Do you leave your Chargers plugged in?
70 posts / 0 new
THE_dAY
Last seen: 1 min 55 sec ago
This question is for Li-ion battery chargers, phone/tablet/laptop chargers or any other mobile device charger when NOT in use.
I leave my smartphone and laptop charger plugged when not in use.
These are behind my nightstand and to unplug and replug these every time I charge would be a slight hassle as I charge randomly and frequently.
I used to leave my Xtar charger plugged in when not in use, just the walwart.
I recently have unplugged the Xtar walwart since it has a green LED light and I don’t want to waste energy and raise my bill unnecessarily.
After searching the web a bit it seems the smartphone chargers of the past few years use very little when plugged in.
I also understand that it is worse to leave you device plugged in to charger when it is already fully charged.
I’m curious to what practices/advice other members here have?
DanielM
DanielM's picture
Last seen: 10 months 5 days ago
All the time.
My phone charger has been plugged in for at least two years. Works just fine. I can’t be bothered to plug it in/out of the outlet, I’ll take the expense of whatever vampire current draw and wear and tear it takes.
Old-Lumens wrote:
I love modding, but I don't have much use at all for flashlights in general.
TomNMich
Last seen: 2 weeks 6 days ago
I leave mine plugged in to a power strip switched off when not in use.
djozz
djozz's picture
Last seen: 2 hours 19 sec ago
I leave everything that is from a reknown brand plugged in, including lesser brands that are tested to be electrically safe by HKJ.
All else is suspect, and usually not in use anyway. And stuff that uses old-school transformers I do not leave plugged in because they use up too much power.
Danglerb
Most stay plugged in, but those are generally the heavy use devices, the unplugged stuff gets a charge and unplugged and removed from the charger.
Calif is about to do some of its wacky stuff and require all chargers sold in the state to shut off or something like that.
On my list of things to do some day, make a nice individually switched charger farm. Maybe two of them, one in the house and one in the garage.
Still a bit dim
tech
Last seen: 6 months 3 weeks ago
I unplug all chargers and also switch off the power strip. I don’t trust them, I also have no smoke alarm and sleep with plugs in my ears (help me get deeper sleep). I used to leave my Mac on but since the battery is dead now I also switch it off.
THE_dAY
Thanks for the input!
This question is more about saving energy as a whole (1st world global scale) from all our walwarts as opposed to safety concerns.
Since my Xtar walwart has the green LED constantly ON I decided to unplug that one and only have it plugged in while in use.
I don’t how much it is actually using, maybe I need to get some type of walwart/plug checking device.
finges
Last seen: 12 hours 1 min ago
Buy yourself a plug in watt meter and check your chargers you will be amazed how much some will use in stand by.
Werner
Werner's picture
Last seen: 2 years 4 months ago
I have everywhere switchable powerstrips which I always Switch off when not in use. Laptop, Chargers,TV, PC everywhere.
If you have 10devices which consume only half a Watt in standby you get
10*0.5*24*365=43kWh which are used for nothing….so doing that is very unecological and uneconomical.
Especially with the smart devices we have today which only consume very small amounts of energy it’s ridiculous.
For example if you use a phone with 10Wh and recharge it 365 times a year you would only consume 4kWh for using it one year. I choosed 10Wh because that is also the energy for recharging a18650. so recharging a battery everyday consumes the same amount of energy like to let the charger stay plugged in but with the big difference that it has no use…
eebowler
eebowler's picture
Last seen: 2 weeks 4 days ago
None of my chargers, adapters stay plugged in. I fear wear and rare.
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
netprince
Last seen: 1 hour 1 min ago
I keep mine plugged into a power strip, and when not in use I switch off the power strip. I do this in the hopes that they will not be damaged by power surges or brownouts or whatnot.
Also some chargers (usually the less smart ones) used to want to be power cycled before inserting the batteries. I’m not sure if this is the case anymore.
Bort
Bort's picture
Last seen: 19 min 49 sec ago
I keep my RCA USB outputs and LaCrosse BC700 plugged in all the time but they are CSA approved items. Both have been tested and use less then 1 watt idling, and are on a powerbar that i can turn off when i want to.
I NEVER leave any direct from china items plugged in, they are typically not CSA, UL or CE approved and even if they have a sticker saying they are its more then possible they are counterfeit.
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
hank
hank's picture
Last seen: 5 hours 18 min ago
+1
brad
brad's picture
Last seen: 3 hours 51 sec ago
I use about 130 kw of electricity per month and don’t sweat the chargers much, but a surge protected power strip seems to be the right idea, and you can get ones with individual switches if you want.
I keep meaning to set up a charging station using a power strip with individual switches so that I can leave everything plugged in, yet have individual control, and separation from surges when not being used.
Not what we have but what we enjoy, constitutes our abundance.
FlashPilot
FlashPilot's picture
Last seen: 50 min 33 sec ago
^^ Best answer yet.
I resell dozens of flashlights each month (with cells and charger) and make each customer promise that they will not leave their chargers plugged in after use or leave them unattended while charging. Its good practice to unplug and takes so little effort, which might prevent your house from burning down and/or injuring someone.
qandeel
Last seen: 3 hours 16 min ago
Good discussion. What is a surge protected power strip?
 عُمَانْ
Streamer
Streamer's picture
Last seen: 2 years 1 month ago
Only one left plugged in is on USB charge from desktop.  It's off when I shut down every nite and go to bed though.
