So ā itās a tangent, but if anyone has suggestions about what would be a good host for a triple 219c ā please start a thread about that.
Something with a whole lot of extra heat sinking, I guess?
I have been using one of the Mtnelectronics FET +7135 drivers in a triple with no apparent issues. The only difference is that I am using an 18350 tube, so I only draw 9A or so maxā¦. With the 219C it gets hot, but I do not seem to have the other timing related issues.
On the other hand, I also built a 18350 219C triple with a 3A Qlite, still a good amountof light, and nowhere near as much heatā¦
Perhaps a X6 with a copper heat sink? Or did you mean a tube light?
just hoping someone will start a thread for it elsewhere, this oneās not the place to go off track
lol, then why not just start one silly.
Now that I know what I know. I may go ahead and order the convoy s2 host that goes along with the spacer I already have. The spacer really seems an important factor. Chopping it to fit in the a6 seems like the wrong move. (But I may get impatient and try to finalize this thing. I want some beam shots!) RMM already builds an s3 tube triple so it must be working well for him.
And thanks for your help Tom E! The only thing I have any business doing is soldering - and even that has been a learning curve! I really didnāt do a lot of research before I started modding this light. I emailed RMM one time but really didnāt read many threads on triples before starting.
EDIT:
Hi have the longer copper spacer (for the S2) and put it in a S8 (which used the same pill and reflector as the S2). It seems to handle the heat much better than the S2+ spacer I used for the BLF A6 triple I madeā¦much better. The BLF A6 triple got hot much faster than the S8.
QUESTION! Does the shorty tube fit a protected 18350 cell? KeepPower P1835C 18350 900mAh geschĆ¼tzte wiederaufladbare Li-Ion Batterie Sale - Banggood Deutschland sold out-arrival notice-arrival notice
Nope!
I have tested that particular cell and it is too long for the short tube.
Wrathbringer27:QUESTION! Does the shorty tube fit a protected 18350 cell? KeepPower P1835C 18350 900mAh geschĆ¼tzte wiederaufladbare Li-Ion Batterie Sale - Banggood Deutschland sold out-arrival notice-arrival notice
Nope!
Are you able to recommend me a capable battery for the shorty? I wan max capacity and max discharge. I dun care if it protected or not! Thanks!
RollerBoySE: Wrathbringer27:QUESTION! Does the shorty tube fit a protected 18350 cell? KeepPower P1835C 18350 900mAh geschĆ¼tzte wiederaufladbare Li-Ion Batterie Sale - Banggood Deutschland sold out-arrival notice-arrival notice
Nope!
KeepPower (unprotected), Efest, NiteCore and Xtar are all good choices.
Wrathbringer27: RollerBoySE: Wrathbringer27:QUESTION! Does the shorty tube fit a protected 18350 cell? KeepPower P1835C 18350 900mAh geschĆ¼tzte wiederaufladbare Li-Ion Batterie Sale - Banggood Deutschland sold out-arrival notice-arrival notice
Nope!
These are 18350 cells right? Not 16340?
RollerBoySE: Wrathbringer27: RollerBoySE: Wrathbringer27:QUESTION! Does the shorty tube fit a protected 18350 cell? KeepPower P1835C 18350 900mAh geschĆ¼tzte wiederaufladbare Li-Ion Batterie Sale - Banggood Deutschland sold out-arrival notice-arrival notice
Nope!
Yes, all 18350.
Wrathbringer27: RollerBoySE: Wrathbringer27: RollerBoySE: Wrathbringer27:QUESTION! Does the shorty tube fit a protected 18350 cell? KeepPower P1835C 18350 900mAh geschĆ¼tzte wiederaufladbare Li-Ion Batterie Sale - Banggood Deutschland sold out-arrival notice-arrival notice
Nope!
Yes, all 18350.
THANKS!
dudunphy: hank:So ā itās a tangent, but if anyone has suggestions about what would be a good host for a triple 219c ā please start a thread about that.
Something with a whole lot of extra heat sinking, I guess?Now that I know what I know. I may go ahead and order the convoy s2 host that goes along with the spacer I already have. The spacer really seems an important factor. Chopping it to fit in the a6 seems like the wrong move. (But I may get impatient and try to finalize this thing. I want some beam shots!) RMM already builds an s3 tube triple so it must be working well for him.
Hi have the copper space in a S8 (similar to a S2). It seems to handle the heat much better than the S2+ spacer I used for the BLF A6 triple I madeā¦much better. The BLF A6 triple got hot much faster than the S8.
Thanks! So youāre saying that you built an s8 triple or you used the spacer from one? I wonder what the difference is.
Or did you mean you used the S2 spacer (the long one ā not the short S2+ spacer) and put it that spacer in a Convoy S8?
Hi guys, Iām sorry I was not clear. I used the longer spacer for the S2 and put it in the S8 host. The S2 and S8 used the same reflector and pill.
hank:Or did you mean you used the S2 spacer (the long one ā not the short S2+ spacer) and put it that spacer in a Convoy S8?
The convoy must be better at shedding heat. Must be the pill. It looks more heavy duty than the shelf in the a6. Thanks again tristanxoxo!
If a light gets hot faster at the same drive current as another with a similar mass pill it means itās conducting heat better not worse.
