Review: Four-way Convoy S2/S3 mini-review
114 posts / 0 new
garrybunk
garrybunk's picture
Last seen: 1 day 22 hours ago
No, getting hot quickly is a good thing.  It means the heat is getting transferred out to the air like you want. If it didn't get hot it would mean the heat is trapped at/near the emitter and could potentially overheat and/or damage the emitter.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
viperbart
viperbart's picture
Last seen: 8 months 3 weeks ago
Tapis wrote:
Just got my Convoy S3 today. It actually gets hot quite quick and feel hotter than my Zebralight SC62w, maybe because of a lack of heatsink?
Your Zebralight has a temperature sensor and dials down the power to keep it under 60Celcius. Your convoy doesn’t have this feature and let’s the heat rise until you decide to turn it down. Your convoy will naturally get hotter than the ZL after a few minutes. .
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 3 months ago
garrybunk wrote:
No, getting hot quickly is a good thing.  It means the heat is getting transferred out to the air like you want. If it didn’t get hot it would mean the heat is trapped at/near the emitter and could potentially overheat and/or damage the emitter.
-Garry
There is also a caveat to that too…getting hot fast means it’s pumping out ALOT of heat…if there isn’t enough surface area or thermal mass to the light…the heat has nowhere to go fast enough and only heats up the entire unit
This is why lower modes is a good thing…if it’s getting too hot too fast, throttle it back and allow the heat to distribute and convect away…then if you want you can bump up higher for a little bit…this is why I like the STAR firmwares auto throttle function Smile
surprise
surprise's picture
Last seen: 10 months 2 weeks ago
Do protected 3400 cells (e.g. the ones from Fasttech) fit into the Convoy S2? After reading all posts regarding this, some refer to the S2, others to the S3…
ToyKeeper
ToyKeeper's picture
Last seen: 1 min 23 sec ago
Last I heard, the S3 can take protected cells but the S2 can’t. I don’t know about the newer S2+ though.
Most of the Convoy S line only takes unprotected cells, and usually only cells without any additional wrappers or button tops. It’s fine though, as long as you use firmware with decent low-voltage protection (which all pre-assembled Convoy lights should have).
I used to buy only protected cells, but now I prefer unprotected unless I’m using them in a serial configuration… and I try to avoid serial configs.
andyz
Last seen: 3 years 6 months ago
It depends on driver’s spring size. Mine with 8,9 mm spring fits at least 68 mm protected cell.
dw911
Not in mine, even samsung laptop pulls end up with dents in the top if im not careful.
Personally I would be worried about shorting a protected cell or damaging the cell protection circuit
surprise
surprise's picture
Hmm, the spring could be shortened…
That doesn’t sound too promising – even after shortening springs.
Are the other S-series Convoy lights any better? S2+, S5, S3, S6?
I would like to get several as “18650 candles” (XM-L 7C with 1050mA).
SIGShooter
SIGShooter's picture
Last seen: 9 hours 32 min ago
I have a S2, S2+ and S6 and I’ve never had dent issues with any of my flat top batteries.
ToyKeeper
ToyKeeper's picture
Since it’s only one cell and it has a decent driver, it’s probably safe to use unprotected cells. They fit easier into almost everything, and the driver will cut off power before the protection would have kicked in anyway.
My favorite Convoy S-series light is the S7. It’s not good for high-powered lighting since the stainless steel doesn’t shed heat very well, but it looks pretty and is nearly bulletproof. It holds up to wear and tear a lot better than anodized aluminum. Mine runs at a maximum of 1900mA with a Nichia 219B, though I don’t normally push it harder than 900mA.
surprise
surprise's picture
I have a heap of unprotected Samsung ICR18650-26F 2600mAh, according to previous posts they should fit:
http://www.banggood.com/Samsung-IRC18650-26F-Rechargeable-Li-ion-Battery...
If the driver (complete package from Fasttech) really cuts of completely before 2.75V – even when running at 1050mAh or 500mAh (middle mode), everything is good!
