Sold out! - GBGB: BLF-348 - Classy and Small 1xAAA Stainless Steel light, with Nichia NVSW219B-V1 R9050
ugh, don’t say that. :frowning: I only ordered one and it’s not here yet.
About tint……
Very neutral. Regular “neutral white” is nowhere near as neutral as this looks to my eye.
After this neutrals look like warm.
OTOH: reds dont pop-out so much as with neutral or warm white (if you prefer it like that).
I got one older Nichia but it is WW and High CRI.
With this and white wall, I have to say it is hard to detect any tint. It is mostly just white.
Of course, depends on your eyes… I recently did a test, Im tetrachromatic.
In short:
I REALLY LIKE THE TINT!!! 8)
Thats bad news. High CRI was the main reason I ordered this light. I havent got my light yet.
Well I’ll throw in the contrarian position, because I don’t know what these other folks are going on about. I also only bought one and its great - works flawlessly, beautiful tint, great CRI. And yes I have other 219b emitters for comparison. Its so good that I went back and ordered a couple more, for some reason.
You folks who haven’t received yours yet can stop worrying - the light is great.
You can't compare the CRI of 2 different tints without being subjective, the 4500K is simply another tint (nominal by the way), the CRI is not, you just totally prefer the 4500K. I am saying this because I go some NVSW219B-V1 in 5000K and it is unfair to call them as not having good CRI.
+1
Please note that the light uses the 219B-V1 emitter, that started shipping last spring, it’s 5000K as opposed to previous 219B with 4500K.
It’s a more natural color temperature and the typical CRI is 93 (previous version is 92).
@Ormbett: Don’t worry mate. It’s high CRI. All Nichia 219B are…
Thanks! After the recent posts in this thread I feel much better :slight_smile:
Ok, there was just some metal in wrong place behind the pill - working now.
Tested 4 side by side against white wall and there are some small tint differences. Some a bit warmer, some a bit cooler. You can tell when they are side by side but individually tested its hard to say which one is which…
I ordered one of these. Didn’t use a coupon (only knocked a few pennies off) as it meant I wouldn’t be able to use a few points I’d earned. The points took the price down to £3.40, happy enough with that. For once in my life I have more flashlights en route than I do knives…….!!!
What? Not on any of mine.
Switch your “Input format” (below the comment box) to “Advanced” and you can drag and drop a picture in (make it small first if it’s huge)
You also need to add more carriage returns and otherwise fiddle a bit if you’re writing text, usually it’s not worth doing, but to post a pic, try that.
Choose the “other” checkout, either with or without PayPal, I forget — one but not the other checkout button lets you uncheck that tracking option
I think I’d be more likely to drill the clip as my chubs barely fit the button as it is.
Is this what you were referring to:
Wait, did you get that hole on one of the lights you rec’d from this group buy?
None of mine came like that. Nicely done, however it was done.
It’s doable — resembles the hole that CK drilled out last year with a ball mill
Yes, it was already in/on the light.
It’s funny. I bought a bunch of aftermarket clips and even tried a preon clip. I think I like the stock one best. Any one want some Cnq aftermarket clips?
:slight_smile:
Mine came after about 3 weeks. Very nice.
I agree but only partially.
IMO colors look “correct”. On the other hand, they are all a bit more towards “greyish” or something like that.
I think it may be because of higher K but I´m not sure.
Definitely looks a little different than with warmer white Nichias.
One of mine has almost completely “tintless” beam. I cannot honestly tell any colors from the bare beam when pointing at something white and this is new to me 8)
driver
Rs=0.5Ohm
