Keygos KE-1 vs KE-2 vs KE-5
I have seen these Keygos Flashlights that are either Ultrafire copies or from the same manufacturer. Both the KE-1 and KE-2 look like the Ultrafire C8, with the KE-5 looking like UltraFire U-80.
Possibly they are the same rebranded or the maker is using a basic carcass and the circuitry is different. I do not know and I am clueless on this subject.
Keygos are generally listed as being 1300 lumen, but more like up to 1000 lumen.
I have written to Keygos to ask the differences, but maybe you guys with them can provide a better review. http://www.keygos.com
The only differences listed are the body type and measurements.
KE-1
Dimensions
6.14" x 1.77" x 0.94" / 15.6 x 4.5 x 2.4cm (L x Head Dia.x Body Dia.)
Weight
177g / 6.24oz
https://budgetlightforum.com/t/-/4253 review
http://www.ebay.co.uk/itm/1300-Lumens-CREE-XML-XM-L-T6-LED-Flashlight-Torch-KE1-/160673345755?pt=AU_Sport_Camping_Hiking_Lamps_Torches&hash=item2568e0b0db
KE-2
Dimensions
5.94" x 1.77" x 0.98" / 15.1 x 4.5 x 2.5cm (L x Head Dia.x Body Dia.)
Weight
180g / 6.35oz
https://budgetlightforum.com/t/-/3978 review
http://www.ebay.co.uk/itm/1300-Lumens-CREE-XML-XM-L-T6-LED-Flashlight-Torch-KE2-/160623343369?pt=UK_SportsLeisure_Camping_LightsLanternsTorches&hash=item2565e5b709
KE-5
Dimensions
5.90" x 1.77" x 1.18" / 15 x 4.5 x 3cm (L x Head Dia.x Body Dia.)
Weight
154g / 5.43oz
http://www.jayki.com/13146 review
https://budgetlightforum.com/t/-/3320 review
https://budgetlightforum.com/t/-/4305 review
http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=160609127192&ssPageName=ADME:X:AAQ:DE:1123
https://budgetlightforum.com/t/-/4423 review
I read in one forum that the heat sink on the KE-5 was glue instead of screwed.
I also read in a translated Russian review something about the battery current!
http://www.24au.ru/Details.aspx?LotID=1191869
1) Absolutely honest 900 lumens.
5) Supply of 18 650 single battery - included. Ток потребления 2.5 ампера. Current consumption of 2.5 amps. Что интересно, применять можно только аккумуляторы без защиты, т.к. Interestingly, use only batteries without protection, because при токе 2.5 ампера защита отключает аккумулятор. at a current of 2.5 ampere protection disconnects the battery.
Here is a list of Keygos YouTube videos:
KE-1
http://www.youtube.com/watch?v=D-tPj-pF-Vw
KE-2
http://www.youtube.com/watch?v=wTsxn7hW6j8
KE-5
http://www.youtube.com/watch?v=8ycwUBP4xgQ
http://www.youtube.com/watch?v=ZFLzOm3y30Q
http://www.youtube.com/watch?v=jCCmsg1av54
In general the only main thing I can imagine is the reflectors are different. They are all smooth, but I think there might be a difference around the Cree emitter.
Possibly the digital regulated circuitry is below 3000mA Current Output.
I am looking at single cell 18650 Flashlights of the most lumens, highest power, and longest beam throw. Budget of around $32. I was looking at Ultrafire flashlights but now considering one of these Keygos copies.
These 3 models interest me, but I would first like to know their technical info and the differences between them. Plus their weaknesses compared to other similar budget flashlights. But I want to keep the subject on these 3 Keygos flashlights please! Comparison beam shots between them would be super. :)
Ok, something for you experts to get your teeth into. Thanks in advance!
First of all , welcome .
It seems you've done quite a bit of research already .
You'll fit right in here .
Good luck finding the perfect light .
Thanks Jack. :)
You mean I am a Geek. Well I only have two Flashlights (not Fleshlights) at present. But already looking for a third.
Some years ago I made the mistake of saying potatoes are all the same. I nearly did the same today in saying batteries are all the same.
Well the first Keygos KE-5 I got burns at around 3.5 amps at the tailcap with Trust fire flame 18650. The second what I just got burns at only 2.05 amps. And it's not even close to being as bright.
Mine also puls around 2A. ILF ,Comparing the two do the drivers look identical? Did you purchase both from the same seller?
Do you have pictures of the drivers of both KE5? it seems I also got the 2amps driver before modding mine.
Thanks
Yes both bought from redlog on ebay. Both pills are completely different so I would say so are both drivers as well. Nite and day difference between the 2. The first one I got will probably be very close to 800 lumens and maybe even brighter.
I think the Cree C8 XM-L is brighter than the second Keygos KE-5 I got. I wouldn't buy another like this one. I would bet the first Keygos KE-5 is over 200 lumens brighter than this second one I just got for my son.
Pics please.
I don't want to take the thing back apart. It's built cheap compared to the first one. I'll leave it at that. I won't recommend anymore of them since they have went cheaper.
Welcome to BLF, Chris!
ILIKEFLASHLIGHTS
I have been close to pulling the trigger on a KE-5 from redlog as I LOVE my KE-1 and their service was excellent. However, I read your review and getting 3A instead of the 2A I get from the KE-1 made me want to go for the KE-5 just to see the difference.
I might just have to get the KD C8 because I think it is the same as the KE-1 only cheaper. Then, if I'm not getting more than 2A, I will have to do my first mod and put a new driver in one of them.
What do you think of your KE-1 compared to the KD C8? IIRC you have both.
Do you think if either of them were pulling close to 3A they would be in the ballpark of your first KE-5?
OTOH, perhaps I should just save up for an X9. Guess I could just do the mod on that if I got one of the 1.4 drivers as it sounds like I likely would. I am very happy with the KE-1 would just like a bit more through and to see what one of these would actually do with a 2.8 driver.
Wade
Wade, I took some pictures for you so you can see the difference what I mean. Now if you can find one like the first KE-5 I got I would tell you to buy it in a heartbeat. Let me upload these pictures and then I will tell you more what I think.
Ok here's my first bright Keygos KE-5. That's approx 85yds.
Here's the second Keygos KE-5 and you can see that it's nite and day difference between the two. I didn't touch the camera between these 2 shots. Again 85yds to that shed.
Here you can see the difference up close. My first Keygos KE-5 which is the bright one is on the left. The 2nd Keygos KE-5 is on the right. To me there is no comparison.
Wow that’s a big difference. Mine does seem brighter driven at 2A. It looks like its in med mode.
Yep. Both were on high and both had Trustfire flame 18650 that were both about fully charged. Now remember I have got some tail cap readings on the first bright Keygos KE-5 as high as 3.75 amps I believe with the Trustfire flame 18650.
And just for grins I took a picture of the same exact distance with the TR-1200 5X Q5 light.
Now you know why I like the TR-1200. I'm guessing that thing puts out very close to 900 lumens.
