This batch should be without that hole. I asked for it, but Factory refused to do it.. (probably a tooling issue - or just too costly to manufacture)
That being said, they may have had some spare bodies from some earlier batch. (just assembling them with the Nichia emitter). If you got one with a hole, be happy with it. If not, you got what we ordered. :)
None of the samples and all of my lights I have opened/checked have had the hole.
As for the FT light being the same, that's mostly correct. However, the switch might be different (more loose, rattling, softer spring). That was one of the changes the factory did for us. :)
Ordered when code was first provided and received my 5 today. All work well, leds are centered. No hole. Impressed with the quality of machining especially at this price point. Joints are nearly invisible though some are better than others. My first Nichia of this type and I like the tint, color rendition. If it sounds like I’m happy it’s ’cause I am.
Thanks the, nice job.
Yeah, that’s the experience I’m having NightSpy. As long as I’m holding it in my hand, it doesn’t get unbearable and I wouldn’t want to set it down with it on using the 10440.
I tried a Energizer lithium cell in it and to me, it’s almost twice as bright using the 10440.
