Nichia 219C, testing a 5000K 83CRI emitter, comparing with a XP-G2 S4 2B and other leds
Did test the 219c 5k. The tint isn't very nice (not if you are used to the A or B series) Too flat (dull) and has some greenish/blue hue (that is the reason why it slightly outperform the 219b in term of lumens... "less red" emitted)
Let's see what they will provide for 219C 90+...
I’m not sure where to ask this… Has anyone done testing on the 219B V1? The tint is very nice in my BLF-348, and I remember having a talk about it’s Vf being the same as as the 219c, but I’m wondering about lumens and how much current they can take…
Finally got around to installing some 219Cs last night.
I installed two in small 1x14500 zoomies, and 3 more inside my Jetbeam TCR-01 triple. Previously all 3 lights had been running with Nichia 219B.
My impression: Not bad at all! All 3 lights are producing considerably more lumens than before. The new emitters aren’t high-CRI like the 219Bs I previously had installed, but they more than make up for it with the increased output. My TCR-01 triple with triple 219C and stock driver (not sure the about… my guess is maybe 2 amps), is producing a beam that is fairly close in brightness to a similar light with triple 219B and FET driver (both on IMR 18350).
I also like the low forward voltage on these emitters. Hopefully they will keep their max output in these lights longer than on the previous emitters or XPL HI. I’ve previously tried XPL HI in small 1x14500 zoomies at 3 amps. Output looks great initially, but they start to step down pretty fast as the battery depletes.
No, there is no test, many still confuse them with 219B (discontinued) and they will forever I assume since Nichia's specifications are still vastly not comprehended by most people. Yes undoubtedly you can check the datasheets and see the Vf is the same, but you know they will come in different Vfs bins anyway (3 bins: L1 L2 M1 , lower to higher voltage), so far the 219C is not disclosed as to what Vf is, by none of the sellers, so I would like to see a L2 vs L2 comaparison not something like M1 vs L1.
A few weeks ago I tried to order a few 4500K 90CRI V1's from illumination supply, asking them for cheaper shipping to Europe, but got no answer yet. If they ever make it to me I will do an output test. That only will give some information on one led, but it will give an rough indication of where the 219B V1 is situated between 219B and 219C.
I assume you mean the 4000K at Ilumn, not 4500K. Well you can get the other 219B-V1 from IOS, a few weeks sounds like a lot of time.
But anyway, even if the Vfs of the 219C and 219B-V1 are the same, that is, the voltage bins are the same, the thermal resistance is not the same, 219C being rated for a lower thermal resistance.
If you’d like I can order some from RMM for you and forward them like we did with the XP-L HI…?
I hoped for illumn.com because I like 4000k leds way better than 5000k. (apart from doing output tests I like building flashlights )
oops, I didn’t even notice his were 5000k. 4500k is my preference. I can order some from Illumn then? Shoot me a PM if you’re interested.
Now at http://intl-outdoor.com/nichia-nvsw219ct-r800-d260-bare-led-p-909.html
Hi djozz, regarding your 219B in the graph I see it hitting 600 lumens around 2.7A.
In your older test of the 219B here it is maxed out just under 600 lumens around 4A.
Is that because older graph shows lumen values with reflector losses and the graph on in this thread is lumen value without reflector?
Just to be clear these were the same binned HCRI 219B?
Thanks for your awesome work!
I'm not absolutely sure of the binning of the 219B from the graph of the OP actually, the numbers are from a test together with the new Oslon square, at a later date than my first 219B test. I think that the led came from the same batch that I used in the first 219B test, from Kaidomain so uncertain, but I ordered one or two from intl-outdoor as well later.
The method indeed changed since my first 219B test, that first test uses a ceiling bounce method that measures the output from a reflector placed over the led, which can lead to (up to 20%?) light loss, this is on top of calibration inaccuracies that come with the ceiling bounce method (my calibration light -D40A- is much more throwy than the small OP-reflector that is used over the led that was being measured, and the ceiling bounce method is sensitive to source distance and incoming light angle, I expect the test-led to come out a bit too low compared to the calibration light). The later test that is used in the graph in the OP above (and all other tests since then) measures bare led lumens in an integrating sphere.
Any idea if they are going to come out with 90 CRI 219C?
I’m really liking the current batch of 83 CRI 219C. I’ve installed 10 of them in various lights over the last few months. Beautiful tint. Nice beam pattern in zoomies. Low forward voltage makes for easy regulation especially in small 1x14500 EDC lights, etc.
Just last night I swapped the XPL HI emitters in one of my DQG Tiny III triples with 219C. Not bad. Though with a 3.8 amp 10x7135 driver at 100% power the triple 219C doesn’t throw as well as my other DQG equipped with triple XPL HI and a FET emitter…. running at 30% power.
Any good sources for the 4000K version of this LED? I like the 5000K, but would like to see the other as well… I found the Osram SSL’s on Mouser in 4000K, but cannot seem to locate these anywhere in anything other than 5000K
I haven’t seen any 4000K 219C but there is 4000K 219B V1 HCRI at Illumn.com here
The beamshots I’ve seen of the HDS lights with these 4000K HCRI 219B look really good.
Thanks for the great test, I need to get more familiar with Nichia emitters, and the graph made things much clearer.
Thanks for the explanation. I’ll keep in mind that your current tests are bare LED lumens.
I got my 219C 4000K's at Cutter, here: http://www.cutter.com.au/proddetail.php?prod=cut2744 - good price except for the shipping.
You should add a bunch of other emitters like the XPL and XML, need moar data!!!
Check his signature block at the bottom…. Djozz is a very prolific tester….
Hint: It says DJOZZ Tests in blue…
