@RaVeN
Short click side switch: turbo > high > mid > low
Long click side switch: strobe another click back to lightning mode.
doubble click side switch: direct turbo
Torch wil memory the last mode.
Manual says: To avoid overheating and ensure LED lifespan, Ms-R25 will automatically step down slowly till the output is lower than 65% of the turbo brightness when temperature istoo high. For turbo again pls restart the torch or press side swich for choosing.
@Patrickbateman
I would say something like the Nitecore MH20 CW ( 6000K ).
Freeme, I am very interested in the MH27! I really like the look of this light, with 53500 cd and RGB it is very appealing. Seeing as I don’t have any coloured lights I figure this will kill a few birds with one stone too. Any idea when this GB will be, roughly?
Edited
Did a quick measurement just now. Model A registered 3.3A with 18650VTC4, which is 0.2A higher than my MH20. Output would be higher with 2xCR132A according to specs. Note: my measurement is usually at the lower end compared to the other fellow members.
Bezel is not glued for B. I managed to remove it with the lens. Reflector did not came off as it was held down by black o-ring. LED should be accessible but I stopped at that point because I did not want it to be scratched by mistake or contact with dust.
It could be different... cos I got different readings between A & B (to be confirmed later).
As for the clip, it fits perfectly with SF and even Convoy S2+ without modifications(kind of over-sized).
