Do you have a link from where you ordered it from?
it will depend if your torch is regulated or not if it is the batteries will not make it brighter at all, if your torch has a built in low voltage cut off you might not be able to use 100% of the mah capacity the same would go for trustfire flames even, but they should give you high current draw readings and longer run times.
next week im going to buy a couple to try out this is where ill get them from
I would much rather buy 2 Xtar 18700 2600MAH for $13.50 than pay that much for one of those. I doubt that they will beat the Xtar batteries, too.
they beat the xtar,s in more then one way but not on price
xtar 2450 mAh (claimed 2600 mAh)
hi-max 2450 mAh (claimed 2600 mAh)
TFF 2450 mAh (claimed 2400 mAh)
redlist 2950 mAh (claimed 2900 mAh)
the xtars are put together cheap and have an over stated mAh ratting
my money is on redlist over xtar but yes there is double the price send me your best xtar and i will do a internal resistance and mAh high current shoot out.
but if you search xtar on here they trip with current draw of 5 amps so the ic,s on the red,s should be better if they are from japan and not hon kong like xtar, the hi-max batteries can handle a higher current draw then the xtar,s going from a post of this forum
the xtar,s take the same mAh as the trustfire flames food for thought, but alot of people dont know how good or bad there batteries really are cause they are using basic chargers with no data read out and some never get pushed
http://lygte-info.dk/info/Batteries18650-2011.html
im not saying the xtar,s are not good but there is the posiblity of some thing better out there but it all comes down to $$$
I ordered from Redilast.com so the battery will be here to Florida in a few days I assume rather than waiting for overseas shipping etc.
Torch runs on 3aaas or with adapter tube a 18650- a good emergency light because of dual power options- brighter on 18650 .
http://www.szwholesale.com/images/ProPho/3973/DSC_2311.jpg
This is a link to the Saik Sa9- my first Torch and first 18650 device. I did not buy the light at this store- it was from Ebay- it has a nice wide flood that tailstands to light up a 12 X 12 room like a small fluorescent lamp would- only prettier light.
It also has a Laser like penny sized beam on full Zoom mode that projects a clear image of the LED easily a few hundred yards and with a little humidity the beam is visible kind of Laser like.
Has nice medium mode, solidly made, turns from flood to Zoom in about 90 degree turn of the greenish metallic ring.
I only got two batteries with it and a travel charger on Ebay for $16.50 - one battery the Blue Ultafires works great one is a dud.
I want to see what a really good battery will do so I ordered a Redilast 2900 after reading that they really test out above 2900 mah.
They have a 3100mah but most chargers I've read will not be able to take advantage of the extra capacity anyway.
I am a novice but will report on the Redilast when I get it- my guess is that this light is NOT regulated 'cause it was so cheap but it's solid and I love the color and brilliance of the Cree Q5 and the glass sphere lens really focuses well.
I have a few Ultrafires 3600 ( fake ) which are from a nearby dealer coming tomorrow which will probably be bad............we'll see.
In the future the worst batteries I'll bother with will be Trustfires.
I think these 18650s are great if they standardize them and make honestly and safely- they could be used in Radios and other devices in USA- little powerhouses IMO.
im in the same boat, i would like to try the opisite end of the scale. Your Q5 torch sounds awsome i have a couple of Q5 lights and realy like them and my TR-1200 has to be on of my fav,s 5 X Q5,s
The only different thing for a charger is that it will have to charger for 30-40 minutes more. Both batteries are fully charged @ 4.2V, (2900mAh & 3100mAh). So any charger that chargers 18650 will do it. There isn't something special that a charger has to do for that 3100 battery.
They can be charged to 4.35 but 4.2 is fine you’ll never over charge it
Hikelight- maybe I misunderstood then- I thought that most of the small chargers only go to 4.2v and that to take full advantage and get fully charged you had to go to 4.35.
Or to put it more simply- with my little travel charger- a 2900mah Redilast and a 3100mah would only get charged to 2950mah- the same anyway.
