Thanks ImA4. Here is a link to the build thread. Not much response to it though, I guess worklights are not as interesting as flashlights
Now that you point out the heat spreaders I notice them.
Also, I have run those bulbs alongside of the versions with the heavy heat sinks. Each seem to run at about the same temperature after a few hours.
I have confirmed the 60W LED bulb in the twin pack for $3.98 with the 4.57 year lifespan is the same exact bulb as the 99 cent bulb with the 1.8 year lifespan. It is the same exact bulb inside and out.
That 99 cent bulb will be available again on Black Friday, probably at all the Lowes.
Holy crap this is crazy! I didnât know any of this was going on! 99¢ led bulb with life of an incandescent?! This is madness! This is the future of led bulbs! (haha)
Too bad there isnât any loweâs close by here; mostly home depots only.
dchomak can you do a flicker test of the cheap 99¢ led bulb? The power supply looks extremely simple (for âdecentâ led bulbs) so it might flicker. You can look at it closely with a camera to see if it flickers. Or you can shake it or shake something in front of it.
Also hereâs something interesting about Loweâs: I found out that Loweâs sells mostly Cooper (Eaton) Wiring Devices (switches, receptacles, GFCIs, etc), for the same price as Home Depot sells Leviton!
But I think Cooper Wiring Devices are better than Leviton Wiring Devices. I was impressed with the features on the Cooper receptacles. They have a âScrew-Catchâ˘â and they have a built-in wire stripper and looper and bla blaâŚ
Also the switches are better because they donât have that problem of tending to want to be on. With the Leviton switches, they feel like they want to be on. Flicking them on makes a nice flick sound, like the switch is enthusiastic about it, but flipping them off makes a quiet flup like they donât want to be turned off. The cheap generic Jasco/GE switches sold at Walmart are even worse. The old Leviton switches didnât have that problem but the new ones do. Also the Leviton have a derp with the ground screw⌠they _screw_ed it up. The two nubs that hold the wire loop are too close together making it almost impossible to fit a loop in there, so you either have to bend a nub down or rotate the loop in an improper position.
bla bla bla you get it, The wiring devices loweâs sells are cooper and I think they are better than Leviton that home depot sells, and for the same price.
This time I got a great deal on some incandescents :bigsmile:
250 Watt Infra Red. (Heat Lamps)
Then I found more of the 75W equiv LED bulbs
50 cents more per bulb than the last store but when you want need them, the extra money is easily justified
Then I came across this deal. Unfortunately someone else beat me this time.
Thatâs a 24 inch cast iron pipe wrench that normally would be $24.98. That is a BIG wrench. Here is a picture of the replacement model with my SK68 sitting on top of it for scale. And this picture is in perspective. The head is actually bigger than it appears in this photo. Oh well, I canât win them all.
Well, as far as these LED bulbs go, it takes a lot of bulbs to fill up those 1 to 7 socket converters.
For instance, I am about to replace an antique 4 foot florescent light fixture in my in home shop with an old bathroom light fixture that has 8 sockets. One of these. The gold ones also happen to be 4 feet long
Once I get that up I will either fill it with 8 of the bulbs I got at Lowes. If that doesnât give me enough light, I will try 2 of the 1 to 7 converters at each end and fill them up will bulbs also. I have the option of installing up to 20 bulbs over my bench. See what I mean, they can get used up quickly.
BTW, 20 - 800 Lumen bulbs would give me 16,000 Lumens. That is probably to much. If I use 20 of the 450 Lumen bulbs (that I paid 42 cents each) We are talking 9000 Lumen. Maybe that is more reasonalble.
Another way to reach 9000 Lumen would be skip the 1 to 7 converters and use 8 - 1100 Lumen bulbs.
See, all kinds of options with this kind of setup. Only when using lots of cheap bulbs (LOCB) do these options become available.
I was at Lowes today (for roofing sealer⌠but I had to check out the deals while I was there).
They have 36-packs of Rayovac AA alkaline for $5.99. Nice deal.
Just got out of Lowe's. No sign of the $0.99 bulbs; no idea where the display even was! Wasn't at my usual Lowe's though and think we may drive to another. Did pickup a nice deal on plastic shelving units.
I went to HD first, only because they always have free donuts and coffee first thing on BF.
Then I went to Lowes. They had 2 displays of the 99 cent bulbs. Everybody was taking 20 to 30 bulbs at a time. I got there are 6:30AM, 30 minutes after they opened up and they were halfway thru the 912 bulbs they had put out
The base of the 60watt equivalent LED light runs hot. Am using 2 lights in the kitchen ceiling. Is there any fire danger running the lights in closed, cramped space?
No, just short life.
How hot is it? Is it hot enough to hurt your fingers after a short moment of touching it?
The Philips basic bulbs get that hot but they are rated for 10 years or something like that.
It gets hot enough not to touch it only a few minutes after turn on. Great relief that only the life is affected. Maybe this is the reason the warranty is only 4 yrs. Thanks for response.
Incandescent lamps get a LOT hotter. Since LED lamps are more efficient, you can use a 60w LED lamp in a fixture rated for 60w incandescent max and still have some safety margin. A 9w LED lamp is way under the limit.
I have some of each and externally they run at about the same temperature. I suspect though that internally the 99 cent ones would be hotter. Actually I know they run hotter because without a good thermal path there will be a larger temperature gradient from the source of the heat (the LEDs) to the outside of the bulb.
Ability to heat sink well does nothing to reduce the total heat emitted; it only allows the bulb to shed that heat more efficiently. Given all else being the same the total heat seen by the fixture will therefore be the same either way.
It is entirely safe to use an LED bulb with the same output equivalency rating in an Incan fixture, although enclosed fixtures may reduce LED bulb life considerably. Incans can withstand almost any sane level of heat but LEDâs may not like the same situation. But for this kind of price theyâre worth a shot!
