Do you guys and gals think this light would still benefit from the tail spring bypass mod with the S2+ tailcap installed? Can the S2+ switch handle that kind of thing?
But the metal switch is still functional even with the current draw of a tripel?
My plan is to build a triple with an A6 driver in a S2+ host (with metal switch), but I couldn’t find more info (max. Amps) about the switch.
The light works fine… it just compressed the spring so far that even a light tap will cause it to change modes. It’s fixable by stretching the spring out (or putting in a new one) and adding a spring bypass.
For higher-amp lights like a triple XP-L, I have a solid post on one end of the battery and a really strong spring on the other side (q-lite springs are actually pretty awesome).
Somebody please correct me if I’m wrong, but I always look at the switch in this perspective. If it’s supposed to be able to do 1.5A at 125V, then that would be 3A at 62.5V or 6A at 31.25V or 12A at 15.625V or 24A at 7.8125V or 48A at 3.90625V, well I think you can see that they should handle anything we have cells for. I don’t know if this is the correct way to evaluate these switches, but I’m sure someone can and will chime in if I’m off base.
I’ve run a small Omten at 21A in my Ti X6 with 4 Nichia 219C and so far so good. It could fail tomorrow of course, but…
I’ve also had good luck stretching a spring back into proper form then bypassing it with a wire bypass. The wire carries the current from this point forward and the spring has always worked to keep the cell in contact. Again, so far so good.
Typical triples with XP-L HI emitters run around 11-12A, with XP-G2 emitters around 9-11A. That’s if you do spring bypasses and kill all resistance possible while using a top high discharge cell with a good solid ground in the host body.
Is there a link somewhere for this solid post mod?
I did the spring bypass on the s2+metal tail switch that I have on my A6 today and it seems to be working fine. I have a regular NCR18650B so I’m sure it’s not putting it to the test though.
Ooops sorry didn't see this. Definitely Nyogel 760G. The difference is minor but varied radically from light to light, all depending. I've probably seen high as of 20 lumens, so for 600'ish lights, that's 3.3%. I'd say 0-4% in a range.
You probably won’t see much difference with a NCR18650B.
As for a solid post… not much explanation is needed. Just solder a chunk of metal to one end or the other. Or even just put a solder blob on where a spring would normally go. For parts, check http://www.mtnelectronics.com/ , under Components -> Springs / Brass Buttons.
This is surely not how that works, when 'on', a switch only 'sees' the voltage over itself and in principle only the current determines how much it can take. But voltages in the circuit are not irrelevant, during the switching on and off, arcing can occur that damages the switch, this effect does increase with voltage. So in the end voltage does matter but not in the way you reason.
That that small Omten can take 21A is nothing less than a small miracle, in principle the building design is good, but with its thin metal strips in a fairly soft plastic housing I would not have given it more than 3A, until it happily survived 16 in my test, and now 21A in your triple .
I doubt it would handle 48A because AC, measured at RMS and not peak voltage, “sees” less resistance in a conductor (or switch assembly) at a given voltage than DC does, so there is not a direct correlation between the two. IIRC (and it’s been a long time ago since I was in it this deep) the DC capacity of a conductor (switch) is roughly calculated at 62% of an equal AC voltage and current level.
Ohm’s law is far more complex with AC than DC- AC and Ohm’s Law explains it better than I can.
You are correct. I unsurprisingly noticed no gain from the spring bypass using NCR18650B. I have some Sanyo NCR18650GA’s on the way so hopefully I may see a difference using those.
In hindsight I feel silly asking about the post mod now. it’s really straight forward lol.
The s2 tailcap and switch do look sharp on the a6 though I must say.
I have most of the anodizing brushed off just leaving some blue highlights in the knurling and around the switch.
Ya will do. I went out today to grab some oven cleaner, got to Wallmart, spent $47, and came home without oven cleaner. D’oh.
So I put the wire brush on the dermal when I got home, just to give the oven cleaner a head start when I do eventually get it. I got a little carried away, and here we are.
There is a Omten switch in the S2+ metal switch assembly?
I just got an answer from Simon (Convoy), I asked him about the maximum current on the S2+ metal switch, his answer is 3A (no voltage mentioned, but I think it’s meant in the flashlight context).
I have a blue S2+ host on it’s way, so I will see…
I realized I could just move the switch over from the a6 and put it under the metal button in the S2 tailcap. So now I have the A6 switch inside the S2+ tailcap on the rear end of my A6.
Works perfectly.
Also I did some water testing of this hybrid tailcap. Without adding a gasket or doing any further modification, the tailcap with metal clicky and A6 switch appear to be waterproof on it’s own.
Granted I only filled my tube so didn’t get anywhere near the ipx-8 standard depth of 2 meters, but I did slosh it around and click it 40 or 50 times.
When I took everything apart I looked and there was no water ingress, so then I did the same thing but with batteries installed. Everything turned out fine.
When I took it apart after the second test I realized there is space to double up on o-rings on both ends
Is the coupon code for the unanodized version still kicking around? I think I may grab one of these in a cooled tint. This “3D” tint is pretty warm, like incandescent or warmer. I think they may have sent the wrong emitter in this light.
The sku says 3D but Idunno about that. This is the warmest light I’ve seen since my mini mag incandescent back in 1999, warmer even.
