Interesting- I just yesterday got 2 Ultrafire *3600 mah Blacks yesterday -they were available locally by mail and they take much longer to charge than the Ultrafire Blue that shipped with the Torch and charger from Ebay-
Also un-scientific ( and from a novice about all this ) - they also last longer but these have an Ultrafire Name Logo etched into the bottom Negative plate of the battery-not from Ebay. But not as bad as some have said- dealer said they were from the Ultrafire Rep.
I ordered a Redilast 2900mah just to see what a real high capacity, honest rated battery is like- not from Ebay.
eBay is such a gamble hey, I’ve got so many dodgy torch deals off eBay I rather pay a bit more else were, but many people say ebays great… I’m going to get some red list batteries still undecided on 2600, 2900 or back order some 3100, I know you can get the same batteries unprotected cheaper but I like the idea of them being protected
I’ve got some the take 900 mAh out of 2400 mAh and suffer from voltage sag but the protection circuits work well every time so I gave them to my old man
I want to try out those 3000mAh Ultrafire flames but the nearly 12 bucks cost at MF puts me off (I'd rather spend $1.50 and get the XTAR 2600, but then i have over 20pcs of them so i don't think i need more LOL!).
Kaidomain is even better, 16 bucks. :) I can get Panny 3100s for below 20 bucks!
My 8pcs of TF Flames 2400 all tested to be 2200mAh range @ 1A though.... 4 more in transit. :)
It's $13.50 shipped here, no worries on the declaration as i'd imagine the import taxes are super there, "you can buy 6pcs and still won't feel a pinch", drop Serena an email. :) Add $2 for registered but that's not necessary.
They are basically protected Sanyos, with a PCB current limit of ~ 5A. Slightly higher resistance than the unpro Sanyo 2600 due to PCB but not an issue in majority of the usage.
Where did you get the Trustfire 3000mAh flames? They are different in wrapped as compared to the 2400mAhs.
That’s kind of my point but each to there own, I guess they have a bad rep cause of DX and eBay but I’ve tested mine to 5 amp draw and they will do it they are ok for cheapies, I only have 3 single cell lights (ive given 2 away) and 2 are under performers I’ve tested them with a few cheap brands so now I’ll test the with some top shelf batteries if they draw the same there abouts it’s the drivers not the batteries, so then I’ll swap drivers and start the testing again. So I will say these are geat multi cell batteries great for torches that use two or more batteries at once, then once I’ve done more testing I’ll say yes or no to single cell and dd lights others say they are fine and test on my charger say they will give 5 amps and the protection does not trip but I’ll would like to know myself. If that makes sence as right now I know mine take good mAh still for old used batteries and give good run times in my multi cell lights
You mean TF Flames, right? Everything I have read has said that the UF's do not come close to matching their rated capacities. I have only seen one mention of testing the 3000 mah TF FLames. Still looking for it.
Yes. I read that recently also somewhere that the 3000mah Trustfires are about 2600 mah, tested slightly better than the consistently rated Trustfire Flames that usually test at 2450mah.
Wonder why they didn't just call them Trustfire Flame PLUS with extra 100-150 mah.
I've not read anything good about Ultrafires - but the ones I got from 200 miles away in 2days are good compared to the Blue Ultrafires.
As I said these are rated *3600 mah( ridiculous ) but have an engraved Ultrafire logo on negative end plate- anyone seen that before ?
Maybe we should have a list of USA Suppliers- for when people need the them quickly- but I know this is an international Forum.
For me some times the USA cost more to ship to Australia so a good hon kong or china online store is priceless and shipping time is about the same.
I have some more tables to post when I get home from work as I did not have time to post last night.
Is most people understanding the tables ? I’ll do a key also when I finsh work if that helps but the main ones to look at is far left charge time, accu V battery or batteries voltage and mAh how long the battery will last
#6 mAh test @ 1amp with an internal resistance of 160 milliohm,s
start of the test @ 1 amp
end of the test @ 1 amp
3.5v to 4.19 v @ 2413 mAh not bad in my book, i have pulled apart a couple more to check they have two mosfet's on the pcb,s (IC's) and they do, i also have given my old man 4 x trustfire flames that all tested very close or above 2400 mAh, i will test the new trustfire flames i have coming to make sure they are on par with my used ones i have tested.
tonight i will order some claimed topself batteries and when they get here i will compair tail cap readings to these used trustfire flames and post the results on here and maybe next week ill get some xtar,s and compare them also
trustfire flames brought from manafont get my thumb,s up
i have brought 2 x redilast 2600 2 x hi-max 2600 and 2 x solarforce 2400 batteries to compair tail cap readings to, ill update this post over the next couple few weeks
