Is the genuine battery carrier for the fenix tk35 available for sale? If so, tk35 clone + fenix battery carrier = less than fenix tk35?
You could end up with a nice tint tk35 clone with decent driver if the batt carrier is reasonable money.
You believe the spec of 130k cd from Fenix on the TK70 bro? You can check out the table i posted above. BTW, my figures are OTF.
Anyway, i guess it's not a spec per se, it's just straight from Fenix. Like if you buy a copy watch, would you believe the spec? (it's a bit different for flashlights, but the concept is there).
So basically this item doesn’t have the fenix output. I am expecting like 800lumens
I think if you change the driver, it can compete with tk35 one on one …
Yep, another "unfortunate" point for some i guess. There are few lights (same emitter/40mm reflector form factor) which i know of gets you over 800L OTF though. Not even the U80/980L. I don't have the TK35, so i can't give you relative readings. The 980L with 3.8A at the tail (maybe slightly lower with the switch) gives me about 66-67 lux reflected ceiling bounce and dives below 60 after 1 minute. This one is about 54-55 and holds there for a crazy 9 mins (and is able to sustain max output mode for over 1 hr - note i have done this 3X already once in 30 deg C heat not unlike your location in Padang/Indonesia and twice in 23 deg air-con environment). The T40CS gives me 79 lux. Even the FF STL-V2 gives me 72.
RRT-2 XM-L is 39.8L / rated 468 OTF (ANSI), it is 45 lux on my meter. TK70 is 218-220 reflected, rated 2200 OTF (ANSI).
Just some info from my experience. I don't 100% do manufacturer specs, but i do use it as an avenue for information....nothing more/nothing less.