However, I do leave Iphone charging over nite.
MontyPyfon
MontyPyfon's picture
Since about four weeks ago, I always unplug or power off any chargers.
My brother lives on a grid where there are too many people connected with solar panels on their roofs. He had a Nitecore i4 plugged in but empty of batteries.
He and his wife were eating lunch one day, and they heard a loud “pop” in the next room. He investigated and smelled acrid electrical smoke.
His nitecore was dead!
A nice bright sunny day and with all those solar panels producing extra power, seems their grid voltage gets up over 255v when it should be ~240v.
His TV went out another day (a small power board fried) . His neighbours have reported similar issues with over-voltage in the area.
My son, on the other side of the country, has some gadget on his computer, modem etc that trips when voltage gets too high, and it records the time and over-voltage. This happens occasionally in the middle of hot sunny days here in Queensland. His analysis is that it is the over input to the grid by solar panels controlled by cheap Chinese controllers.
Keep ‘em off when not in use, or protect them with something.
To many flashlights, too many batteries. Wife is going to kill me Smile
Q8 (Still coming), S2+: 10, SRK style: 6, C8: 10, L2: 3,  L6: 2, Couri XM-L2: 1 LuckySun BLF SE: 3, EagleEye X6: 2   and lots more....
Monty
Bort
Bort's picture
thats odd, bad design or something, solar power is low voltage D/C that has to be converted to A/C, so it should not be the panels but something wrong with the inverters.
Bort
Bort's picture
FlashPilot wrote:
^^ Best answer yet.
Thanks, this is why i can’t see li ion flashlights becoming mainstream, the chargers are not there yet and the batteries need special care (some of mine are now overheating when i charge so i toss them, the chargers don’t have temperature protection, and non enthusiasts would just ignore it).
I wish 4AA was mainstream, eneloops are safe, chargers are plentiful, it could run XP-L chips at 3A without trouble, but would need temperature protection in the light, tailstanding at high amps, or the light in a blanket or drawer or duffel bag for example could cause big problems.
Suncoaster
Suncoaster's picture
Last seen: 3 days 18 hours ago
Location: Where the girls are green and the grass is pretty.
This country has switches on all (240V) powerpoints, so I leave chargers plugged in but flick the switch off.
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
pilotdog68
pilotdog68's picture
Last seen: 9 months 5 days ago
laptop/phone chargers are always plugged in. 18650/etc chargers get unplugged mainly because I need use of that outlet.
The Miller
The Miller's picture
We got the notebook chargers plugged in and connected to the notebooks all the time until I started reading about the cells. Now I turn the block with outlets they are connected to off in the evening and switch it back on as the first notebook is about to shut itself down because of low battery.
Cellphones I used to let them drain the battery and then recharge to full and kept the adapters plugged in. Now I recharge them when at 20-30% and unplug when 80-90 using 1 adapter for all the rest unplugged and not used anymore.
brad
brad's picture
It is a version of this, with surge protection added.
http://lifehacker.com/how-to-choose-buy-and-safely-use-a-good-surge-prot...
Here is one with American plugs.
CheapThrills
CheapThrills's picture
Last seen: 1 week 4 days ago
Phone chargers: IN
All others: OUT
Andrew2007
Andrew2007's picture
Last seen: 5 years 3 weeks ago
I leave them plugged in but they’re individually switched so I always switch them off.
MontyPyfon
Yes, I should have said the problem is with the inverters. Thanks for the heads-up.
Monty
lostheplot
lostheplot's picture
Last seen: 11 months 12 hours ago
thats odd, bad design or something, solar power is low voltage D/C that has to be converted to A/C, so it should not be the panels but something wrong with the inverters.[/quote]
I believe that the voltage put out by the inverter would have to be slightly higher than grid voltage, otherwise it would not flow(bit like water,air or hydraulics )my 03
just had a look at our inverter presently 10 am putting 245v out
I used to live in the Gladstone area (qld) for 15yrs and never had so much trouble with power ,brown outs load shedding ect.not to mention storm dammage
but I guess qal comalco and the smelter all came first..
sorry all images down
thanks photobucket
SawMaster
Last seen: 2 years 3 months ago
My old NiMh charger stays plugged in as it’s very inconvenient to get at it’s wall-wart but otherwise everything else is on surge/power strips, sometimes with a downstream strip for lesser-used stuff at that location.
My desk has a main strip (all PC gadgets and usual lighting) then goes to a radio strip (ham gear and chargers, brighter work-light) so that for almost every use I just hit one or two switches. My old workbench was the similar and when I’m done the new one will be too.
I’m not as worried about “vampire power” as I am fire hazards and damaged equipment from surges/spikes/brownouts. The MOV’s in strips wear out so over time I add a new “main”, downstream ones are usually safe to use longer so I replace them occasionally. I learned from a lightning strike to not leave anything I value plugged in directly when I’m not here to monitor things.
Phil
Jack Kellar
Jack Kellar's picture
Last seen: 4 hours 23 min ago
Only when charging something up.
Or when I forget it there. It happens…
sp5it
sp5it's picture
Last seen: 6 min 24 sec ago
I always disconnect unused devices.
Mike
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
 If a lot of people listen to Slayer, the world would be a better place to live" - Tommy Wiseau
