That’s very true funny how that happens. I’m going to let you do the switch versions.
We getting an insane amount of ideas into these switch boards. Go BLF!
I’m going to go ahead and call this the current “Ultimate edition”. As long as you guys don’t find any errors, I’ll be ordering this board very shortly because I can’t think of anything else to add. Of course if we get the transistor idea to work that will bring a completely different level of function, but I think this one will suit my needs perfectly. It’s still not beautiful, but at least it is more balanced now.
It allows for two pots. Only one would be in use at a time, the switch would toggle between the two. So you would use the pots to set ‘high’ and ‘low’ levels at the time of assembly, then use the switch to toggle between those two levels. Or, just leave one of the pots unpopulated and that switch position becomes ‘off’. If you don’t want to use the pots, you can simply bridge the pot pads with a resistor to have essentially the same functionality. Both led’s are on the same circuit.
OD of board is 15.93mm (so it should fit almost anywhere)
Outer ground ring is 2.1mm wide
Gap between rings is 0.93mm
ID of spring ring is 7.4mm
OD of spring ring is 10.8mm (1.7mm wide)
Main power vias are 0.8mm each (1 ounce copper)
Accessory vias are 0.5mm each
Spring bypass via is 1.1mm
According to my measurements, as long as the pots you use only hang over the edge of their pads a tiny bit, an omten 1288 will slip in perfectly between them. Nothing bigger will fit. Everything on this pcb is packed in tight, so you will need to be careful assembling it.
I highly recommend hot-air reflowing but otherwise I recommend soldering in this order:
I don’t see any minimum resistor being set in series. Just wondering, what happens if you set the pot to 0 ohm? With the bleeder resistor only at about 0.5k, will the tiny LED withstand the current?
There just isn’t anywhere to put another component that I can see. If you just want the on/off function, Rev2 and Rev3 have the resistor in series with the pot.
With a bleeder of 560 Ohm, and a battery of 4.2V, even without a led the current will be 7.5mA which is fine for those tiny leds. With the led in the circuit it will be less than that.
Whenever I grab a light to show off to muggles, it’s usually my naked S8 and it’s usually in the daytime indoors, so I want the blue tailcap to be bright enough to stand out. The rest of the time, I want it more dim and functional. That was my inspiration.
Thanks pilotdog, using a via and means less solder wicks up the wire to stiffen it when you add the spring. Also means less likely hood of bridging in this case and placement is automatic.
Placement is great. Via is big enough for awg18 though I think the insulation of silicon wire might be to thick in that size to clear the spring. Thoughts on that? I’ve only done solder wick bypasses so far so not sure of the ideal wire size but a .8 via would still allow up to awg22 and put solder mask between the via and the spring. The problem I’ve had is the spring requires more heat to wet and sharing the same pad means the wick takes up more solder than is wanted. A via takes less space than a pad and is easier to keep discrete. I appreciate the work that goes into this and I’m making an effort to consider how this board might be used by others besides myself and not just making more work for you. Thank you.
1.1mm is the drill diameter I used for the via, but I think that’s before it gets plated. They always end up smaller when I get them from Oshpark. I understand what you’re saying about wicking, but I don’t think I can do much to get around that. Even if the pad is small enough to have solder resist between it and the spring, it’ll still be connected by the copper underneath. I would just solder the wire in its hole, then tack the spring down in the two corners furthest from the wire to avoid the wicking as much as possible. I never solder the spring all the way around, just in 2 or 3 places.
My first adventures with the transistor circuit, quick story because I need sleep now.
I used one of the older boards, cut some traces, scratched off some solder mask and got the circuit done.
Long story short, it does not work straight out of the box, I tried lots of other configurations and resistor values (the bleeder eats voltage so that has its influence on the working of the circuit), even refreshed my knowledge of NPN transistors for this (keep enough voltage over the base), I get red light (most of the times), I get blue light, but no switch-over at certain voltages. Too low resistor values even keep the driver MCU alive (LVP warning ), etc. What does not help is that I have no electronics background.
A dedicated board would help the testing, but if it will work at all in the end, I don't know.
An explanation of how I think the circuit works: at voltages closer to full battery the green led (I used blue btw) lights up and that keeps enough voltage on (and thus current through) the transistor base that a free current flows from emitter to collector, thus bypassing the red led, that stays off. Below a certain voltage the green led drops out, the voltage between the transistor base and ground drops below 0.7V, the transistor stops conducting and the red led lights up. Anyone knows better than this??
