deal alerts: @ ebay, all flashlights below $5
I have the Soshine ones from FastTech, they seem to be good, I do not know if they are the best though.
The 10mm sinkpads are too small for these, there is only a shelf and they would need to be about 2-3mm wider, thus the filing down of the 16mm… Either way, good little light, even stock, for the money…
Correction, THESE are the LiFePO4 10440’s
Aha good point, i didn’t think about the shelf, but you right then starting from 16mm is the only way.
EDIT
I will probably pick up some of those Soshine cells next time i order from fasttech, do you know any small cheap good chargers for them? I can use my opus but i am thinking for gifting.
No, that is the only problem, for LiFePO4’s there are no good small cheap chargers… Perhaps the Nitecore D2? Or the Xtar WP2H
I updated the post above, the first ones I linked were the 3.7V, I have the second ones, the 3.2V
That is to bad, i will search for one.
For 4.2v 10440 we have the cheap and excellent Xstar MC0, i hope one for LiFePO4 will turn up.
Mine has a gap in the key chain eye, so they gave me a full refund.
I just ordered one of these for US $3.44. I figured that a Nichia upgrade might be all this needs.
It looks kinda like a 14500 version of the Sharp Eagle ZQ-SH-05
Or a SingFire SF-361 clone.
http://www.ebay.com/itm/121796355784
Once you receive it, can you let us know if it takes 17mm driver or 14mm driver? Thanks.
Assuming I have the seller right, and I’m pretty sure I do, 4-cn922 sent me one with an lb emitter, but solid pill, driver seems decent, switch seems nicer than others, too. Nicely finished c8.
I bought two C8s from securityingstore (http://www.ebay.com/itm/331455918001?\_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT). The best thing is that they take the standard UF brass pill, e.g., the one sell by FT. It will make a very good host for the cost (<$5).
I think they are the same as yours.
Thought that TomTop’s 18650 might turn in the vein of Hugsby’s, alas it did not, waste of money, made pictures of it, in short - plastic reflector, dirty lens, two bright blue LED’s on each side of the switch, didnt try out charging feature(bought it for slightly above 5$ with car and wall charger, without them it costs below 5:money_mouth_face:, battery tube fits my red Convoy S2+ and cheap C8 with deep reflector, came with pocket clip which scratches light easily, scratched my Convoy too, has rust to it, took it apart, surprise - LB star with probably fake XP-E, sits on a shelf.
Pictures - http://1drv.ms/1O3BVxS
Item - http://www.ebay.com/itm/171640191679
I’ve been reading this forum quite a bit today and joined. I’m curious, I read that as of earlier this year the LB knock off emitter lights began to severely outnumber the amount of genuine cree (and sometimes possibly rejected cree emitters) on the $5-10 lights on Ebay / Aliexpress. Is it pretty much impossible to find actual Cree flashlights now in this price tier? So far it’s been like looking for a needle in the haystack, some Ebay listings it’s easy to tell, most it isn’t since the Ebay sellers use fake stock photos of the light in use. Note that I’m primarily looking at 18650 battery flashlights.
Look into buying a Convoy (S series/C8). A bit more than $10, but vastly superior in every other aspect. No worrying about fake emitters.
Yeah, was looking into that, looks decent, apparently Simon is the main dealer to go to for those? I’m pretty new to all of this besides some lurking here and there. Will have to think about that one.
I was mostly glancing at the <$5 18650 lights (I extract cells from laptops from time to time) figured it might be neat to try some out and maybe modify. I noticed people tend to change out the emitter and driver with something else and just use the shell as a host.
I just skimmed through quite a few pages of Ebay(US) listings and come up with around 30ish variants of different lights at $5ish and under shipped. I would link them all but it would be a bit too cluttered / spammy. So here’s a link to a paste of them, note that there could be a few duplicates in there.
These in particular seem to be very widespread online in different knock off brands from what I’ve noticed:
http://www.ebay.com/itm/3000LM-Vander-CREE-XPE-Zoomable-Focus-Aluminum-3-Mode-LED-Flashlight-Torch-BJ-/161914559394?hash=item25b2dc1ba2:g:NWgAAOSwNphWah4T
Also ran across a ‘C8’ type.
http://www.ebay.com/itm/Multi-purpose-Black-300Lm-CREE-Q5-LED-5-Mode-Bright-Flashlight-5-Output-Levels-/271860326044?hash=item3f4c235e9c:g:ZS0AAOSweW5VSCvc
I would avoid those named SkyWolfEye or Vander. Quality might be to bad to be of use. E.g. those tubular ones (“S5”) have a loose pill, very thin tubes and poor threads. Models with side switch are often not that easy to modify. You should decide if you really want a zoomable light, it sounds promising but those cheap ones have their downsides. Even if you buy it only as a host, below 5$ it’s hard to find decent quality. Those C8 with an older Cree XR-E could be worth a try. Emitter and driver swap should be easy and deliver what you want.
Yeah, I figured the zoomable thing was a gimmick, I watched a variety of youtube videos and some lights would zoom alright and some would not or made rather loud clicks when doing so. Furthermore, apparently you can leak water into the unit and kill the light when doing that, at least with the cheapies. Still it would be neat to find something semi usable / moddable, it’s a bit of a shame that I came around so late when everything is now using the ‘lattice bright’ emitter so they’re all going to have that terribly dim pale blue light I imagine.
I received it. It’s similar inside like the light that vēer bought. It has a similar driver but it takes a 16mm MCPCB and just has a lip/ledge for the MCPCB to sit on. It has a Lattice Bright emitter just as expected in a light of this price
Don’t expect to make a hot rod out of it. It’s just a cheap 14500 light that needs a Nichia on Noctigon upgrade after pressing/Arctic Silver epoxy a copper disc in there.
Was wondering if these were still available for cheap. I went back through my ebay purchases and the seller i got these from orgionally dont sale them anymore. I gave all these away and sk68’s when the tornados hit around the Dallas area recently to friends and people without power.
Hopefully someone knows!
I see some on eBay, but the claims are a bit outlandish:
One, the cheapest I could find, for $3.99, with a “1500LM CREE R5”:
http://www.ebay.com/itm/1500LM-CREE-R5-LED-Mini-Flashlight-Torch-Light-Hunting-Handy-Lamp-3-Mode-AA-/391290060546
…while we know that the ones from last year were all shipped with ultra-blue LatticeBright XP-E counterfeits. Conveniently, the listing doesn’t show any photos of the emitter.
Thanks for the information, wish that we could the deals we got last year on these. Is there any other cheap ones that fill its shoes?
i just bought from xtar the wk21 for $11.10 thats 500 lumens from a real quality company.
