I tested everything in my house back when I got a kill-a-watt and the phone chargers and other wall warts didnāt even register a decimal when not in use. I do unplug most things when I leave on a trip and nobody is home. But otherwise they stay plugged in. Unplugging and plugging everyday can lead to wear on the outlet and stress on the internals of a wall wart as you pry it free.
If you want to save enough power actually see a difference on your bill, here are the real power eaters. Use these less:
Microwave
Oven
Stove
Refigerator/Freezer
Chest Freezer
Home Heater Fan
Kitchen food prep devices
Incandescent bulbs
Internet router
Internet modem
Laptop
Sounds right. Things that get warm to the touch are using power, but not a lot unless they have a fan or burn your hand. Things that have no certification or testing are hazardous in the event of power surges. Anything plugged in may increase the risk or damage in case of a nearby lightning strike.
My internet router + modem take 60w. If you are reading this itās likely the same for you. Thatās a lotā¦ 525600 watts a year, or 526 kWh. That could be reduced 67% by using a timer to shut it off while sleeping or at work.
Thanks HKJ, thatās a good idea.
I have the Xtar SP1 charger and looked through your review for standby current for just the Xtar walwart (donāt know the correct name to call it) while plugged into wall but not plugged into charger (12V input) and I see you donāt test that.
It could be a nice addition to your reviews to add this info if you wish.
Iāve plugged the Xtar walwart back in when not in use as it was a slight hassle to plug/unplug into wall when wanting to charge. I do however unplug the charger end (12V input)
Every charger model is different so you have to check yours. There has been government pressure and some regulation to cut phantom power usage because as it rises it increases societal electricity consumption for little benefit, but there is still a long way to go, some items like cable boxes typically use a great deal of power when idle.
