You have a point there: thanks to the light being all copper, it can be DIY'ed too using old-school plumbing: grind the lanyard 'ears' off the tail, remove the switch, and using a small blow torch, solder a small copper round in with a (fairly long) spring on top.
good option, but it would not be a tailstanding clickie
another possible way to get to a tailstanding clickie Tool is to homebrew a taller copper collar from a bit of pipe, that could be sized to slip between the ears and the rubber cap, and attached in a temporary way with glue. The collar could also be made in 2 sections, to stick up like the ears.
The Maratac does not tailstand stably, with the stock clip in cap position,
requires trimming the clip tip:
otoh, the magnetic twist cap for the tool is tall enough for the pocket clip not to interfere with tailstanding. I would like that tailcap option in copper, but again, its not a tailstanding clickie solution.
Now, 2 days later, it is on Amazon in the N219, No PWM, MLH, 18-3-80 lumen sequence. No Firefly, no tailstand. Read the post above for a 20% discount code.
And you can get in on the Rey Light group buy that is supposed to have LMH 1-18-80 modes with the N219, No PWM, no tailstand.
And there is a Titanium version planned, that “might” tailstand. As the Lumintop poster said:
And if you want a really bright version, with LiIon, you can get the custom driver equipped ToolVN
So 4, count em, 4 different ways to spend your money on Tools