Then these are exactly what I’m searching for – cheap long-running warm white “candles” :bigsmile:
RonMuller
Last seen: 6 months 3 weeks ago
You just need some custom firmware in the driver to make the light flicker like a candle.  Hmm, my wife would love something like this.
surprise
surprise's picture
There are already “lifelike” flickering LED candles to buy, even from Philips, but they use proprietary rechargeable cells with low capacity, because of the form factor Party
They are however very low power, like real candles, so they are more a gimmick than usable lighting. I’ll use the Convoys outdoors, and will put a diffuser over them. One working option is the good old white balloon – nice weight-to-size ratio, and customizable size! :bigsmile:
zoom zoom
Last seen: 2 years 2 months ago
My s4 won't hold a protected cell. It's too long, and puts too much pressure on the driver.
lightme
lightme's picture
Last seen: 5 years 6 months ago
I noticed a my new gray S2 host has a distinctly blueish tint to it. This is the first time I’ve seen that much tint in a natural gray hard anodizing. Anyone else get one like that?
RonMuller
We have one of the flickering candles your speaking of.  I find them fairly useless. If I could get that functionality and have a decent flashlight it would have more Waf (wife    acceptance factor).
I like the idea of using a balloon for a diffuser!
ToyKeeper
ToyKeeper's picture
I’ve been tempted to do that. I made something to simulate lightning, but haven’t done a candle flame yet. I usually just tail-stand a light on “low” (or even “moon”) when I want something candle-like.
It’s hard to include randomized behavior modes in regular EDC firmwares though, since a good random number generator takes a lot of space. But if we ever start using the attiny25 instead of attiny13, there should be plenty of room to include a candle mode along with regular flashlight functions.
Then again, I just freed up about 260 bytes on my clicky EDC firmware… maybe I should use that room for a candle mode. Smile
lightme
lightme's picture
We have some that came with a wireless remote to turn them on. It’s obvious they are fake candles because they flicker in sync so it can’t be random. Turning them on one at a time is the only way to make them flicker out of sync. Unfortunately, it’s not easy to do that with the remote.
Zanders
Last seen: 11 months 2 weeks ago
My S3 from Fastech can take Panasonic 3400 protected but not the S2, the cell was to long.
DrJones
DrJones's picture
Last seen: 5 years 4 months ago
Here's a thread about candle flicker.
After some hours of thinking, simulating and programming, I could reproduce the statistical behaviour described in the links there in 140 bytes (uhm, sorry for showing-off, but I am a bit proud about that).  I also integrated it into my RGBW firmware, adding some red&green for a warmer tint. Quite nice, used it a few times. Brighter than a real candle though (a real candle has about 12 lm).
However these candle flicker modes are unrealistic in one respect: Inside a room (no draft) most candles I had just burned very steady most of the time, i.e. no flicker at all.
Mr. Nobody
Mr. Nobody's picture
Can someone here measure there S3 and S2 brass pills, curious to know the depth of each one. The S2+ has the deepest but no one in the US has any in stock
viktori
viktori's picture
Last seen: 5 years 2 weeks ago
I just got my S2 today from FT.
I was testing it out and one of my tests was lengthwise smacking of it’s tailcap end against my palm.
I swear, at some point it started flashing in low mode at perhaps 1-2Hz (once or twice per second). This was a flash controlled by the driver, not an accident due to loose contact. Now I can’t reproduce it anymore. I’m not certain if I hit the switch at all or was it contact break due to battery shortly breaking contact, though I suspect it’s the former. My protected battery is pretty firm between the springs.
This one is advertised as 3/5 modes model, but it obviously has some secret mode(s).
Anyone have any info on how to access it again?
I like beacon modes, though I prefer to keep them hidden by default if possible.
Thanks,
Viktor
Edit:
I can reproduce it, but only by hitting it against my palm instead of by operating the switch. My palm hurts a bit. Smile
Is this low voltage warning that’s triggered by momentary loss of contact?
I’d estimate it’s a 1Hz high duty cycle flash. Roughly 900ms on, 100ms off, rinse, repeat.
This is my flashlight collection.
viktori
viktori's picture
Yeah, that’s low V protection kicking in. Tested it out and confirmed by draining the cell.