ILIKEFLashlights-on a practical basis I agree with you, the difference in performance does NOT warrant the cost- I just want to try one of these.
The whole thing on 18650s is so odd anyway- there's fake ones, they are almost ALL relabeled, very few companies make consumer versions, the average person does not even know about these batteries( like me one month ago) but they are in almost every laptop, and they are very powerful and eco friendly in many ways- compared to throwaways especially.
There are some tests on the XTAR's. https://budgetlightforum.com/t/-/1762
FWIW the 2600 are also Sanyo batteries, I would much rather trust them than a lot of the others floating around. :)
Redilast cells are Panasonic cells with added protection circuits. Panasonic doesn't have cells that reach full charge @ 4.35, only 4.2V.
2900 - Panasonic NCR18650
3100 - Panasonic NCR18650A
Just like CK and others
http://industrial.panasonic.com/www-data/pdf2/ACA4000/ACA4000CE254.pdf
The cells that reach full capacity @ 4.35V and are 3000mAh like the Samsung ICR18650-30A when are charged to 4.2V, they will only have a capacity of about 2800mah or maybe even less. They have a nominal voltage of 3.78V, unlike Panasonic which have a nominal voltage of 3.6V
Thanks Hike- got it, I either read something that was wrong or maybe misunderstood.
Will be interesting to have a good battery, then if I get a Solarforce or an XM-L of some kind - I'll get some solid 2600mah ones, but it is cool to have a few of the premium ones- , like Seny Bor etc.
Also if my little torch is unregulated it may pull more current from a lower resistance, high current capable battery, so I may get more brightness from a Rediast or Seny Bor compared to the Blue Ultrafire that came with the torch- correct ?
Thanks hikelite for setting that straight
As Hikelite stated, it is some Sanyo cells that require charging beyond 4.2v to achieve full capacity (there is also a 16650 cell rated to 2200mAh Max/2100mAh Min that requires charging to 4.30v).
The higher capacity Panasonic cells only require charging to 4.2v, but if memory serves, their capacity is calculated with a discharge down to 2.5v rather than stopping at 3.0v, so you could still observe lower capacities if you stop at 3.0v.
This is certainly the case with the 3100mAh cells - can't remember off the top of my head if the 2900mAh cells are rated down to 3.0v or 2.5v.
2.5V cut-off for both, 2900mAh and 3100mAh Panasonics
I was mentioning about the Samsung ICR18650-30A.
But of course Sanyo has some cells too. Like UR18650ZTA needing 4.35V or UR18650ZT needing 4.3V
Sanyo likes to state only the minimum capacity on cells. Which is 2900mAh and 2700mAh in this case.
And the 16650 cell too, UR16650ZT, 4.3V min. capacity 2100.
2100 got 3120mAh on the NCR18650A @ 2.6V termination.
Oops, apologies for the misquote, you did indeed say Samsung, but I was obviously thinking Sanyo.
I'll stand by what I said about rather buying 2 Xtar 18700 2600MAH batteries from Serena for $13.50. I'd almost bet money they will last as long and perform about as well as the Redilast 2900MAH. And you can buy 3 for what you pay for one of these. No matter how you figure the math, the Xtar is the better buy.
in your opinion and maybe most others aswell and maybe not every one.
i say you send me one of your xtar,s ill pay the shipping ill buy a redlist 2900 and ill stress test, test mah, maxium current draws and voltage sag and internal resistance and see witch perform,s better and if your right then people can make up there mind witch is better and witch they find better value for the $$$ they will mostlike pick the xtar simple for price.
or if people want to donate some coin to my paypal i will buy a hi-max, a TFF, a xtar and a redlist and compair them all with some pritty pictures.
The Xtar batteries have one of the best wraps of any battery that I have seen. And it looks like they will last with the best of them.
so you wont take me up on my offer ill compare wraps ?
i found this interesting
this was very interesting
also this
