Nice DD! Looks classy! Are those leds yellow or orange?
Update.
I got these in two weeks ago but had no time to play with them:
Besides, I had not receive the pots yet, they came a few days ago. I bought them on Ebay (link) and they are 100kOhm.
I decided on a 1K resistor on the 'diode' spot (which is in series with the pot on the other side). The leds are 805-size 630nm leds (Osram btw, but I see no difference with no-name red leds that I got on ebay before).
The pot fitted very well on the pads, and cleared the spring that I used, even on full compression. I made sure that while soldering the bypass wire on top of the spring, there was enough hole leftover for a small screwdriver to enter. Adjusting the pot like this worked easily without problems.
I tried the switch-assembly in a BLF-A6 (bleeder resistor=680 Ohm) because Toykeeper's firmware has proven rather finicky about what goes on in these lighted tailcaps (and with this mod it was no different, but fun to play with). But first about the tail light: with the pot fully open, there was a nice, well visible amount of light, clearly brighter than a tritium vial, but not disturbingly bright at all:
(next to my ReyBLFTi light)
With the pot fully to the other side, so about 100kOhm, the brightness of the tail was about tritium vial level (the camera overexposes red a bit compared to the other colours)
So for getting the brightness of at least red leds down to 'trit-level', you do need a high value pot (told you so ). But everything varies with everything so other led-colours will behave differently, other batteries perhaps even (did not check yet).
Now for the interference of the mod with the BLF-A6 User Interface. My standard setting is 7 modes without memory. With the pot fully open, long-press reverse mode changing did not work, as I found before with low resistor values in the lighted tail mod. But the fun of this mod is that you can just turn up the resistance and see what happens . With the pot at '15%' reverse mode changing started working (brightness of the red leds was still good). But the light appeared 'stuck' when in a long press: when the light was switched off and on again after a minute, this was still seen as a long press, and it went back one mode from the one it was when switched off (how would you name the opposite of next-mode-memory, previousfromlastmodememory? ). With the pot turned up a bit further again, after switch-off the same happened (previousfromlastmodememory) but only for 10 seconds, waiting 10 seconds got the UI back to normal: always start on low mode when switching on again. The pot a bit further again, this 10 seconds went down to 4 seconds, and a bit further again the BLF-A6 UI worked completely normal again. The red leds were still bright enough for a nice effect. So in my situation (BLF-A6, these red leds, this pot) the fixed resistor on the diode pads would best be about 15K, then even with a fully open pot the UI behaves.
The pots that I bought have no physical stop when on minimum or maximum, you can just turn the slider fully round. For operating the pot this is annoying because you can not see exactly when you are at the end of the resistance-trace, and beyond that the slider looses contact. But a positive consequence is that with the slider in between the trace-ends, you have switched the tail-lighting fully off, which could be usefull somehow someway.
I had a fun evening doing this :-)
