Incandescent lamps get a LOT hotter. Since LED lamps are more efficient, you can use a 60w LED lamp in a fixture rated for 60w incandescent max and still have some safety margin. A 9w LED lamp is way under the limit.
I have some of each and externally they run at about the same temperature. I suspect though that internally the 99 cent ones would be hotter. Actually I know they run hotter because without a good thermal path there will be a larger temperature gradient from the source of the heat (the LEDs) to the outside of the bulb.
Ability to heat sink well does nothing to reduce the total heat emitted; it only allows the bulb to shed that heat more efficiently. Given all else being the same the total heat seen by the fixture will therefore be the same either way.
It is entirely safe to use an LED bulb with the same output equivalency rating in an Incan fixture, although enclosed fixtures may reduce LED bulb life considerably. Incans can withstand almost any sane level of heat but LEDās may not like the same situation. But for this kind of price theyāre worth a shot!
They may actually last longer than 1.8 years. Remember I proved, at least to myself, that the 2 pack of bulbs at 2 for $3.98 are the same exact bulb inside and out and yet they are rated at 4.57 years.
BTW, make no mistake, that is 4.57 years. Not 4.56 or 4.58.
That just reminds me that I should take all of that stuff with a grain of salt
As to my post #154 where a massive heat sink version of the 1100 Lumen bulb had the same exact lifetime as a version with no heatsink just shows that a lot of these printed specks are just a ācopy and pasteā
In another thread Found: $1 LED light bulbs at Dollar Tree I made a passing inference to this with this picture. 3 manufacturers of 3 different 40W equivalent bulbs, Osram, CREE and Greenlite. All three packages had the same EXACT specs.
450 Lumens
72 cents yearly operating expenses
22.8 years service life
6 watts.
That is not a coincidence, itās ācopy and pasteā
Weāll probably be going to Loweās today to get a GE ground bar kit because HD doesnāt sell them in storesā¦ so maybe Iāll find those 99Ā¢ illuminators.
Went to do some plumbing work on a good friends house across town today. Parts were to come from Lowes so as we hit the door I mentioned the $0.99 lights and how weād missed them (Iāve been sick a couple days, much better now). Then two displays chock full of them appear right at the front of the store :bigsmile: Another guy was looking at them as I explained Dchomakās tear-down with these being the same as the ābetterā ones. I didnāt need many so I got 2, my friend got about a dozen as did the guy looking at the lights who joined our conversation.
Oh, and the plumbing went smooth needing only one extra trip to get a copper fitting I was going to reuse but couldnāt unscrew from the old regulator. 3 wins for me today, quite a lucky day indeed!
LOL,
I started reading your post and when I got to the end of the second line I realized it didnāt rhyme. Thatās when I had to start all over again
An advantage of the 99 cents bulb is that they a very light weight. There are certain fixtures that I have that donāt like heavy bulbs.
OMG OMG OMG! GREEN WIRE CONNECTORS! :heart_eyes:
They are very useful and make any electrical box much tidier. Unfortunately they are always expensive.
Too bad the nearest Loweās is a little too far awayā¦
I wonder how long those prices will be around. Maybe theyāll survive until we are able to go to Loweās.
I like the feed-through greenies with a hole in the center- they really make for a tidier box.
USA NEC now requires either a green wire-nut or a mechanical crimp sleeve tying all the grounds together in boxes with a single wire going to the switch or outlet ground terminal. An added non-feedthrough pigtail wire may go over the limit for wires allowed in that box while the feedthrough wire-nut wonāt.
With a green grounding wire connector, in a box where you have a cable in and cable out (line and load) and a metal box and a device, you can ground everything with no extra pigtails. Just wrap one wire around the ground screw of the box, and then connect it to the other wire with the other wire going through the connector to the device. You actually only connect two wires but it does the same thing as having two pigtails therefore four wires.
Some deals I saw at Lowes. Mostly stuff I needed to rewire the lights on my trailer.
These are incans, but I could plug in LEDs later
These were 7.98, then 3.99, then 1.98 and then I came along. Got it for $1.58
This is the water proof mounting hardware for the trailer connectors.
Black electrical tape would be handy for taping up connections. 30 cents a roll is a steal!
Needed some tiedowns for stringing the wires under the trailer
In case those werenāt big enough, I got some of these. They are HUGE
3 inch convex mirror to see around all that stuff Iāll be dragging behind me.
Then a couple of months ago, Lowes cleared out a lot of sockets for cheap. So cheap at first that they changed their mind and raised the price a bit. Well alot of that stuff didnāt sell at that higher price. Here is a box full of what was left and priced at 25 cents per item.
Here is what I picked out for myself. 25 cents each!
Swivel sockets, claw feet and a 3ā 1/4 inch extention
Just some stuff I found walking around Lowes.
BTW, most of this stuff I have no use for, Iāll buy anything IF itās cheap enough. And the other day I was thinkingā¦ā¦ā¦ā¦ā¦ Because I usually buy stuff I need at really really good prices, I can afford to buy stuff I donāt need at really really good prices. :laughing:
Filament bulbs of all types. I did NOT buy any of these
These are back on sale. This was the last day though, they are no longer available at that price.
A few of the Utilitech lights are on clearance at some stores. 3C 500 lumen $8.00, 9AA 1000 lumen $10.00.
Got a chance to mess with these today. The 3C 500 lumen is pretty nice and the build quality is much nicer then any of my Defiants. Great deal for under 8 bucks!!! I would pass on the 9AA 1000 lumen triple model but itās still decent for only 10 bucks.
