Will inform supplier about this issue.
If you do not want a second A, I think it will be quicker to get rid by putting it on sale?
Overall quality seems good.
Battery Tube and Tailcap from MS-R25 and MS-R28 are the same.
You can feel a temperature rising very quick, so the connection between LED and Body seems good.
They could lube the threads with a little more grease.
In my opinion very nice is the “soft” switch between modes with a one sec dimming effect.
The verry long NONAME protected Panasonic 3400mAh fit into both Flashlights.
MS-R25 has a little spring at + terminal, so Flat Tops are no problem.
MS-R28 On both Flashlights the + Terminal needs cleaning.
NO FLAT TOP Batterys
Thanks for the info ID4. Could you please describe the user interface (sequence, mode memory, shortcuts)?
And did you notice any step down at the highest level on MS-R25?
Good, thank you !
How is the tint ?
@RaVeN
Short click side switch: turbo > high > mid > low
Long click side switch: strobe another click back to lightning mode.
doubble click side switch: direct turbo
Torch wil memory the last mode.
Manual says: To avoid overheating and ensure LED lifespan, Ms-R25 will automatically step down slowly till the output is lower than 65% of the turbo brightness when temperature istoo high. For turbo again pls restart the torch or press side swich for choosing.
@Patrickbateman
I would say something like the Nitecore MH20 CW ( 6000K ).
Freeme, I am very interested in the MH27! I really like the look of this light, with 53500 cd and RGB it is very appealing. Seeing as I don’t have any coloured lights I figure this will kill a few birds with one stone too. Any idea when this GB will be, roughly?
Cheers!
Dec/Jan probably?
Enough time to recoup my funds after Christmas, hopefully… :party:
Thanks for putting these on for everyone too, legend.
Me too. Hope that it is better than SRT7.
sign me up for an MH27 freeme and thanks for all you do for the community.
Hi freeme,
I’d be interested in the MH27, too. Please sign me up.
Thank you!
MH27 looks quite interesting. Count me in.
Names added. #BGB.
Sign me for the MH27
Budgets are stretched but a must have light!!!
Interested in the MH27.
List updated.
I’m in for the MH27.
Thanks
Thanks
Daily list update. Price will depend greatly on the number of participants so keep them coming!
FINALLY!! They are here today!
Edited
Did a quick measurement just now. Model A registered 3.3A with 18650VTC4, which is 0.2A higher than my MH20. Output would be higher with 2xCR132A according to specs.
Note: my measurement is usually at the lower end compared to the other fellow members.
