No, just short life.
How hot is it? Is it hot enough to hurt your fingers after a short moment of touching it?
The Philips basic bulbs get that hot but they are rated for 10 years or something like that.
It gets hot enough not to touch it only a few minutes after turn on. Great relief that only the life is affected. Maybe this is the reason the warranty is only 4 yrs. Thanks for response.
Incandescent lamps get a LOT hotter. Since LED lamps are more efficient, you can use a 60w LED lamp in a fixture rated for 60w incandescent max and still have some safety margin. A 9w LED lamp is way under the limit.
I have some of each and externally they run at about the same temperature. I suspect though that internally the 99 cent ones would be hotter. Actually I know they run hotter because without a good thermal path there will be a larger temperature gradient from the source of the heat (the LEDs) to the outside of the bulb.
Ability to heat sink well does nothing to reduce the total heat emitted; it only allows the bulb to shed that heat more efficiently. Given all else being the same the total heat seen by the fixture will therefore be the same either way.
It is entirely safe to use an LED bulb with the same output equivalency rating in an Incan fixture, although enclosed fixtures may reduce LED bulb life considerably. Incans can withstand almost any sane level of heat but LED’s may not like the same situation. But for this kind of price they’re worth a shot!
They may actually last longer than 1.8 years. Remember I proved, at least to myself, that the 2 pack of bulbs at 2 for $3.98 are the same exact bulb inside and out and yet they are rated at 4.57 years.
BTW, make no mistake, that is 4.57 years. Not 4.56 or 4.58.
That just reminds me that I should take all of that stuff with a grain of salt
As to my post #154 where a massive heat sink version of the 1100 Lumen bulb had the same exact lifetime as a version with no heatsink just shows that a lot of these printed specks are just a “copy and paste”
In another thread Found: $1 LED light bulbs at Dollar Tree I made a passing inference to this with this picture. 3 manufacturers of 3 different 40W equivalent bulbs, Osram, CREE and Greenlite. All three packages had the same EXACT specs.
450 Lumens
72 cents yearly operating expenses
22.8 years service life
6 watts.
That is not a coincidence, it’s “copy and paste”
Went to do some plumbing work on a good friends house across town today. Parts were to come from Lowes so as we hit the door I mentioned the $0.99 lights and how we’d missed them (I’ve been sick a couple days, much better now). Then two displays chock full of them appear right at the front of the store :bigsmile: Another guy was looking at them as I explained Dchomak’s tear-down with these being the same as the “better” ones. I didn’t need many so I got 2, my friend got about a dozen as did the guy looking at the lights who joined our conversation.
Oh, and the plumbing went smooth needing only one extra trip to get a copper fitting I was going to reuse but couldn’t unscrew from the old regulator. 3 wins for me today, quite a lucky day indeed!
LOL,
I started reading your post and when I got to the end of the second line I realized it didn’t rhyme. That’s when I had to start all over again
An advantage of the 99 cents bulb is that they a very light weight. There are certain fixtures that I have that don’t like heavy bulbs.
OMG OMG OMG! GREEN WIRE CONNECTORS! :heart_eyes:
They are very useful and make any electrical box much tidier. Unfortunately they are always expensive.
Too bad the nearest Lowe’s is a little too far away…
I wonder how long those prices will be around. Maybe they’ll survive until we are able to go to Lowe’s.
I like the feed-through greenies with a hole in the center- they really make for a tidier box.
USA NEC now requires either a green wire-nut or a mechanical crimp sleeve tying all the grounds together in boxes with a single wire going to the switch or outlet ground terminal. An added non-feedthrough pigtail wire may go over the limit for wires allowed in that box while the feedthrough wire-nut won’t.
With a green grounding wire connector, in a box where you have a cable in and cable out (line and load) and a metal box and a device, you can ground everything with no extra pigtails. Just wrap one wire around the ground screw of the box, and then connect it to the other wire with the other wire going through the connector to the device. You actually only connect two wires but it does the same thing as having two pigtails therefore four wires.
Some deals I saw at Lowes. Mostly stuff I needed to rewire the lights on my trailer.
These are incans, but I could plug in LEDs later
These were 7.98, then 3.99, then 1.98 and then I came along. Got it for $1.58
This is the water proof mounting hardware for the trailer connectors.
Black electrical tape would be handy for taping up connections. 30 cents a roll is a steal!
Needed some tiedowns for stringing the wires under the trailer
In case those weren’t big enough, I got some of these. They are HUGE
3 inch convex mirror to see around all that stuff I’ll be dragging behind me.
Then a couple of months ago, Lowes cleared out a lot of sockets for cheap. So cheap at first that they changed their mind and raised the price a bit. Well alot of that stuff didn’t sell at that higher price. Here is a box full of what was left and priced at 25 cents per item.
Here is what I picked out for myself. 25 cents each!
Swivel sockets, claw feet and a 3” 1/4 inch extention
