Using an Altoid tin is very cool, for some reason I love seeing those used for things, but I have never seen one used for anything this elaborate.
Thanks guys. There was actually at least one other thing I wanted to add, but the extra wiring just wouldn’t fit
you are a genius!!
great!
Did i say you are a genius? if not, you are. Brilliant!
Nice work :)
When will HKJ be putting up the review? ;)
...shine on you crazy diamond ...
I would be extremely leary of connecting two TP4056’s in parallel. They are not designed to share the load and could get into a fight over who’s the boss. I can imagine situations where they might not terminate charging properly, etc.
Believe me I was. I got the idea to do them in parallel from some random person’s post on CPF, so I decided to give it a try. (I’ve even seen a 1.5amp charger that has twp TP4056 on the same pcb.) I tested the setup on my bench for several cells before actually deciding to put it into the Altoids tin. As soon as the charging enters the constant voltage stage, the second one shuts off (“done”) and only one of the chargers finishes the charging. So one of the lights turns green well before the other. I also hand-picked these two chargers from a lot of 6 (as there is some variation among samples). On their own, the first one terminates at 4.20v every time. The second one terminates at 4.17v just as reliably. Together in this final configuration, I have now charged 8 cells and all have measured either 4.19v or 4.20v at completion. Obviously I’ll still keep an eye on it, but the meter makes it easy.
One of my inspirations in fact! I actually was planning on using one of those chargers, but changed my mind after buying one from RMM
I had a similar thought but I don’t know if it’s really a concern. Both TP4056 boards push current into the battery at a max of 1A with the chips regulating the flow. Just as long as your USB charger can provide the full 2A I don’t think it’s an issue. From what I gather the chips step down the current as it approaches the cutoff as well. With both in parallel it simply means it’ll get to the cutoff voltage faster with higher current (still below 2A total). I was concerned that power would feed from one board to the other but then I thought the battery could just as well do that with a single board especially if you want to charge a fully charged battery. Then I thought what if both chargers terminate at slightly different voltages? Then I realized that probably didn’t matter either since it would simply mean one charger would stop before the other. I think putting in a USB meter alleviated a lot of concern with initial testing and configuration. It’s not necessary anymore but it’s nice to see the validation that it’s still working. Housing it in an Altoid’s metal container would just be extra cautious. Great work!
I bought 2 types of “TP4056” boards before realizing that there are fake 4056 chips out there. I’m ordering a 3rd batch off of Aliexpress now to see if there’s any difference. (Can’t beat ~$1 for 5 boards shipped). I built my own 10180 charger replacing the regulating resistor so it outputs ~50mA instead of 1A.
Nice. These mc1 are really cheap and slide very nice, I also have one bought for few dollars in one of the last sales. How does the stock circuit board look like?
And how did you open the mc1?
I haven’t seen the two parallel modules but I have thought about it too.
You could also use a potentiometer to adjust the current, just replace the stock current selecting resistor with a pot and you would be able to charge even small batteries…
Sorry I didn’t really look at the MC1 circuit before I stripped it all off and soldered my wires on. The MC1 is just glued around the seam; I used a razor and started at the microusb port and slowly worked my way around.
I thought about having a way to charge at a lower rate, but I really don’t use anything smaller than a 14500. I have single 10440 that I rarely use, so my VP2 will be fine for that. Mainly I wanted something faster than the VP2 for big 18650’s, and more portable. Then halfway through the project I decided to use the little omten to disable one of the chargers for 14500 duty. I’m starting to use my TG06 and L1A more than anything.
This is what I want to see on BLF all the time, thanks for sharing, great build!!
Group buy!
Sweet!!! That is very cool indeed.
Very nice work there. Congrats
Now… If just my phone hadn’t a 4.35V battery I would use it to charge the spare ones
Also, would this work with a variable resistor? Or has the resistance to be fixed at the datasheet’s values?
Nice charger on Steroids :bigsmile: the TP4056 is my favourite small charger board for Li-Ion cells. The smallest one i built was this one: Wallet-sized LiIon Charger build for pennies!
Is 1A not too much for a 14500?
I use the mc1 stock with 500mA for my efest imr16340 and I thought it is to much?
That’s why I wanted to use a charger board with pot….?
I wasn’t sure how to select the current until I have seen your post and the idea with the build in USB power meter.
I just checked a fishermans friend tin box and it is a bit too small to fit well…
