HJK states that “The charger will assume NiMH below 1.8 volt and LiIon above 1.8 volt.”. My impression is: if the charger “thinks” it’s a NiMH, it will never charge on to LiIon levels. Unless you can override that “thought” via a button.
+1
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 2 years 6 months ago
Sounds like your Nitecore battery went kaput…you should never discharge a Li Ion battery below 2.75vdc for long…if it’s reading 1.8..something is bad wrong!
akhyar
akhyar's picture
Last seen: 15 hours 32 min ago
If your battery reading shows below 2.5v, maybe you can “jump-start” your battery before you put it in the charger.
There are some posts on how to “jump-start” batteries with almost dead voltage before you put back in the charger.
There are risks involved in this method, so only proceed if you know what are you doing
lostheplot
lostheplot's picture
Last seen: 1 year 9 months ago
Is it a protected cell?
It may have stuffed up
Try removing the protection and charge’‘ if your charger can charge unprotected cells’‘
I had something similar with one of my Panasonics recently
sorry all images down
thanks photobucket
