Yep. Great host, but stock not very good.
Modded? Dedomed XP G2 S2 1d, LD1 driver and 425Kcd.
Different beast indeed!
Far throwing light and a solid lamp.
has anyone else tested the 1505 and measured different emitters? it’s a bit weird that the de-domed xpg2 had less kcd than the xml2, so if someone else has tested i’d be interested in the results!
I don’t think a XP-L HI is going to throw any further than a dedomed XP-L does. My assumption is just from reading other threads and the testing that has been done in those threads between HI and dedomed emitters.
I just built a UF-1504 with the XPL HI yesterday and still have a spare pill. Maybe I should make a comparison module with the XM-L2. Unfortunately the only XM-L2 I got lying around is an unknown bin leftover part.
I always wondered how the hell did you get such low results on 1503 (180 or less kcd) cause I had very consistent performance out of them like 240-280kcd (seriously I am not kidding here). They were really nice and I was pleased...
Well all that changed now cause I got a new batch of 1503 with ultra c.r.a.p aspherical lenses :(
Lenses with a lot of color abberation, with low light transmittance and low performance from 160-180 kcd. Totally unusable!
If someone has found right lenses for this 1503 please pm me. I must order something asap.
I have a few of the top performing lenses for these, in stock. The rumors that I won’t sell my RAs, heh, please pass the word that if you want the best RAs there are, we need commitment to me to run another batch of the size needed. I made the first working RA there ever was when they were taken to CPF and then sold out from under me by Wav-tried-en-failed. I never gave them my formula, only the generic proposal plans for the design. As far as I could tell they tried building a business from email communications and thought they could run with it. I still hold that formula and it will die with me.
First off, you can’t make an RA from metal. It’s good that people have tried, I even tried. Not discrediting the ones that tried, but, there are some very deep problems that need to be solved to actually make them correctly. I have them made for a lens and that lens is made for a light. An order of operation exists. This is what I do everyday, I work with optical systems containing components costing more than expensive homes. Honestly I’ve tried to tell this forum with 100 hints how I can help you jump your lights 5 years into the future, practically speaking, and only a few of our good builders have followed up with me the right way. Then I read “he won’t sell them”. It’s because it simply doesn’t work that way guys, I’m sorry. If you want the longest throwing lights in the world, you just have to tell me that you want one, and then setup a run through me. I’m very willing to help, but I can’t help you if you don’t ask me seriously. Some have turned away because they aren’t told $20 for $150 in parts. Does anyone ever look into precision laser components? Precision optics? It’s kind of like going to the jeweler and saying, I want that diamond, the big one right there, I got $50. Then the jeweler walks away and continues helping the person who actually bought diamonds before. Really not trying to sound rude but at this point, I’m right here, I haven’t denied anyone sales, please don’t say that is what I am doing.
I outlined the problem. People need to agree on the host, and commit to it. I think that should be simple.
One host that I could outfit with an RA that is budget right now, I’m going to attempt soon as I have them in stock—the SR52 Intimidator. It’s machined correctly for my modification type and not much more to it besides that it has good quality. The Skilhunt Defier XO, K26, both setup right for small aspheric builds.
Do you like any of those? If yes, get a discussion going and pull me in. As a dealer I will work with the forum to develop the longest thrower possible in that design. I just don’t do it without commitment from the forum and I’d like to make that clear.
Instead of doing ten different group buys for the same bait and switch crap from china, maybe try a group purchase built by engineers instead of sales reps. You might be surprised at the results you get.
Pretty much sums up what I’ve been trying to explain to people too. Knowing how ridiculously good yours are (and the other issues) is why I keep telling people that although the purely machined SS collars I’ve made have gotten to the point of around a 25% boost in the 1405, it’s still a far cry from the 80+ you’re getting from your optical systems. I’m sure there is still more tuning that can be done in the micro metal RA’s, but getting to 50 boost will probably require a cost equivalent to (or close) to the RA’s you’re making, if it can even be done.
By the way MEM, I’ve been meaning to text you back. Been a busy last week, but I think I’ll have some time today to finally get back to you.
So on an aspheric head with twist zoom glass lens can the
XP-G2 S4 2B dedomed at 3.76 Amps in Turbo or High Mode hit 1200 or more meters of throw for the ‘white laser’ effect…and still be useful at close range using flood ?
Who would build this ?
Can it exceed the Dereelight in throw ?
I think a fixed Aspheric is less useful and versatile than a good twist Zoom.
Hi robertkoa, you did inspire me to redo the mod properly today, but it being my farthest thrower still, I’m reluctant to part from it.
I may re-mod my second 1504 (which is a shortened 1405) one of these days with the same parts and then sell one to you. As for the costs, the parts were about $50 altogether and shipping to the US (?) is $27 with tracking.
Anyone have beam shots of these lamps as in the thread title?
I have just received two 1508’s with 75mm glass ( both broken edges) from Shenzhen Homesafety Electronic Co.
The lenses still fit and are not cracked in the middle, only around the mounting. They are sending me new lenses.
Those glass aspheric lenses for flashlights are all made in a mould, not ground to shape. Therefore they all have to some extend surface irregularities, it is hit or miss how much, it is very far from optical grade and even my Sunwayman aspheric flashlight clearly has a less than perfect lens.
You must have one of the worst examples of them all, or perhaps all the 75mm lenses in the 1408’s are exeptionally bad quality.
Btw, the maximum flood on your light looks ectremely narrow.
Yep very narrow.
here is very quick un edited in camera jpg shot indooss just now on my bed.
I have two of these , identical, one is set to max zoom, …just about to drop off the thread, the other max flood.
I have shot a load of others, of the pill etc, that I will put up on the other thread I mentioned earlier
