With the higher Vf of the Nichia 219b the amps that this light pulls is not as high as my 219C build. There will be a heat issue anyway but not as 'clear and present' as in mine.
This driver is made for this light IMHO https://budgetlightforum.com/t/-/33706
I have made and tested this light with the LD-2 driver and xpl triples at 9A and 12A and 219C single at 6A with silicone cubes on the driver and the NTC resistor glued to the MCPCB. with this setup the lights throttle down as required to keep the led below 70 degrees C. I even wrapped one in a blanket and it went down to low and didn’t get too hot to touch.
I'm not sure if this has been answered but is this available the same as the original light was as a host with the two pills but with an upgraded switch and if so how much?
[/quote]
Maybe everyone that wanted one got it last time? I don't know... Maybe you could add "New Group Buy" or something to the title so people know what the thread is about?
[/quote]
Thank you for the advice, I will change the title, and put paypal address in the thread.
