Very neutral. Regular “neutral white” is nowhere near as neutral as this looks to my eye.
After this neutrals look like warm.
OTOH: reds dont pop-out so much as with neutral or warm white (if you prefer it like that).
I got one older Nichia but it is WW and High CRI.
With this and white wall, I have to say it is hard to detect any tint. It is mostly just white.
Of course, depends on your eyes… I recently did a test, Im tetrachromatic.
Well I’ll throw in the contrarian position, because I don’t know what these other folks are going on about. I also only bought one and its great - works flawlessly, beautiful tint, great CRI. And yes I have other 219b emitters for comparison. Its so good that I went back and ordered a couple more, for some reason.
You folks who haven’t received yours yet can stop worrying - the light is great.
You can't compare the CRI of 2 different tints without being subjective, the 4500K is simply another tint (nominal by the way), the CRI is not, you just totally prefer the 4500K. I am saying this because I go some NVSW219B-V1 in 5000K and it is unfair to call them as not having good CRI.
Ok, there was just some metal in wrong place behind the pill - working now.
Tested 4 side by side against white wall and there are some small tint differences. Some a bit warmer, some a bit cooler. You can tell when they are side by side but individually tested its hard to say which one is which…
I ordered one of these. Didn’t use a coupon (only knocked a few pennies off) as it meant I wouldn’t be able to use a few points I’d earned. The points took the price down to £3.40, happy enough with that. For once in my life I have more flashlights en route than I do knives…….!!!
Switch your “Input format” (below the comment box) to “Advanced” and you can drag and drop a picture in (make it small first if it’s huge)
You also need to add more carriage returns and otherwise fiddle a bit if you’re writing text, usually it’s not worth doing, but to post a pic, try that.
It’s funny. I bought a bunch of aftermarket clips and even tried a preon clip. I think I like the stock one best. Any one want some Cnq aftermarket clips?
IMO colors look “correct”. On the other hand, they are all a bit more towards “greyish” or something like that.
I think it may be because of higher K but I´m not sure.
Definitely looks a little different than with warmer white Nichias.
One of mine has almost completely “tintless” beam. I cannot honestly tell any colors from the bare beam when pointing at something white and this is new to me 8)
I have two lights, one is throwier than the other, the other is slightly warmer, i think, I will have to have a closer look where that comes from, but I do not expect very precise engineering on a 7 dollar light :party:
Btw, this $7.71 Fasttech light has the exact same build as the gb light (but with a -not fake- Cree XP-E led): https://www.fasttech.com/products/1601/10008272/1741600-mini-pen-style-1-cree-r3-1-mode-240-lumen-cool
