What if I don’t have a camera? - I have 32 lights (4 are Olight), but no way to show you.
Yeah, I know that’s it’s on the Smart Phones too, but I don’t have (or even want) one of them either. - I Hate being bothered by phones, though I do have a magicJack just for my ‘family’ - VOIP.
I guess that I’m just too old and stuck in my ways to enter, but really think that the new S2 is cool!
My lights: JetBeam WL-S1, Thorefire PF04, Lumapower Avenger RX (2 AAA configuration) and BLF A6 SE
Each is used in a specific setting and performs amazingly. The JetBeam is my favorite because of the amazing range of battery types it can take with no additional tubes.
I bought this from Sam’s before finding flashoholic support online, it was all tan paint with yellow accents. The threads were glued so the paint got damaged on the battery tube. The missing paint on the tail cap came off with the masking tape. The gunmetal grey is Solid Film Lubricant, a molybdenum epoxy in aerosol format that can be used to coat aluminum firearm receivers when the ano has worn off. So I thought it might work on the bare Al of a flashlight.
The driver has been replaced with a FET+7135 the emitter is dedomed XP-L V6 3D and it has C8 style reflector. Under the ridged collar is a usb port that can be used to charge a portable device or charge the proprietary 18650. I kind of have an idea for making it work with any 18650 but it might take some tweaking. As it is now the charging feature charges the cell reliably to 4.16v and outputs 5v @ 1A. The screw down collar actually sucks heat out of the body pretty well after I cleaned the threads and put a bit of thermal compound on them. It runs fairly cool on high and competes with any others of the same class for brightness and throw with an IMR. It’s not my favorite but I’ve grown kind of attached to it and can see having it for years. I might even just remove the gimmicky usb cca and just add more brass under the driver.
Does anybody see anything wrong with this picture? … no Olights!… :_( ive always dreamt of having one ever since ive gotten on board the blf. They are just d**n good looking! Currently my favorate is my Thorfire C8 but that could change real quick if I win this Olight. Good luck to all! Edit: i got thw picture to show up.
I’m at my parent’s home for a few days & so this is all I can find lying around
An old 4-7’s FL I had done YEARS ago.
A #’s ti Quark that I sent out to have beadblasted. I then anodized it to two different shades on bronze. I had swapped the LED it to a then still engineering sample of XP-G 4000k R4 (& I doubt I’ll bother updating b/c there now seem to be so many funner/more exciting hosts out there to do) & so yes, I desperately need an update. =)
This is my S20 Baton. It's my everyday work light. I ve been carrying it for years. At one time I replaced the older style emitter for an XPG2. Love the lockout, and the magnetic tail.
This is my modded Solarstorm SC02, my most fun light to date, quad RGBW optic/dsche board with colour XP-E2's and a 92CRI Nichia219A. The fun comes from DrJones' super rgbw-driver that is simple for the simple use, and extremely enhanced with many options if you are in to that. The stripes in the picture comes from the (I believe it was 2000Hz) PWM that the driver is using for adjusting the brightness.
