If space was an issue, the board could use the SSU footprint and the cap be placed under the MCU. It would require the SU MCU package to be used and the pins to be bent in. When this is done, the MCU sits high enough to clear small 0805 caps underneath. Bent legs really make program clipping much easier.
Mike - yes. The large cap should remain before the diode, small cap after, at least that's what it's looking like. Think it gives us best of both. The test light continues to run smoothly. I got 3 lights now that had the problems and fixed now, all slightly different in cap values and placement, but all have a high value and low value cap, and the low value is after the diode.
The last driver, RMM's, is using a 0.1 uF cap, not 1.0 - DEL recommended the 0.1, though might not make much of a difference (I think).
Edit: that may be a viable option bout the bent pins technique. I am a bit concerned though bout the soldering of the MCU pins - certainly not as robust as when they lay flat on the pads, normally. I've done a few though and plan on doing more, and seems to be holding up well, but usually have to touch up a pin or 2 by hand after reflowing.
I vote for under the MCU.
It can even be on the opposite side of the PCB, but that would spoil the ‘single-sided’ feature. Vias also decrease decoupling performance somewhat.
The go-to size for local decoupling is 0.1 uF, but I think 1 uF will be fine as well in this case.
The tracks connecting pins 1 and 8 to this cap should be as short as possible and around 50 mils wide.
Atmel’s recommended decoupling is more concerned with noise emission from the MCU, but describes the basics well.
Atmel also recommends a series ferrite bead, this is not that applicable to our single supply MCU’s.
I’ve made a start and added a few extra features very difficult to get everything to fit.
Pin 3 has a 0.8mm via that leads to a 7135 that can be populated if wanted or the via can be used as switch in ect…
The pads to the right of the MCU are the extra cap. It could be moved to the opposite side later.
Don’t think I will be able to get the 85v foot print, but I’ll work on it more later.
DEL could answer this better, but I'd say probably not. This is more or less for us hackers , but, the chinese changed the BLF A6 driver anyway, so they did not 100% duplicate the wight FET+1 driver we started with. The soldering problems were not a design issue - it was a manufacturing/production/QC issue - sloppy and rushed basically, from the looks of it.
I work for a manufacturing company, and we insist our PCB suppliers test the boards before shipped to us. We will design/engineer/produce test fixtures for them to use in order to achieve as close to 0% DOA failure rate as possible. This is one way of doing QC - you want this done as close to the source as possible.
Sorry to say the way our group buys are done here are far from ideal in time and cost. This whole cycle of sample testing in the US is very inefficient and wasteful, but not much other choices unfortunately...
Let me verify the clearance under an 85 with bent pins tonight. I'm pretty sure that there is height for a 0805 1uF, but I haven't tested that idea yet.
Think it will depend on the voltage rating as well - higher the voltage, bigger the part. Think we use 16v rated caps in general. I believe it helps having a higher rating - not sure.
Gap under an 85 with legs pushed in most of the way to touching the chip is .028" to .029" (.72mm). My 1uF caps in an 0805 package (I believe 16V rated) measure .034" to .035" (.88mm). So it seems one could get away with a cap under the MCU as solder can quite easily bridge a .006" gap.
Or, the gap could be completely eliminated by slightly straightening the legs.
I've been away from this game for far too long; it's time to jump back in again. I had to force myself away just when things were getting interesting around here so that I could focus on some of my "other work".
The layout on that 85 driver I did really stinks...way too much space around the MCU, but I figured that it would be easy to flash the thing a million times. It looks like it also needed a bodge capacitor to work right. I guess I should have labeled it "alpha".
I haven't read through everything here, but a capacitor underneath the MCU sounds like a really bad idea unless you like tedious leg bending and soldering on every driver. I'm sure we can make it work without resorting to stuff like that.
Welcome Back!! You were missed! A scope on the signal lines sure would come in handy for this, I don't have the tools. Had success with the extra caps though, and definitely we've had some great help going on with texaspyro and DEL stepping in.
Not sure if you read it, but I finally got a good fix to the hi->OFF->moon flashing problem -- with that sequence, many times got a quick flash when moon mode starts. It looks like it's 100% resolved now in my latest firmware update - I solved it in code, not hardware, explained above somewhere... I've seen this flashy thing happen on power tail switch's too - wonder if it can be fixed in a similar way. Haven't looked into it yet.
On the high amp problem (caps), I believe TK has been getting the same reports coming in on her 25 based driver. Not sure if she is following this thread though.
Sort of agree - I'm leaning towards the bent pin solution being what we can do with our small runs, hobbyists, etc., but not a solution for large runs going forward.
If space is needed, I think it's good idea. I bend all my 85 pins anyway because they clip some much easier and the clip holds much more securely. If you haven't tried it, you should.
Another benefit of the bent legs is the MCU sits more proud and you can put resistor right up to the legs without programming clip interference.
I wonder if we really need LED - pads when the FET Drain tab available to solder to. It's nice to have a spot that is labelled and a spot that will fail first from mechanical stress, but is it really necessary when space is short?
Pyro1son,
The FET Drain Pad and LED _ Pad appear close to shorting with the pill. It's probably fine, but it looks like the FET could be slid closer to the ground ring edge.
I have dealt with the issue on a lot of drivers and have scoped it when it happens. Usually from a 3.8v-3.9v supply you'll see a 6V+ peak with 2V-3V peak-to-peak ripple (BAD). They actually run with a really dirty supply but when you get them up past 5.5V-6V it's going to have some issues. We are really pushing the MCU pretty hard switching these low-RDS but high-gate-charge FETs directly from the MCU pin, especially without any gate resistor. You can end up with either too little decoupling or if you have the cap. behind the diode you can get quite a bit of boosting. You also get a lot of ground bounce from the FET switching. There are a lot of layout tweaks that can make them run without expensive or extra parts.
You do absolutely need at least a small LED- pad if you want to use anything but an LFPAK56 FET. The SiR800DP, for example, does not really work without some extra exposed pad out the back. You can sacrifice it if you only use an LFPAK56, but I know that quite a few use the SiR800DP and it has proven to be a top performer.
Think you really need some pad space for LED-, at least with the SIR800DP FET - there's nothing on the FET there to solder to. That was my issue with Richard's board.
I’ve moved the FET away from the edge and the 2nd CAP from under the MCU as I just don’t like the Idea. I would rather just put both caps on the bottom of the board.
