Known issue, and to be expected. The off-time capacitor they used is sensitive to heat, so the button timings change depending on the temperature of the light. While hot, it’s faster… and while cold, it’s slower.
This effect was reduced by 80% before production, but not eliminated entirely.
If you use one of RMM’s drivers instead, the heat sensitivity is reduced by like 95% so it’s barely noticeable even when very hot or very cold. RMM uses the best available components, and he has an improved board design.
Do you guys and gals think this light would still benefit from the tail spring bypass mod with the S2+ tailcap installed? Can the S2+ switch handle that kind of thing?
But the metal switch is still functional even with the current draw of a tripel?
My plan is to build a triple with an A6 driver in a S2+ host (with metal switch), but I couldn’t find more info (max. Amps) about the switch.
The light works fine… it just compressed the spring so far that even a light tap will cause it to change modes. It’s fixable by stretching the spring out (or putting in a new one) and adding a spring bypass.
For higher-amp lights like a triple XP-L, I have a solid post on one end of the battery and a really strong spring on the other side (q-lite springs are actually pretty awesome).
Somebody please correct me if I’m wrong, but I always look at the switch in this perspective. If it’s supposed to be able to do 1.5A at 125V, then that would be 3A at 62.5V or 6A at 31.25V or 12A at 15.625V or 24A at 7.8125V or 48A at 3.90625V, well I think you can see that they should handle anything we have cells for. I don’t know if this is the correct way to evaluate these switches, but I’m sure someone can and will chime in if I’m off base.
I’ve run a small Omten at 21A in my Ti X6 with 4 Nichia 219C and so far so good. It could fail tomorrow of course, but…
I’ve also had good luck stretching a spring back into proper form then bypassing it with a wire bypass. The wire carries the current from this point forward and the spring has always worked to keep the cell in contact. Again, so far so good.
Typical triples with XP-L HI emitters run around 11-12A, with XP-G2 emitters around 9-11A. That’s if you do spring bypasses and kill all resistance possible while using a top high discharge cell with a good solid ground in the host body.
Is there a link somewhere for this solid post mod?
I did the spring bypass on the s2+metal tail switch that I have on my A6 today and it seems to be working fine. I have a regular NCR18650B so I’m sure it’s not putting it to the test though.
Ooops sorry didn't see this. Definitely Nyogel 760G. The difference is minor but varied radically from light to light, all depending. I've probably seen high as of 20 lumens, so for 600'ish lights, that's 3.3%. I'd say 0-4% in a range.
You probably won’t see much difference with a NCR18650B.
As for a solid post… not much explanation is needed. Just solder a chunk of metal to one end or the other. Or even just put a solder blob on where a spring would normally go. For parts, check http://www.mtnelectronics.com/ , under Components -> Springs / Brass Buttons.
This is surely not how that works, when 'on', a switch only 'sees' the voltage over itself and in principle only the current determines how much it can take. But voltages in the circuit are not irrelevant, during the switching on and off, arcing can occur that damages the switch, this effect does increase with voltage. So in the end voltage does matter but not in the way you reason.
That that small Omten can take 21A is nothing less than a small miracle, in principle the building design is good, but with its thin metal strips in a fairly soft plastic housing I would not have given it more than 3A, until it happily survived 16 in my test, and now 21A in your triple .
I doubt it would handle 48A because AC, measured at RMS and not peak voltage, “sees” less resistance in a conductor (or switch assembly) at a given voltage than DC does, so there is not a direct correlation between the two. IIRC (and it’s been a long time ago since I was in it this deep) the DC capacity of a conductor (switch) is roughly calculated at 62% of an equal AC voltage and current level.
Ohm’s law is far more complex with AC than DC- AC and Ohm’s Law explains it better than I can.
You are correct. I unsurprisingly noticed no gain from the spring bypass using NCR18650B. I have some Sanyo NCR18650GA’s on the way so hopefully I may see a difference using those.
In hindsight I feel silly asking about the post mod now. it’s really straight forward lol.
The s2 tailcap and switch do look sharp on the a6 though I must say.
I have most of the anodizing brushed off just leaving some blue highlights in the knurling and around the switch.
Ya will do. I went out today to grab some oven cleaner, got to Wallmart, spent $47, and came home without oven cleaner. D’oh.
So I put the wire brush on the dermal when I got home, just to give the oven cleaner a head start when I do eventually get it. I got a little carried away, and here we are.
There is a Omten switch in the S2+ metal switch assembly?
I just got an answer from Simon (Convoy), I asked him about the maximum current on the S2+ metal switch, his answer is 3A (no voltage mentioned, but I think it’s meant in the flashlight context).
I have a blue S2+ host on it’s way, so I will see…
